Question about Amana Refrigerators
My Amana Model AUF200KW Freezer drain tude keeps freezing up. How do I prevent this from happening? mjsampson@suddenlink.net
  • 525 Answers
I have been unable to determine if there were any particular issues on this model. Based on this fact, I can only suggest that the defrost, (terminating), thermostat is cutting off the heater prematurely. This can be caused by a dislocation of the thermostat, or a weakening in the sensing portion of the thermostat. This will cause the freezer to start cooling before all the water can escape to the defrost pan. Replacing this part may help resolve your complaint, but you may want to inspect the evaporator coil to see if it has indeed been misaligned first.
Below is a link that can help in disassembly and replacement issues.
http://www.repairclinic.com/0100_34.asp
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 18, 2008
Upper unit freezes up even tho both top and bottom are turned down. only does it occasionally
Its the defrost problem. The drain hole is clogged and water freezes in the unit instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/amana-abb1927de-bottom-freezer-upper.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Amana ABB1927DE Bottom Freezer...
Hi, I am Dennis. The unit leaks water from the vent in the bottom center of the freezer side on to the floor of the freezer and sometimes out of the freezer door to the kitchen floor. Not muck of a leak....
Abesolutely a bad defrost heater. it is too weak to defrost the ice completely, therefore it falls off the coils and freezes on the drain tray. If you dont want to replace the heater you can also just install a drain tube heater that wires into the evaperator fan, it will run constantly as the fan does to keep water from freezing in the tube or tray. All parts can be purchased at http://www.reliableparts.com/ using your model number.
Nov 30, 2010 | Amana ASD2622HRQ Side by Side Refrigerator
Fisher and Paykel Fridge/Freezer - Drain Freezing Up
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jul 20, 2010 | Fisher and Paykel Refrigerators
Water down in the bottom and we had to turn the thermostat to a colder temp
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Apr 22, 2010 | Amana ATB1832AR Top Freezer Refrigerator
My freezer leaks when not freezing
Drain tube
Mar 02, 2010 | Refrigerators
My Amana AFB2534DEW fridge is leaking onto floor, no visible leak coming from inside fridge or freezer. Unit does not have ice maker or water dispenser. Please help diagnose problem... Thanks
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Take a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Jan 07, 2010 | Amana AFB2534DE Bottom Freezer French Door...
I have a Hotpoint Refrigerator Model HSS25GFPH and the water dispenser won't work. The icemaker is still working. I have changed the filter and still no water. Any suggestions? Ben Kirkpatrick,...
My daughter's Hotpoint has the same problem (not sure of the exact model). Discovered that the water line inside the freezer door is freezing up. However, I don't know why and the dealer says they have no clue either. This may be your problem.
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice cream and bread don't freeze, food in frig DOES freeze
Not fixed but I do not want to spend MORE money to find out what's wrong with this AMANA piece of ****. Apparently, from research on the net, the compressor or motor is not strong enough in this unit to actually do the job...but if anyone has any suggestions, I'm happy to hear them...
May 16, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water pooling and freezing inside bottom freezer.
make sure you have cleared the drain all the way to the drip pan, and the fridge should be tilted slightly to the rear for good drainage........make sure there is a clear path for the water to make it to the drain hole
Jan 03, 2009 | LG LFC25760 French Door Refrigerator
Water dispenser does not work
the problem is in the freezer door insulation, or lack of, get your model number and serial number handy call 800-386-1215 and see if your machine is under the door replacement program
Worth the try
Apr 10, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refrigerators Logo
189 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
