Question about Toshiba TEC B SX4T Printer
Good Morning; I have probleme installing driver for Toshiba B-SX4 under windows XP. I execute "DriverWizards.exe" (size =696 ko), using "Local port". This procedure finishs successfully. when connected to computer (using standard RJ-45 cable), the printer is detected as "Ethernet controller" with a yellow interrogation point. A notification message appears showing that windows XP can not found pilot for this peripheral. It is not possible to install driver from the CD using "Update pilot", the installation wizard indicates that specified path does not contains needed pilot. Thanks for your help.
    Champion:
  • 254 Answers
You have security rights problem.
Check with your administrator
Posted on Aug 16, 2011
I have a Hp 2133 mini notebook and just installed windows xp home edition onto it. While trying to activate it, i noticed it wouldn't work without ethernet drivers, so i used my other pc to get the drivers...
Check once again the downloaded driver is the exact one for Ur NIC. Extract the downloaded driver in the other PC and copy the extracted content to the next and run the setup.exe file Make sure to Safely remove Ur pendrive.
Mar 25, 2011 | HP 2133 Notebook
HOW TO GET SOUND DRIVER FOR MODEL NUMBER Toshiba Satellite L15-S104 (PSL10U01X02F) PC
I assume this Operating System is Windows XP
icon_downloads.png Conexant Audio Driver for Windows XP
Version: 6.13.10.8355 Size: 686,736 bytes Posted: 03/29/05 Released Date: 03/29/05 Applicable Categories: Driver, Sound Operating System: Windows XP, Windows XP SP2/SP3 Package: WinZIP self-installing ZIP file. Can also be unZIPped using WinZip, PKUnZip or equivalent. Also supports silent installation. Click for silent/unattended installation instructions. File: sl15sndx.exe Download Now
Download Link
http://cdgenp01.csd.toshiba.com/content/support/downloads/sl15sndx.exe
Applicable Models: Satellite L15-S104
Click the Download link - you will be prompted with window asking you to save - it is 671 kb file , After Downloading this file , Run this Downloaded file , it will extract 9 files and starts setup file , select the Conexant AC Link Audio Driver and click Ok button to conitnue. to install this Sound Driver
Please let me know if you require any clarifications.
Regards
Ramsoft
Jan 20, 2011 | Toshiba Satellite L15-S104 Notebook
Using XP Pro, with correct driver. Error is "Unable to Select Twain Source. Edited Path to include: %SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem; C:\WINDOWS\twain...
You will need to install the twain driver for the scanner.
Click on the link below and download the driver. Once its downloaded execute the .exe file. you will then get a small box pop up with "Unzip" on the right hand side. Look at the path of the unzipped file on the left hand side and save it to your desktop. For example C:\users\yourname\desktop instead of C:\Users\yourname\AppData\Local\Temp. The file extracts quite fast so go to the desktop and run the SETUPSG.EXE file. When its installed you should be able to use the scanner.
Download Canon Scan gear here >>>>>>>
http://modrv.com/scanners/canon/402prog.html
Good luck and kind regards.
Dec 14, 2010 | Canon CanoScan N670U Flatbed Scanner
Sound driver
Hi lbrugni ,
Below are the link to download the Sound Driver for your Computer. Please open the link in a new Internet Explorer window. Then, you can save the file on the Desktop and double click on it to begin the installation. After installation, please restart the Computer for the settings to take the effect.
Windows XP (Version: v3.11.0.51; 08-30-2006; 1.75M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/conexant_audio_os2006203a.exe
Windows XP (Version: 3.44.0.0(v3.44.0.0; 11-06-2007; 1.17M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_conexant_os2007336b.exe
Windows Vista (Version: v3.18.0.51; 02-02-2007; 2.3M)
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_conexant_25636A.exe
Good Luck!
Hope this helps.
Please post back if you have any questions or require any further assistance.
Thanks for using FixYa.
Nov 05, 2010 | Toshiba Satellite P105-S6084 Notebook
No Audio Sound RealTek Won,t Install?
Here is the driver link
1.For windows XP
http://cdgenp01.csd.toshiba.com/content/support/downloads/qg600audiox.exe
2.For windows vista
http://cdgenp01.csd.toshiba.com/content/support/downloads/driver_audio_sigmatel_25601A.exe
According to me, you are using windows xp as there won't be any problem with windows vista.
The sound card you are using is high definition audio.so you need to download Microsoft UAA Bus Controller Software.Install this first and installed the driver for windows xp.
here is the link for Microsoft UAA Bus Controller Software
http://download.cnet.com/kb888111-exe/3000-2110_4-104699.html
This will solve it
Dec 16, 2009 | Toshiba Qosmio G35-AV600 Notebook
I cant find a driver to the motheboard i have
Here is a link to your motherboard. They don't have the Windows 7 drivers but you might be able to set the driver compatibility to XP. I'm not sure but its worth a try.
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to change driver compatibility (this example uses Vista)
1. Right click on the driver setup executable file and select the Compatibility tab. Set compatibility settings to Windows XP (Service Pack 2), and set the program's Privilege Level to run as administrator.
2. Install the device drivers and reboot the computer.
3. Right click My Computer, select “Manage” in the new window select Device Manager. Select the unknown item on the list. Right click on the unknown and select Properties, and then select the Driver tab. Select the Update Driver button and let it search for the drivers. A warning will appear regarding the lack of a digital signature. Tell Windows to install the driver anyway.
4. Reboot computer.
5. Search for your xx.exe or open an Explorer window and drill down to c:\windows\wher driver installed
6. Right click on the exe and select the Compatibility tab. Set compatibility settings on the exe to Windows XP SP2 and make sure the executable can run as an administrator
Hope this helps. At least until they come out with the proper drivers.
Nov 08, 2009 | MSI MS-6702E Motherboard
104 people viewed this question
Top Toshiba TEC Office Equipment & Supplies Experts
pkwc
CheckitRight
CheckitRight
richie46
Are you a Toshiba TEC Office Equipment and Supply Expert? Answer questions, earn points and help others
