Question about Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor
Yesterday when i switched on my PC...some spark comes near cpu fan...then my ups is working properly and other accessories are working properly, but cpu alone not starting....there is no sound in cpu......please help me
    Genius:
  • 1,672 Answers
Take a look closely at ur mobo, tell us where the spark came from? look also at the underside that may have touch the casing, check also the power connection from the PSU(Power Supply Unit) to the board connector!
Posted on Nov 11, 2010
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
Constant beeps
if there is beeps on it then its probably your ram has come loose or your cpu fan try to find installing RAM on PC on youtube there should be a video there and do the same for cpu fan ....hope this helps if you like you can google your pc's manafacturer error beeps like if its 2 short then one long it will let you know exactly is in error....bonnell
Apr 22, 2012 | Gigabyte Ga-g31m-s2l Motherboard Intel G31...
Samsung r40 shuts down after running for about 20 mins, was told cooling fan was not working so stripped down laptop cleaned fan (was full of dust) reasemmbled and ran all day yesterday, switched on this...
The CPU fan may be faulty and not spinning freely.
If you had removed the heatsink off the CPU did you place new thermal grease/paste on the CPU before installing the heatsink back on the CPU?
Jun 02, 2011 | Samsung R40-K009 R40-K00A R40-K00D"...
Usb hub powering up mt pc fans??
the switching system of your mainboard is not working properly try to change the resistor and capasitor near the control panel. good luck
Apr 23, 2010 | Computers & Internet
Toshiba Satellite A75-S231 overheating pls advise me
You need to open the Notebook and clean it with an Air-blower mainly near the CPU (Processor) area.
You need to check whether the CPU cooling fan is working properly or not, try cleaning it too, If the problem still persists replace the CPU cooling fan.
That's it.
Feb 03, 2010 | Toshiba Satellite A75-S231 Notebook
Trying to reinstall with my cds but during the process the pc just shuts itself down unexpectedly with no way to switch it on without taking the plug out.
This may be due to over heating cause by CPU cooler fan not working properly or dust /dirt contamination in the CPU heat sink.
OPen your Laptop and Clean with an air blower mainly near the CPU.and it will work fine.
Dec 20, 2009 | Acer Aspire 5100 Notebook
Acer power fg does not start up for a long time. if it does start then it can just shut down with no warning and then will not start up again. fan is working when the pc is running
Your heat sink is not properly working. this is because when cpu heat crosses threshold it shutdowns it self. it will not start again until it cools.
Try to remove the heat sink and then clean the base of heat sink which sits on cpu and apply the cpu thermal interface material. this is obtained in any computer accessories shop. shouldn't cost much. if available go for Cooler Master Cpu interface material.
Apr 22, 2009 | Acer Power FG (APFGUP5161) PC Desktop
Error on startup
can u check ur motherboard where u have connected the processor fan. mostly it will be near the processor slot. so see if u have plugged it somewhere else
Dec 01, 2008 | HP (D7580-60003) Motherboard
Buzzer sound from intel d101ggc motherboard
Check the fans in your pc, it sounds like at least one of them isent working properly and your pc gets overheated. When a pc going to warm it gets really slow and hangs.
My guess is that the CPU-fan dosent work properly and your CPU gets overheated, but check all the fans to be sure. The CPU fan runs cantantly, check so it dosent stop now and then.
Good luck
Nov 21, 2008 | Intel D101GGC Motherboard
Pc switches off on its own
sounds like a power supply problem, or an overheating problem. Is the cpu case expelling hot air? open the case verify that is has at least 1 working cpu fan. It should also have at least 1 other fan inside the chassis.
Aug 29, 2007 | Compaq Armada M700 Notebook
Intel (RK80532PG0881M) Pentium 4, 3 GHz Processor Logo
51 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
