Question about Hotpoint DY46 Style Line Stainless Steel Electric Double Oven
The outer glass on my hotpoint oven door has shattered do i need special replacement glass
  • Hotpoint Master
  • 3,463 Answers
You must replace it with the glass as supplied by the manufacturer, as it is is special heat tempered glass.
Posted on Nov 11, 2010
Oven door glass shattered
Replacement is likely not to be easy or cheap, but necessary.
Jan 10, 2014 | Tecnik Ovens
The outer oven door glass shattered suddenly how do I change it?
I depends on how old your oven is. If you're lucky you may be able to get a replacement glass. If not take some measurements and see a glass supplier. You will need a piece of tempered glass.
Feb 07, 2011 | Ovens
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
The glass has shattered in my electrolux eou6330x door
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
Dec 30, 2008 | Tecnik TKC8522 Electric Double Oven
I need a replacement door for a built in Baumatic 720 series oven
I have exactly the same problem and my bottom glass panel exploded. My friends did the same. You can take the inside glass panel out via the two screws and clean the inside of the outer glass once removed. Id replace all the rubber seals to as they perish, particularly the one that clips onto the oven itself that meets the door.
Nov 21, 2008 | Ovens
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
I need to replace the outer glass on my Advantium oven
contact GE; they should have replacement glass in stock.
Apr 28, 2008 | GE ZSC2001FSS Advantium Electric Single...
Hotpoint DY46 Style Line Stainless Steel Electric Double Oven Logo
947 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
Colin Stickland
Colin Stickland
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
