Question about Canon LASER SHOT LBP-2900 Printer
Fixing unit error error code e0000000 - Canon LASER SHOT LBP-2900 Printer
    Genius:
  • 1,570 Answers
Uninstall and reinstall the printer software
Posted on Nov 11, 2010
Fixing unit error 00000
Posted on May 06, 2013
3 Suggested Answers
evan89
  • 356 Answers
SOURCE: how to fix error code E0000000 in canon printer
Un-Install and Re-Install the Printers Software.
Positive Feedback ALWAYS Appreciated :)
Posted on Mar 06, 2011
F Victor man
  • 821 Answers
SOURCE: Fixing unit error error code
The only cure is to replace the fixing unit (fuser).
Posted on Jun 05, 2011
Canon lbp 3300 error fixing ERROR CODE E0000000
This error is mainly due to components related to drying of the drying assembly, the control circuit drying from the main source.
Xe n?ng nh?t b?n
Oct 28, 2013 | Canon LASER SHOT LBP 3300 Printer
E0000000-0000 coad
http://www.scribd.com/doc/56387774/iR-3300-Code-List#scribd check out this site gives you all the error codes for this model
Sep 23, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Jun 05, 2011 | Canon LASER SHOT LBP-2900 Printer
How to fix error code E0000000 in canon printer 2900
Mar 06, 2011 | Canon LASER SHOT LBP-2900 Printer
I HAVE IR 4570 WITH PROBLEM E0000000-0001
E0000-001 means that the fixing unit is at the wrong temperture. Did you have a power problem recently? If so, you mat be able to rest the code. You have to get into service mode > press "*" then "2&8" at the same time then "*". the display will change > press "copier" then "funcation" then "clr" then "err" then pres the "OK" in the bottom right corner and then turn then main power off then back on. If the code can be cleared, you are back to work. If not you will have to have the Upper fixing unit or fuser unit replaced... Good Luck
Jul 03, 2010 | Office Equipment & Supplies
Error code E000000-0001
Hello nelco9,I can help you clear the code easy enough. But there is a strong probability the code will come back almost immedietly.Copiers use high heat and pressure to bond the toner to the paper.It is of course critical to accurately monitor this high temp as to insure against fire.The code E0000000-001 means that for any number of reasons the copier did not or could not reliably monitor this temp.Now, something as simple as a momentary variation in the power to the plug the device is plugged into can cause this code as the plug voltage and/or frequency is sufficient to interfere with the copier's ability to track the temp, so lets hope for the best.Trust me there are so many fail safes involved in this process that the copier will properly shut down if the problem is serious.Ok,locate the'ADDITIONAL FUNCTIONS" button on the op panel.It is just to the right of the 9 key pad.Press it, let go, then the numbers 2&8 simaltaneously,let go, then ADDITIONAL FUNCTIONS again.You will see a new screen.Press "copier". Tabs appear at the top.Press the "function" button.New screen again.Press "clear".New screen.Press "ERR" .Press "OK" in the lower right corner.Now if you TRULY know where the main power switch is (right rear of copier about halfway down) then power the copier off.If in doubt simply unplug the copier.When you turn it back on the copier will attemt to start up as normal.If it does then congrats !!.If it fails you will need a new fusing unit which can run as high as $800. I truly hope I have helped you.Take care.
May 02, 2010 | Canon imageRUNNER 3030 Black and White...
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
DC controller PCB is faulty.
Caution To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
4. Main power supply PCB, DC controller PCB
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Canon LASER SHOT LBP-2900 Printer Logo
1,608 people viewed this question
old marine
old marine
