Question about Zonet ZFS3018P 8-Port Ethernet Switch
How can i open ports for this? it seems to be blocking ports 20 and 21 which i need open for a game i was wanting to play. i opened the ports on our router(our internet is ran from the modem into this box into the router), but its still blocking the game if i try to play it through the router. but if i connect straight from the modem to my computer it works fine. so the only answer should be that this zonet box is blocking it, is there any way to open those ports?
    Sergeant:
  • 187 Answers
Go to this website. www.portforward.com very helpful site
Posted on Jun 12, 2017
stwill2326
  • 77 Answers
SOURCE: Can't see both computers in my network places with zonet router
Be certain that you turn off your windows firewall(control panel,systems,firewall).
I would prefer to connect both computers to a switch or hub. Some routers are kind of strange when it comes to sharing files and folders.
Posted on May 29, 2009
gcsltd
  • 239 Answers
SOURCE: Zonet 802.11n Wireless Brodband Router ZSR4134WE
may be u need to go on its ip address & disable mac address!
Posted on Feb 05, 2010
  • 137 Answers
SOURCE: Not getting ethernet connection from the router to the modem
Please check your router's power is working or not.
if your router's power adaptor is OK the possibilty is your router's motherboard is faulty.
need to go service center.
Posted on Mar 30, 2010
Pulkit558
  • 472 Answers
SOURCE: which port do i plug in the ethernet cord from the
It is basically a switch so if you are planning to connect more than one computer using this switch than you need to connect a router in between modem and switch
modem -- > router -- > switch -- > computer
from your modem an ethernet cable will connect into an internet port on the router and than from LAN port of a router cable will connect into any port on your switch.
Let me know in case if you need more help :)
Posted on May 19, 2010
Sirach
  • 59 Answers
SOURCE: Can you help me connect my Zonet Wireless AP Router ZSR2104WE now that I have purchased a new modem (Motorola DSL Modem 3360)?
You must hook these particular items up in a specific sequence. First power down both the modem and the router, only connect the modem to the isp until all appropriate lights on on. Next plug cat 5 to router where it is labeled internet or wan if neither label then to #1. until alights come up on router. Hope this helps.
Posted on Sep 08, 2012
HOW DO WE open the port of this modem
Outgoing traffic isn't blocked normally on routers unless someone specifically blocks them in the configuration menu.
Dec 02, 2012 | Computers & Internet
Can t get on line on my ps3
The PS3 is plug n play and if your router is as well then it will configure the firewall automagically. However, often the older routers just don't play well together. You need to open up ports manually and configure the router and firewall separately for each game you want to play. Each game has specific TCP and UDP ports that need to be opened up to allow access. Its not a trivial exercise. You need to statically assign an I{P address to the PS3 and direct traffic from the router to the PS3 IP address for those games you want through. Each game has the details on which ports to open on the website or in the instructions. Lots of luck
Jan 13, 2011 | NetGear WGR614 Wireless Router
I am unable to play online games because they are blocked
There are lots of games that have been kept blocked by the administrator of some organizations.
I know one of the best-known platforms which is Unblocked Games that would surely help you play a wide range of popular blocked games.
Here, you can access all types of blocked games and can play them easily at any of the restricted areas.
Nov 09, 2009 | Computers & Internet
Siemens Speedstream 4100: Enabling ports for Xbox live play
Do you have a router connected between modem and console? The speedstream itself has no port blocking. if it is a straight line between modem and console then all ports are already open, but chances are you have a router between the too, especially if you have other devices connected(computers and the like). If that is the case, then it is the router in which you need to open the ports. If you do have one, post make and model plus version number if applicable.
Jul 09, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Change NAT from strict to open
You need to do port forwarding on your router. First, you must setup a static IP address on your XBOX. Then You must open these ports on your router setup page using Port Forwarding feature. 80 TCP and UDP, 53 TCP and UDP, 3074 TCP and UDP.
Jun 01, 2009 | Zyxel P660HW-D1 Router
It works fine untail I want to play Asherons Call a MS game, firewall has locked me out, how do I shut off the firewall. tyvm Ken
What you want to do is "open ports" in your firewall. This is simple if you have admin access to your router. Find the section for "port forwarding" and add ports that your game require. Typically, there is a TCP port and a UDP port. The UDP is for broadcasting type messages to/from your fellow gamers. The TCP port is usually for the game server. Check with your game instructions -- or you can probably get the answer with a google search string of "game ports Asherons Call" and I would bet it will give you exactly the settings for your router.
Here ya go (I did the google search). It appears that it only requres the UDP port. I would open all of these unless you find out more detail that you can close some ports (never leave a port open that you don't know or don't need -- it is a hackers door to your computer).
9000 UDP Asheron's Call game
9010 UDP Asheron's Call game 9011 UDP Asheron's Call game 9012 UDP Asheron's Call game 9013 UDP Asheron's Call game
Good luck.
Apr 27, 2009 | Computers & Internet
Change NAT to open
First make sure your security type on the router is WEP-Personal. You may need to get the port range for that game or manufacturer. Then enter them in to the gaming tab. This will keep ports open all the time. NAT 2 is acceptable but you want NAT 1. Some internet connections cannot get NAT1.reply if you need further assistance
Mar 13, 2009 | Dynex DX-E401 Router
My NAT setting is to strict to play xbox live.
You'll just need to open the port number for the specific game that doesn't play. Click the link below for the port number of your game. Use port forwarding feature of the zyxel when opening the game port.
Click HERE
Nov 22, 2008 | Zyxel Prestige 660HW Wireless Router...
Playing games online.
there are two reasons for this issue,
1. open the desired ports of the router
2. the firewall of the router is blocking it.
Oct 24, 2007 | Belkin (F5D7230-4) Router (587009)
Zonet ZFS3018P 8-Port Ethernet Switch Logo
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
