Question about Sharp AR-M205 Copier
Flashing F in display - Sharp AR-M205 Copier
    President:
  • 2,072 Answers
I am going to assume there is a 4 flashing also.
Press # * C * or P * C * the machine will enter diagnostics.
Then enter the number 14 like you were making 14 copies.
Then follow the directions , to execut the 14 clear, the machine will reset and should run fine.
Posted on Nov 12, 2010
  • athletics828 Nov 14, 2010
    Thanks, but the code is actually F1-06. I can't find that code listed anywhere in the manual or online. I haven't tried the 14 clear yet.
  • Sharp Expert
  • 414 Answers
thanks
Posted on Sep 06, 2012
How to change clock
From the owners manual for the 2012 Impala Section 1-14.
(I have included a link from Chevrolet's website to the full manual)
Setting the Clock
To set the time for the Radio with
CD (Base):
1. Press the H button until the hour
begins flashing on the display.
Press H a second time and the
minutes begin flashing on the
display.
2. To increase or decrease the
time, do one of the following
while the hours or minutes are
flashing:
. Turn the f knob.
. Press ¨ SEEK or © SEEK.
. Press\FWD orsREV.
3. Press the H button again until
the clock display stops flashing
to set the currently displayed
time, or wait five seconds until
the flashing stops and the
current time displayed is
automatically set.
http://www.chevrolet.com/content/dam/Chevrolet/northamerica/usa/nscwebsite/en/Home/Ownership/Manuals%20and%20Videos/02_pdf/2k12impala.pdf
Mar 13, 2015 | 2012 Chevrolet Impala
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Why my unit keep shutting off after few seconds and then turbo light keep on flashing?
Operation =
Flashing Display Timer = Yes
Turbo =
LED Display = E1
Explanation and Checking points = Indoor unit room thermistor error - Open or Closed Circuit - Check and replace if required
Operation = Yes
Turbo =
LED Display = E2
Explanation and Checking points = Indoor unit pipe thermistor error - - Open or Closed Circuit - Check and replace if required
Operation =
Turbo = Yes
LED Display = E3
Explanation and Checking points = Indoor unit fan motor malfunction - Check and replace if required
Operation =
Turbo = Yes
LED Display = E6
Explanation and Checking points = EPROM error - Check and replace PCB if required
Operation = Yes
Turbo = Yes
LED Display = Flashing
Explanation and Checking points = Option code error - Check and input new option code if required via wireless remote controller
Operation = Yes
Turbo = Yes
LED Display =
Explanation and Checking points = Outdoor unit temperature sensor - Open or Closed Circuit - Check and replace if required
Jun 18, 2014 | Samsung AQV36JA Classic 36000 BTU Single...
Flashing freezer led
a flashing display is how samsung shows error codes. try and draw a picture of which segments of the display is flashing. think of the figure 8 and then try to show which part of the 8 is being shown. that is how we can tell what error code needs fixed.
Nov 02, 2013 | Samsung RS2630SH Side by Side Refrigerator
Lcd display flashing in out
Display components such as LCDs have limited age and years of service. Flashing and fading are two symptomps usually associated with dying LCDs. How old is your display/radio?
es
May 30, 2013 | Radio Communications
Jandy display flashes on and off
if it is flashing error code 1 while flashing you have a shorted temp sensor if no flashing 1 sounds like display board you can disconnect temp sensor 2 black wires that go into power control board disconnect with unit off then turn back on if no flashing it was the temp sensor
May 24, 2013 | Jandy Laars Lite2 Pool & Spa Heater -...
Display flashing on my deh-p6500
It has what is called reverse mode which flashes to protect the display to turn feature off please follow these steps.
Press the 5 numbered button when power to this unit is turned off while the ignition switch is set to acc or on will cancel the reverse mode and stop the flashing. Hope this helps.
Jan 06, 2010 | Pioneer DEH-P6500 CD Player
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
Display is flashing on and off
Since the display is flashing on and off, try it again on both computers and if the flashing stills goes on then you know that the monitor is bad cause there is no way to video cards from two different computers are going to have the same problem.
Aug 03, 2009 | Cornea Computers & Internet
Panasonic Kx-TG2432 Displays E9
Same here on KX-TG2248:
"Answer on" is flashing rapidly.
"Message/Slow Talk" is flashing rapidly.
"In Use/Charge" is flashing irregularly.
LED displays "E3" (and "set clock" symbol is flashing).
Removing and restoring power, many times,
produced one "spontaneous remission"
(it worked fine for several hours)
but next time moved (having to disconnect power),
it's now quite "committed" to remaining "insane" as above.
Jul 28, 2009 | Panasonic KX TG5100M Cordless Phone
Sharp AR-M205 Copier Logo
196 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
