Question about Compaq Computers & Internet
Cant get usb port to recognize flash drive, mouse usb only charges
  • 275 Answers
I think you need to go to BIOS and check whether USB is enabled or not. You can go to the BIOS by pressing DEL or F2 key when you start up your PC . Can you please mention the motherboard's company name so that i can provide you more information.
Posted on Jun 17, 2008
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Computer not recognizing hard drive. Seems to be a problem with usb connection. Can I put the drive into another enclosure?
Definitely you can try with different enclosure, and it will work in any enclosure... But before buying a new enclosure it would be better if you try to connect the hard drive in a different computer to isolate where the issue is...
Jan 02, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
1 usb port cant detect a flash drive but can detect other usb devices
I'd say its the flash drive thats faulty .Try it in another computer to see if its recognized.If not the flash drive itself is bad.That port recognizing other devices says it functioning as intended.
Oct 24, 2010 | Averatec 3200 Notebook
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
Mouse does not work when used under xp. Followed installation guide but mouse appears inoperable. Mouse batteries are good and usb receiver working but no cursor movement with mouse. Attempted several...
I called Dynex customer support and they walked me through the troubleshooting process. It turns out there was a problem or conflict with one of my usb ports. The port recognizes my flash drive and other usb devices but not the mouse. I tried using the other two remaining ports and the mouse was recognized and works just fine.
Feb 16, 2010 | Dynex Wireless Optical Laptop Mouse...
Usb device not recognize
You mentioned that you uninstalled the unknown device from the Device manager. If you uninstall it then connected your usb flash drive you will see an error again on your device manager. This means that the driver for your usb port is not properly installed.
To install it, visit dell website, look for the model of your machine and locate the driver, download it then install from your machine.
Jun 02, 2009 | Dell Inspiron 6400 Notebook
I have a pny 4gb usb 2.0 flash drive black.instructions needed.
Most USB drives are "plug n play" meaning you just plug it in to a USB 2 port and your operating system will recognize it as a drive. If you're using Windows ME/XP/Vista, just plug it into a USB 2 port and once its recognized you'll be able to send files and folders directly to it by right clicking the file or folder and moving your mouse over SEND TO and selecting the drive from the list.
Nov 18, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
2gb usb 2.0 flash drive
I hope someone has helped you by now! After you plug your flash drive into your computer USB 2 port, your flash drive should appear in "my computer" as a drive. You can rename that drive by clicking once on the drive and then right clicking your mouse and selecting "rename" and name it Your USB or something that reminds you its the USB Drive.
Whether you rename it or not, all you have to do once your computer has recognized the USB drive is to open the folder where your documents are kept and either "move" or "copy" them to the USB drive. Remember that "moving" the files will remove them from your computer and transfer them to the USB drive. Copying the files will leave a copy on your computer as it copies the file to your USB drive. You can also right click the file with your mouse and move the pointer over "Send To" and choose your USB drive from the list and it will Copy the file to your USB drive.
Jun 29, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
USB port problems
Try going into the BIOS and see if the USB Ports are enabled. I don't know what type of system you have. When you turn on the pc it will prompt 'F1 to enter setup' or it might be F10. Do you have a USB mouse or keyboard? Try those in different ports.
Computers & Internet Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
