Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
Western digital 250 external - not opening - Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
    Sniper:
  • 64 Answers
You can try some data recovery software. You can see
http://www.asoftech.com/adr/
It tells the steps how to perform data recovery.
If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
Posted on Dec 30, 2012
  • 10 Answers
Well in this case, the Western Digital data recovery tool may worth taking a try first of all.
If it doesn't help, then take the device for data recovery services if the data is really important to you.
Remember - DO keep the deivice safe from data overritten or physical damage. Regards.
Posted on Sep 17, 2011
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
5 Suggested Answers
SOURCE: how to open the case of a my book wd 320gb
test
Posted on Jan 01, 2008
cheap to fix
  • 404 Answers
SOURCE: western digital 250gb my book external makes a clicking noise
100% faulty, 100% non repairable
Posted on Mar 08, 2009
odiebugs
  • 949 Answers
SOURCE: Western Digital external drive not responding
Unplug it and plug it in to a different USB port, shut down the computer
and while the computer is off, turn on the drive.
Then restart windows with the drive on, now after windows starts, wait about 5-10 minutes, if the drive does not start to blink, (the light),
then go to there website and get there hard drive Diagnostic disk,
you can download it.
This is the download page, read the instructions on how to run the tester on the drive.
http://support.wdc.com/product/download.asp?groupid=101&sid=3&lang=en
Posted on Feb 15, 2010
SOURCE: Cannot Read External Western Digital Mybook 500GB Drive
I have ".Window 7." Sometime I see a icon and it shows the drive size and can't read and my work. Yes, I do save my work on my hard drive, but I also want to save it on my external drive. . I even reboot.
Posted on Jan 05, 2011
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
I lost the software of my westren digital 250 g
Simple, it's a free download from Western Digital I'll post the link below for you. Once there choose your type and size of drive then download it and install it.
http://support.wdc.com/product/download.asp?wdc_lang=en
If this link doesn't work or if you run into further issues, let me know.
Chris
Sep 21, 2010 | Western Digital 250GB MyBook External USB...
My computer is not recognizing my Western Digital passport elite what do I do?
Have to check it in the Device Manager that the new device have been detected or not. It may happen that when the external HDD connects to the computer for the first time computer cannot detect it as it is not properly formatted in proper file-system. Open Computer Management and click on Disk Management and format the device correctly to operate.
Jun 21, 2010 | Western Digital WD Passport 250GB Portable...
Xp not recognizing my 250gb WD passport
The Western Digital My Passport line, besides the Essential Series, is originally formated for a Mac (in the HFS+ format) and as such cannot be read by Windows PCs. You can either get a program to read the External such as Macdrive, or format it to NTFS or FAT32; formats that are readable by Windows. I would recommend formatting it to NTFS, because you can only transfer up to 4 Gigabyte files to FAT32, while NTFS is nearly limitless.
May 03, 2010 | Western Digital 250GB ELEMENTS EXTERNAL...
Western digital passport i/o device error
90% of the time this is a power problem. The USB port on the computer can not supply enough watts. Use an external USB hub that has a 5V power supply.
Oct 14, 2009 | Western Digital 250GB MyBook External USB...
My computer recognizes the western digital but i cant view my files.
just update the chipset drivers of ur system form the vendors site,,, tat ll solve the issue...
Jun 02, 2009 | Western Digital 250GB MyBook External USB...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
658 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
