Question about Dell (E210882) Motherboard
My dell. DHM cannot start up. the power supply is okay. What is the problemm
    Scholar:
  • 105 Answers
Hi.
Remove battery for 30 minutes. If i were you I'd first start by using a multimeter and see the condensor surrounding the Processor area. when they are down, that is what happens to your pc.
If condensors make that beeping sound........ it means u have to replace them. then find someone who knows soldering..
good luck
Posted on Nov 11, 2010
How to remove hard drive from dell dhm computer?
switch off pc
remove sata cable and powercable of hard disk
remove the screws of harddisk
Jul 15, 2014 | Dell Computers & Internet
Re-wiring a DELL dhm
The wires will only connect in the right places. If you haven't been inside before the problem started, then there is nothing to worry about in that respect, cables don't just unplug themselves. There is a very good chance that the power supply itself has failed. They aren't expensive and are easy to fit. Just take a photo of the inside before you remove the old one, it will make it easier to refit the new one.
Sep 21, 2013 | Dell Dimension 2400 PC Desktop
I have a Dell model number says dhm made on 11 13 04 it wwont boot up think it needs a hard drive but before i buy one how do i find out if its a single dual or quad core?
Power on the computer and enter the setup menu by tapping the <F2>
key. It will tell you what type of processor you have. You can then Google search the processor type to see if it's duo or quad.
Feb 04, 2013 | Dell Computers & Internet
Power buten not working on dell dhm
Hello this should be the homepage:
http://www.dell.com/support/drivers/us/en/04/Product/dimension-4700
Here is how to disasemble the pc:
http://support.dell.com/support/edocs/systems/dim4700/sm/parts.htm
If i am wrong, search for the model here:
http://www.dell.com/support/drivers/us/en/04/ProductSelector/Select?rquery=fkey-e-Drivers_PS
By selecting desktop, and model number.
A solid amber light is usually a indication of a failed power supply. The fact that you maybe get the light means the button is working and the problem is else where.
Start by removing all the ram and all plug in cards. Then disconnect all the power inputs to all the drives.
If you still get the solid light then its either the mother board or the supply.
But you can order a new power switch, from a dell dealer.
This is rarely happening, so i suspect the power supply, is malfunctioning.
All ATX power supplys fit`s in the case, so it does not have to be a dell.
Best of luck
Feb 03, 2013 | Dell (E210882) Motherboard
Hi..i have a computer name DELL model: DHM, the serial no: 9QXPX21. my problem is, if I press power button, the motherboard detect lights but doesn't work, i try to change power supply, memory and I...
Make sure your power supply is set for the correct region you are in, if that does not work, check the obvious stuff like your monitor having power and being on and all that. If that doesn't fix it your Motherboard is likely fried and you will have to replace it
May 31, 2011 | Dell Computers & Internet
Getting my dell motherboards to start up.......
you might have fried the mobo when transferring it, and try it with a monitor see if anything comes up on the screen at startup
Oct 08, 2009 | Dell Dimension 2400 PC Desktop
I smelled smoke and turned computer off.
For sure, especially if you smelled smoke. Although it could b one of the cards or even power supply. You'll have to open it up to see for sure.
Feb 21, 2009 | Dell (E210882) Motherboard
Computer will not turn on at all. Dell Dimension 5100 desktop
I would unplug the power supply from the motherboard, wait a little while and then plug it back in.
Try to power everything back up and it should come up.
I am assuming you are getting a light on the motherboard that indicates power is being supplied?
Feb 15, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Sata cable connection
There are no internal connectors for SATA devices in a Dell Dimension 2400, only IDE. If you have SATA drives that you really want to use, I suggest purchasing an external drive case/dock that converts SATA to usb 2.0. On the other hand, if you are referring to the SATA power connector from a new power supply, you don't need to connect this to anything. If I misunderstood your question, please explain it a little more to me.
Jan 05, 2009 | Dell Dimension 2400 PC Desktop
Dell (E210882) Motherboard Logo
270 people viewed this question
Alun Cox
