Question about HP Photosmart 2610 All-In-One InkJet Printer
Job stuck in cue, won't delete. printer won't print
I deleted all the jobs in cue, all deleted except one, it says it's been "deleting" the file in question (for the last 12 hours).
I've reset the computer, the printer, and pulled the power to the printer, all to no avail.
I have an HP 2610. (I'm running on PC)
Thanks, Jeff
  • jgolddad Jun 17, 2008
    thanks...HP has a website that you can download a diagnostic program which will identify and then fix the problem. It worked perfectly so I am up and running again.
    Thanks
  • acerflo Apr 09, 2009
    I have an officejet 5510v al l in one it is stuck in deleating but dose not deleat. Can someone help me?
  • 54 Answers
Have you tried restarting the print spooler?
What exactly is the version of you PC? WINXP, 2000, Vista?
If you are running on a Windows 2000 or Windows XP
1. You just need to click on START > CONTROL PANEL > Administrative Tools then Services
2. Inside Services window scroll down and look for print spooler
3. Click on stop the service and then after at least 5 seconds start the service
4. Restart your computer and check again if the print job is still there.
Posted on Jun 17, 2008
    Problem Solver:
  • 12 Answers
Awesome worked perfectly for me too... Pretty simple to do...
If you're in vista its easier to find under classic view though instead of control panel home.
Posted on Sep 16, 2009
Worked great thanks binary code.
Posted on Oct 31, 2008
My HP printer stopped working and is stuck in the cue
Navigate to Printers under the control panel and try deleting all current print jobs. Then also make sure to click on Printer> and see that the Work Offline option is NOT checked. Good luck
May 27, 2012 | HEWLETT-PACKARD Computers & Internet
PRINTER WILL NOT PRINT THERE IS A JOB THAT WON'T CLEAR. I TRIED DELETING THE JOB AND ALL IT SHOWS IS THE JOB DELETING AND THATS WHERE IT'S STUCK
To clear the print queue from stuck print jobs, try this approach instead:
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\ folder. You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the print spooler service)
4. Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Oct 02, 2011 | Lexmark X2500 All-In-One Printer
I have a Lexmark S504 wireless multifunction printer. I can print a test page but a can't print anything from any application. The Windows print page window comes up and if you click OK it appears to...
It could be a printer driver issue. Please follow the steps below to fix the problem.
First, clear the print queue from any stuck print jobs. You can do the steps mention - going to Services and stop the print spooler, delete the files in the spooler folder and then restart the service.
Second, delete the existing Lexmark Interpret S405 printer driver. On your computer, go to Start menu > Programs > Lexmark > Uninstall. After the uninstall process, reboot your pc when prompted.
Third, visit the Lexmark website to download and reinstall the Lexmark Interpret S405 printer driver. Select the version of your Windows operating system. Download and execute the file. Follow the instructions on your computer screen.
After the reinstall process is successful, try to print again to verify that the problem is fixed.
Sep 07, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Trying to cancel a print job after it's already scrolled to printer?
Sometimes this is a right royal pain int he **** to actually do. You need to cancel from the pc that send the print job, then you might have to turn the printer off and restart it a few times. Usually just once if you leave it off for a half minute does the trick. The idea is to clear the memory or buffer.
If it will not clear on the pc then it gets annoying as you won't be able to print until it is out of the way. Cancle the job then delete it from the cue. Then try a reboot or two. If nothing else you can remove the printer from the printer menu, then reboot and add it back in. That force the OS to clear out the spooler and so on. You used to have to hunt down the print job file and manually delete it.
Sep 02, 2011 | OKI C5500n Printer
Unable to delete/cancel print job while it runs-lbp 2900
Hi.
To temporarily delete the print jobs in the cue do the following:
Disconnect printer USB.
Restart printer.
Restart computer.
Access printer cue with printer not connected (get there from control panel)
Clear printer cue.
Connect the printer back.
If the printer cue gets stuck too often, and always with different documents, try reinstalling the printer software.
Regards.
Ginko.
May 26, 2010 | Canon LASER SHOT LBP-2900 Printer
Printer 966. Deleting Print Job stuck in Que
Sounds like a problem with the spooler.
Try to bypass the spooler when printing by right clicking on your printer and select "properties"
Select the "advanced" tab and select "print directly to the printer".
Hoepfully this should take care of it.
Mar 25, 2010 | Dell 966 All-In-One InkJet Printer
My last print job gets stuck deleting in the queue!
Go to C:\Windows\System32\spool\PRINTERS on your PC and you will see two files listed fior each of the outstanding print jobs. These will have the file extensions .SHD and .SPL
You need to delete both of these files then power off and power on your printer to be able to continue printing.
Feb 15, 2009 | Lexmark X5470 All-In-One InkJet Printer
Unable to delete print job
Switch off or unplug the printer and then delete it. make sure you have administration rights to delete print cue if your under active directory.
Dec 12, 2007 | Office Equipment & Supplies
Deleting - Printed
I've also had this problem with an HP LaserJet 4650dtn printer. I've solved this by: - Stop the "Print Spooler" service. - Delete all the existing print spool files. (Stored in "C:\WINDOWS\system32\spool\PRINTERS" by default). - Start the "Print Spooler" service. - Right-click the printer's icon in the Printers and Faxes folder and choose Properties. - Click the Advanced tab. - Click the Print Processor... button. - Make a note of the existing "Print processor" selection on the left (in case you need to revert it.). Then change it to "WinPrint". Click OK. - Click OK on the printer's properties window. - Try sending a print job to see whether it persists in the print queue.
May 07, 2007 | Lexmark X1150 All-In-One InkJet Printer
HP Photosmart 2610 All-In-One InkJet Printer Logo
3,636 people viewed this question
Seeker5211
Seeker5211
