Question about Microwave Ovens
The scales have an "out
  • rrobbo1 Nov 11, 2010
    The product is Soehnle Type Venezia TR51127. There is no calibration button on the bottom. I do not have the paper work that came with the machine
    Regards
  • rrobbo1 Nov 18, 2010
    The item is a set of Kitchen Scales. (NOT a Microwave Oven)
    Brand Name: Soehnle
    Type: Venezia
    Model: TR51227.
    The scales are coming up with an (OUT2) error.
    How do I fix this problem.
    Ron Robinson
    President:
  • 1,566 Answers
Hello there,
Can you tell the exact model and manufacturer of your Microwave oven?
Let me know so that we can assist you further.
Lyzmorato
Posted on Nov 16, 2010
  • 2,069 Answers
You should recalibrate the scale. your scale brand is not indicated... so, Please follow the recalibration instructions that came with your scale. otherwise, generically, recalibrating you have to set most scales to the calibrate button on the back and put a weight(about 100g) on it to calibrate it.
regards
Posted on Nov 11, 2010
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
Display shows "=SE-", and do nothing
"SE" means = sensor error, try to dry it out with a hair dryer, if not working, you have to replace the sensor
Jul 29, 2012 | Samsung SMH9151 Microwave Oven
Its nan oxo pull out display food scale and the screen reads F when turning it on
My OXO scale has a removable weighing platform. I removed it and wiped off the top of the scale base. When I put the platform back in place and turned the scale on, the display showed the normal numbers and icons. The F was gone.
Apr 07, 2011 | Microwave Ovens
How do you go about "descaleing" the coffee maker? The water does not flow through the coffee capsule very well.
I know that most grocery stores sell a "cleaner" or two next to their coffee filters/coffee makers/kitchen appliances section. These are usually heavily acidic, and will do a great job of cleaining your coffee maker. I've always been wary of acid in my coffee though, so I just use white vinegar. It'll do a decent job of cleaning out the coffee maker. Run a 1:1 mix of water and vinegar through your coffee maker, drain it, then run water through at least twice.
Scaleing/deposits building up in a coffee maker are signs of imperfections in the water. All tap water has it, but if you don't want to worry about it, use bottled or filtred water in your coffee pot. Plus, your coffee will taste better!
Mar 16, 2011 | Microwave Ovens
How to resolve the F6 E0 error code on the built-in Kitchenaid microwave oven? The unit was brand new and installed 2 and half years ago in my new house. One website mentions the description for this...
"F6" on a Whirlpool microwave means you have a shorted cook relay on your control board, which I can repair. Details here.
FixYa doesn't notify me when there's a response, so if you have other questions, please contact me directly.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 26, 2017 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My display screen is reading de-scale and i don't know how to fix it it is for a kuerig coffee maker
It needs de scaling by the description.
Consult your manual and use the prescribed chemicals to carry out the operation.
Hope that helps.
Jan 22, 2011 | Microwave Ovens
New CR2032 battery last about 1 week before the scales say that the battery is dead. Have tried lots of different battery brands and the same happens with all. We only use the scales a couple of times a...
Sounds like the scales have developed a leak across the battery and is draining the power. New scales maybe the best option but before that, have a look to see if there is any spilliage around the pcboard and/or battery terminals.
Jan 03, 2011 | Microwave Ovens
My GE microwave JVM1740DM1WW no longer is responsive to the keypad. Lights, fan, power etc. don't turn on. Just beeps and gives a "disply shortage" error message along with a "might need...
there is no easy fix to this units current problem it will need to be looked at by a service tech as the fault is an internal circuit shortout and needs to have the faulty circuit found and then replaced using expensive testing units
sorry
merry christmas
Dec 21, 2010 | GE Profile Spacemaker Over-the-Range...
I have a Microwave GE make, Model No. JES1238WH001, made in Malaysia, in July 2003. On staring this, in the panel, "PF" appears for few seconds and then "F3" appears and no further...
Error code F3 on many models of microwave oven means a problem with the touch panel, (tact switches).
Replace the switch panel to fix the fault. Spares can be aquired through your GE dealer. Visit GE's web site for a list of dealers and spare parts suppliers.
Hope this helps.
Nov 27, 2010 | GE Microwave Ovens
When i try to weigh something on it it displays 'our2'. And does not work
OUR2 is probably OutZ or Out2, means you have to recalibrate your scale. Refer to your scales manual for instructions on recalibrating, usually you have to turn on your scale, press CAL button, wait till it displays for example 100g, depending on how much your scale can weight, then put that weight, for example 100g on your scale (you can use coins if you don,t have anything else, though be precise as coins can weigh more or less,informationon coins weight can be found in your country national bank site. After you put the weight, it should display OK or PASS, if it's FAIL or the scale turns itself off, it's either broken or the weight is not correct
May 16, 2010 | Microwave Ovens
Microwave Ovens Logo
115 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
