Question about ASUS A8N-SLI Premium Motherboard
Will not recognize Ram
I have 4x512 sticks of corsair value select. In pairs of 2, they both work fine and the BIOS recognizes that there is 1024 ram available. However, when I use all 4 the BIOS recognizes only 512 megs are available instead of 2gigs.
  • imondeau Jun 17, 2008
    ASUS A8N-SLI Premium MB
    Ram Sets -
    1. CORSAIR ValueSelect 512MB 184-Pin DDR SDRAM DDR 400 (PC 3200) x 2
    2. Edge (I think) 512MB, DDR, DIMM x 2 - I could not find the precise information on this kit.
    For clarity, both sets work independent of each other totally 1gig recognized by BIOS. However together (A1B1, A2B2 OR A1B1, A2B2) they only recognize 512mb of ram.
    Is the solution that I need to buy another set of exactly the same (i.e. corsair value select?) or the exact same type PC3200/400?
    Side note: This is only an issue because my corsair high quality ram died and is being replaced, but is taking forever.
  • duy8910 Dec 29, 2008
    i have a problem with my ram. My computer originally came with 512mb of ram (DDR2 SDRAM). After having it for two years, i replaced that 512 ram with a 1Gig. Not long after that, i bought another 1 gig stick because my PC can support 2 gigs of ram. The problem is, my Pc wouldnt recognised both of the ram, it should be showing 2 Gigs of Ram but instead, it showed only 1gig. 've tried taking out one ram and out each of them in different slot, my computer can recognised them but when i pt them both together, my computer would not recognised, i've tried to put my 1 gig ram with my old 512 ram and my computer would recognised them instantly, but when i put both of my 1 gig ram sticks together, it only shows 1 gig,.I've went into the set up and it shows one slot is empty but i had both of them properly installed. Can sumone help me out here, i'll appreciate it...both of my 1 gig ram sticks are at same speed, DDR2 800. One is kingstona nd the other is apacer.
    President:
  • 2,351 Answers
Insert a pair of memory so you again can see a total memory of 1024GB. Check the slots you have them inserted in. It should be DIMM A-1 & B-1. (Correct)? Remove both & insert the second pair. Use A-1 & B-1 again. Check total memory reported by bios. If you see anything less than 1024GB, that set of memory has an issue. Continue to leave in that set of memory. Go to this link & download memtest86 to a floppy disk & test the memory. You'll find the download section just under the three screen shots.
http://www.memtest.org/
Each set of dimm's should be placed like so. One matched pair in dimm A-1 & B-1. Second set insert into dimm A-2 & B-2. The bios should see the total as 2GB. Run memtest only while using one set of matched 2x512 memory at a time. If there is a problem with the memory memtest86 will find it.
Though the information should fix you're issue, (or catch some bad memory).
It wouldn't hurt to check if a bios upgrade will help also.
Click on this link & check you're bios version against Asus updates. Please only update if you are sure the update will help.
http://support.asus.com/download/download.aspx?modelname=A8N-SLI%20Premium&SLanguage=en-us
Good Luck!
Mike
Posted on Jun 17, 2008
  • Mike Peluso
    Mike Peluso Jun 17, 2008
    Hi imondeau, its always suggested to use the same brand & type so all you're memory can function at the correct seed. I would say the Edge seems to be the trouble. This will clear up when you put in the replaced corsair.
Running a 1 gig stick and a 512mb stick, system only shows 896mb, apparently not recognizing all of the ram installed?
I assume that you've booted the computer with _ONLY_ the 512MB stick installed, and that the computer recognized it (reporting either 512MB or 384MB), i.e., the 512MB RAM is not "defective".
Hmm. 1024 minus 896 is 128.
So, the "integrated-into-the-motherboard" video-card is "stealing" 128MB of your RAM, to be used strictly for "video" purposes, leaving 896MB for Windows to use.
Now, about the "missing" 512MB of RAM.
1. If you have four slots for RAM, and they are physically arranged into two pairs of two slots, rather than four equally-spaced slots, your motherboard is capable of "dual-channel" mode. But, since your two sticks of RAM are not "matched" (size, speed), you _MUST_ insert both sticks into _ADJACENT_ slots (not slots 1/3, nor slots 2/4), in order to run your RAM in "single-channel" mode.
2. If you have two slots for RAM, interchange the two sticks, to see if that makes a difference.
Aug 19, 2010 | eMachines W3507 PC Desktop
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
RESETTING BIOs to recognize my RAM. I HAVE 512 BUT SYSTEM IS ONLY RECOGNIZING 256
if you load bios defaults does this help . . . clean both the dims and sims and blow out the ram slots . . . what kind of ram are you using ( are they an origanal pair eg your not mixing two differant types of ram as this can cause this problem as they can run and differant speeds)
Sep 05, 2009 | Dell Dimension 4700 PC Desktop
Ram assurance
The schematic layout of the P5VDC-MX on the user manual shows that there are 4 DIMM banks, set as 2 X 2 rows, 2 DDR2 and 2 DDR.
The user manual explicity states:
I am running different frequency modules without any problems. With the info above provided by ASUS, it may be possible that a fix could be available with a BIOS update. Otherwise, you can opt to use a lower capacity RAM along with your 1GB Corsair.
Hope this helps.
Jun 24, 2009 | ASUS P5VDC-MX Motherboard
My Acer Lap-top Aspire 5570Z with 80GB HDD & 512 MB DDR2 is very very slow. Can its DDR2 be upgraded to 2 GB.
what the max ram is for this laptop? I bought 2x2GB dual channel ram for it and windows vista home premium (32bit) only recognizes upto 2GB, but CPU-Z recognizes more than that.
Mar 17, 2009 | Acer Computers & Internet
2G Memory Upgrade
I had similar problem with CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
If this is your RAM:
Corsair 1024MB Value Select PC2-4200 (533MHz) DDR2 RAM, 128Mx64non-ECC, 240-pin DIMM, Unbuffered, CL4, Lifetime warranty (VS1GB533D2) Then it is high density. You need low density to work, look for one ending with an 8, not 64.
Feb 26, 2009 | PC Chips P23G Motherboard
Can't get both 1 GB PC4200 ram cards to work!
hello there do you know if this is dram or sram athat u had and are trying to install
Feb 21, 2009 | E-Machines T5212 PC Desktop
4GB memory not being recognized
To recognize more than 3.5GB RAM you must use a 64 bit operating system
ordinary 32 bit O/S only recognize max of 3.25 to 3.5GB ram
Oct 31, 2008 | ASUS A8N-SLI Premium Motherboard
Ram install
1. bad memory
2. the motherboard doesnt support single sided and dual at the same time.
3. bios needs update
4. wrong slots for dualchannel?
Apr 05, 2008 | Intel Motherboard
Ram upgrade
In order to see how many MHz is your desktop, please right click on your "My computer" icon and select "Properties" from the menu.
It will open the system properties window. select the tab "general" and you will see how many MHz is your desktop.
If you have found this solution helpful please rate it as "solved", otherwise please ask here again.
Thank you :)
Oct 12, 2007 | Computers & Internet
ASUS A8N-SLI Premium Motherboard Logo
370 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
