Question about Garmin zumo 550 GPS Receiver
GARMIN ZUMO 550
I flattened the battery - and recharged it - no good (cannot find any satellite signal when outside).
I removed and refitted the battery - twice - for 1/4 hour and 1/2 hour respectively - still no good.
Short of going back to my old Streetpilot III (which NEVER fails to work despite bumping about on the floor of my car for well over a thousand miles) I'd be grateful if you could suggest what I should try next. Best Wishes, PN.
    Scholar:
  • 174 Answers
Have you checked the firmware updates through webupdater (on the garmin site)
Have you ever erased all user settings? To do this press and hold the right bottom of the touch screen while the zumo is powwered of, then press power on until the screen pops up, select yes to erase all user settings, it will now startup clean and request you to set the GPS up. Press and hold the clock will pop up the system menu. Any SD cards installed should be removed, just to make sure that's not the case. To see if your antenna is bust, connect an external antenna. I still have my streetpilot 3, rugged as hell, just a bit crappy memory wise, but back in those days it was THE SOLUTION!
Posted on Jun 17, 2008
My zumo 550 won't acquire satellites I tried update, no result Battery does not work
The internal rechargeable battery in most electronic only has a life expectancy of about 3-4 years so it is common for then to die over time. It may be the same scenario with your GPS's antenna. You may be able to find a replacement battery for your GPS at a local battery outlet. But otherwise it may have to be sent in for warranty or repair.
Hope this helps!
Apr 26, 2011 | Garmin zumo 550 GPS Receiver
HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
  1. Connect the zumo to a power source such as a computer or AC outlet
  2. Hold the zoom (+) and ON buttons at the same time for five seconds
  3. If this does not restore power, remove the battery for five seconds
  4. Place the battery back in the zumo
The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
Good luck,
Michael
Feb 01, 2011 | Garmin zumo 550 GPS Receiver
Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
Jun 30, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 cannot find satellites
I'd remove the battery first, leave it out some time, put it back, fully charge it and use webupdater to see if all is up to date. There is a test menu on the Zumo to see if all works. I will tell you how to get there, only after you have tried the above first!
Jun 16, 2008 | Garmin zumo 550 GPS Receiver
Battery will not take charge from wall unit
Remove the battery for several minutes, replace the battery and plug the wall socket in, leave it for several hours. The battery is probably too dead to do anything, and recharges very slowly. If this doesn't work, try a replacement battery, before you send the unit in for repairs.
Jun 15, 2008 | Garmin zumo 550 GPS Receiver
GARMIN ZUMO GPS 550- how to i connect power source to my Harley mc and speakers?
Red lead to the plus and black to the minus of the battery, connecting to the speakers youl'll nead something with an aux input, or a small amplifier, the output signal of the Zumo is just enough to power a head set!
May 26, 2008 | Garmin zumo 550 GPS Receiver
Garmin
i have contacted garmin and they requested i return it to them for repair.
Feb 17, 2008 | Garmin zumo 550 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
My Zumo would not start after a normal shutdown. I removed the battery and left it for a few minutes, reconnected battery and it started OK. I guess it locked up for some unknown reason.
Aug 21, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
211 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
