Question about Electrolux Microwave Ovens
I have a Electrolus 25ltr Conventional Microwave. I want to buy the grill but it is not available in the market. From Where should i get it? Do electolux has any service centre in Ghaziabad from where it can be procured.
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 11, 2010
H 5040 BM has sparking/flashing coming from grill connection inside top of oven whilst microwave is in use causing this connector to glow red
take it in for repair as the connection is shorting out from the micro waves
get a quote as most repairs are more than the replacement cost
Mar 22, 2016 | Miele Microwave Ovens
Where to download the kenwood mw786 owner manual
I think this microwave with grill used to be marketed by Kenwood in the middle east markets.
The website that will be helpful for downloaded the manual is currently not working. But you can try to select the model number and see if it is available. You can also find something similar to your model as the instructions will be similar.
Instruction Manuals
Aug 13, 2014 | Kenwood Microwave Ovens
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
My de longhi ac925chs has suddenly stopped heating or defrosting but making all the right noises. The oven and grill still work ok. Is this just the fuse and if so, can i change it myself?
It's most likely a burned magnetron, and it's usually as expencive to replace than a new oven but since yours is equiped with a grill and conventional oven check the prices it could be worth changing...
Aug 03, 2011 | DeLonghi MW 535 Microwave Oven
How to use the Tesco mtg06 microwave grill?do not have instruction manual
The oven may be used purely for microwaving or simply as a grill for cooking such things as toast. The radiant or quartz grill may be used in a variety of ways. You can use microwaves that have grill functions to roast foods, for baking purposes or for grilling food such as bacon or sausages on the racks. Some models also allow you to use both the oven and grill together, and you can produce fantastically presented meals by using the grill to brown off your dish after cooking. The grill will often have low, medium and high settings for you to choose from, letting you control how brown your food is. By using a microwave with a grill, you can prepare great meals or snacks in a fraction of the time that it would take if you used a conventional oven and grill. Microwaves are particularly convenient, as you don't have to keep checking on the food or stand over it as it cooks.
Jul 29, 2011 | Sanyo Microwave Ovens
I have a magic chef that has microwave grill conventional oven every thing works except microwave don't heat
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 29, 2010 | Magic Chef MCD1311ST Microwave Oven
How to make pizza in oven
buy a pizza base...its readily available in d market. put it in d microwave for 5 mins then grate some mozzarella cheese and put on top of d pizza base...den put some vegetables...like capsicum, tomato, olives, etc.. again put it in microwave for 10 mins... if needed den put again for some more time, put some ketchup on top.. n ur pizza is ready
Jun 16, 2009 | LG LMH1017 Convection Microwave Oven
Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
