I HAVE SUPER CLX 5.0 KG MODEL OF WHIRLPOOL WASHING MACHINE,IT'S SPIN TUBE IS ROTAING WITHOUT LOAD BUT NOT ON LOAD PLEASE HELP
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 41 Answers
SOURCE: Washing machine rubber door seal replacement
Go to www.Searspartsdirect.com You should be able to find an exploded view and parts list
Posted on Feb 29, 2008
  • 103 Answers
SOURCE: CMD 126 candy washing machine struggles to spin even at low load
hi your balt is sliping or your ford geers are ded
Posted on Apr 05, 2009
  • 351 Answers
SOURCE: whirlpool super capacity washer spin cycle stop working
Sounds like you need a new lid switch. Click HERE for prices.
Posted on Apr 19, 2009
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
I have a wfs1071aw 7.5 kg whirlpool washing machine and it takes water and drains but wont spin.Help please
Possibly your belt is slipping or needs to be replaced. If you're handy, you may want to pop open the top or back and check it out dialing through the cycles to trigger the spin cycle.
Mar 10, 2018 | Whirlpool Washing Machines
Whirlpool 360 bloom wash 8 kg top loading full automatically washing machine. Model 13712 is a not spin
check for unbalance activation or lid lock malfunction
if you can get past the spin cycle then it will be a problem program board
Dec 16, 2015 | Whirlpool Washing Machines
Won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
Hi, I have SW1ASP Samsung 6 kg washing machine. Its washing but not spinning. its try to spin and motor try to pushing to spin but it spin slight and stop. When i jiggle the machine while it try to spin...
1) may be your spinning cloth load over.
2) Check inside the container (space of wall & spin tube) cloth may be inside.
3) Door stopper (Brake) position not correct.
Actually the spin motor starting slowly first.
Mar 26, 2011 | Washing Machines
Hi i want to know that a waight of 6 kg washing maching is a small one for cloths or it is ok . should i go for more than 6 kg. for 4-5 persons family. thanks.i just choose a whirlpool compact model of...
Your question is not easy to answer. An average washing machine is 8 kg. The smaller 6 kg will use less water and detergent, but you will be limited to 4 or 5 pair of jeans at one time...unless your children are small. A front loading machine may be a better choice for you. It can do very large loads, 12 kg, and still use less water and detergent than most top loaders, but be prepared to pay three times the price of a top loader.
Sep 20, 2010 | Whirlpool Washing Machines
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
Kenmore Super Capacity Washing Machine
If your washer is the one you have chosen a Whirlpool built kenmore unit than your washer doesnt have any bearing that fail, It could be the spin tube mounting block becoming stripped ( most common) or a clutch or brakes not releasing issue (not likely). Also make sure the machine is agitating it may just be filling with water and draining and making motor noises. In this case the motor coupling has broken. both the block and coupling are inexpensive parts and easy to install.
Jan 14, 2008 | Kenmore 3.2 cu. ft. Top Load Washer
Whirlpool top load washer 7.5 kg
very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 24, 2007 | Whirlpool LSR9434PT Top Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
