My printer has reach the maximum paper print. how do i reset it?
    Scholar:
  • 105 Answers
Hi. try this link:
http://free-download-resetter.blogspot.com/2009/12/tutorial-reseter-reset-printer-canon-ip.html
good luck
Posted on Nov 11, 2010
I have a canon printer and there a flashing light with p,o,2 and i cant print anything please help thank ya!!!
the time has come for you to reset the printer since you have already reached the maximum print outs for a printer, it varies from 5000 to 7,000 prints
Dec 07, 2013 | Office Equipment & Supplies
Epson r230 service required
Hi if your printer displayed service required, seems like your printer had gone a lot of printing jobs and reached to its maximum numbers to be printed and the counter needs to be reset. browse this site for solution or to download tools to reset your printer counter, http://www.ssclg.com/epsone.shtml
Jun 16, 2011 | Office Equipment & Supplies
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Am running windows7 and when i try to add a form with 21" width and 30.50" height my form is not added.
The form width you are trying to create is wider than the T6215 is able to print on. The maximum page width that you can print is 13.6 inches, if you try to create a custom size paper wider than 13.6" Windows will not show you this form within the T6215 printer driver. As you can not physically print 21" wide you do not need to define a paper size this wide. Simply create a paper size which reflects the maximum print width or 13.6" You will then be able to print the maximum width the T6215 is capable of and also see this form in the printer driver.
Jan 03, 2011 | Tally T6215 Matrix Printer
Flashing orange light. Have tried switching off and on, holding down power and resume switches. Nothing works
your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Feb 12, 2010 | Canon PIXMA iP90 InkJet Printer
Paper feeds, but won't print. As far as I can tell there is ink.
Ensure the Paper Tray is Not Overfilled Each printer tray has a maximum capacity rating, and this rating is based on a specific paper weight and or thickness. Consequently, situations might arise in which the tray will not be able to accommodate the maximum number of sheets listed in the printer specifications. Verify that the paper is not packed too tightly in the paper tray Adjust the Printer Paper Guides Adjust the paper guides to fit the size paper being used (Figure 1). The guides should be close (1/16" or less) to the paper without touching, so that the paper stays properly aligned without continually rubbing the guides. Locate and Remove Any Obstructions Inside the Printer and Input Tray Open the front cover and make sure the kickstand (if there is one) is engaged. Locate and remove any obstructions within the printer, such as paper pieces, staples, tape, or other objects. Close the cover. Remove all paper from the input tray. Inspect the input tray for any obstructions. Remove any visible obstructions. Reinsert the paper. Determine if Multiple Sheets Are Fed at Once From the Paper Tray or ADF Determine if multiple sheets are fed at once from the the paper tray or Automatic Document Feeder (ADF). Verify the print media installed is compatible with the printer Clean the ADF Paper Feed Roller Disconnect the AC power from the printer. Open the cover of the Automatic Document Feeder (Figure 1). Figure 1: Raise the Cover of the Automatic Document Feeder Using a damp paper towel, gently wipe the rubber roller to remove any ink or paper debris (Figure 2). Figure 2: Paper Feed Roller on the Automatic Document Feeder Close the cover and reconnect the power. Reseat the Dell Printer Power Adapter If your printer has a momentary loss of communication with your computer, it may be necessary to reset the printer to re-establish communication. You can reset a Dell? inkjet printer by unplugging the printer power cord from the electrical outlet and from the back of the printer for 10 seconds then reattaching the cord at both ends. If the printer queue icon is showing in your system tray (by your clock), you may have documents that are paused for printing. To resume printing a paused document: Double-click the printer queue icon to check document status of the active printer. Right-click on any documents that show Paused under Status, and then click Resume in the drop-down menu. Try a Different Type of Print Media Many image quality and paper feed issues are caused by the type of print media being used. Try a different type of print media that is specifically made for this printer. Replace the printer.
Nov 22, 2009 | Dell 968 All-In-One Printer
6 orange and 1 green flashing light on S400 canon bubblejet
Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
Apr 09, 2009 | Office Equipment & Supplies
No printing
you need to have an autochip for your printer or it might have reach the maximum capacity of printings or replace ink immediately
Feb 25, 2009 | Epson Stylus C62 InkJet Printer
Flashing orange and green light
Nov 21, 2008 | Office Equipment & Supplies
Computers & Internet Logo
Alun Cox
k24674
