Question about Microwave Ovens
The gas stove fire burns with black soot and is only 1 month old
    Brigadier General:
  • 8,909 Answers
Gas should not burn with soot, if it does it is dangerous as poisonus fumes will be produced as the air/fuel mix is wrong.
Call a qualified gas engineer to check out the installation and make it safe.
Posted on Nov 11, 2010
What type of gas are you using? If it is a natural gas stove and you are using butane, it will do that.
Posted on Dec 08, 2010
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
Metallic smell in oven compartment
The smell you are describing is typical of a defective magnetron, return item to the store for replacement.
Aug 30, 2012 | RCA RMW953 0.9-Cubic Feet Microwave Oven...
All the burners are turned off on my gas stove, but one keeps sparking uncontrollably...its been all night now. I have lifted burner cap off and can see the spark but have no idea how to stop it. Our...
This is dangerous.
You should be able to stop it by unplugging the stove. The automatic spark requires electricity to work.
Unplug it and leave a comment with the make and model and I will assist you in finding a replacement.
Mar 31, 2011 | Microwave Ovens
Small gas leak smelled inside house from GE Adora (just 2 yrs old). Have moved stove and have put soapy water with paint brush on every connection including regulator...don't see any leak evidence...any...
You may have to use dish soap straight, do not use the brush. I use an old spray bottle and dish soap straight, not watered down, to find my leaks. Gas is a very low psi. Soapy water will not bubble up. It can and will just be pushed out of the way. Do not forget any other gas appliances in the house, hot water heater, stove, any thing that uses gas. Please check all. Recheck your stove and even any connections inside, on/off valve etc. Hope this helps Fixya up.
Dec 13, 2010 | Microwave Ovens
On Dacor cook-top. LP gas, what is recommended pressure (inches of water) in manifold? Have one burner of 6 that blackens cookware.
For LP you should be right around 10" WC....to high of pressure will give too much gas and burn rich... and make the soot that makes the cookware black...
heatman101
Sep 14, 2010 | Dacor Microwave Ovens
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
My sharp microwave is under 6 months old. I was
It may be a shorted high voltage diode.
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Feb 28, 2009 | Sharp R-1610 Microwave Oven
I placed yam to microwave - left room and came back to see yam on fire (black as coal) and now my microwave control panel does not work - the yam was on fire before I put it out. filled the house with...
my son did the same with a conker /horsechestnut micowave full of soot kitchen full of smoke microwave was no more / the soot got in to everything just had to replace it
Jan 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Jan 08, 2009 | Microwave Ovens
Microwave Ovens Logo
181 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
