Question about Sony Network Walkman NW-E105
I have songs in my USB MP3 Player but,when I try to plau it my player it shows error of No Database. How can I fix this? thank you
  • Sony Master
  • 17,129 Answers
Whether the songs were recorded and downloaded in the format that is recognised by the Sony player is important.
Please find all support from the link: Click on Sony support
Posted on Nov 19, 2010
    Problem Solver:
  • 10 Answers
SOLUTION FORMAT FROM SONY WALKMAN FROM OWN MENU ACCESS MY NEXT STEP TO INSTALL SONY SOFTWARE UPDATER FILE WITH THE DEVICE CONNECTED TO THE P
Posted on Aug 10, 2012
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
No database
no database pour sony DIGITAL MUSIC PLAYER S/N 5313776 NW-E002F
Sep 25, 2008 | Sony Network Walkman NW-E105
Sansa e200 shows refresh database fail
try putting it in MSC mode and formating it and then putting back on MTP mode. Hope that works
Aug 24, 2008 | SanDisk Sansa e250 MP3 Player
NO DATABASE
sony walkmanmodel no nw e105 write no data what can l do
Aug 23, 2008 | Sony Network Walkman NW-E105
My mp3 player doesn't player
Use SonicStage to transfer music files. This can be downloaded fromthe internet.
Dec 05, 2007 | Sony NW-E002 MP3 Player
Music files won't show up
Is your device almost full? The player needs sever MB's of space to create the database or menu, for you to navigate with. Try deleting some music, then restart the device. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
Try emailing SanDisk technical support team at: support@sandisk.com And ask them for the Recovery Mode firmware upgrade (Also send them the problem the way you posted it here). They should send you a link to some firmware upgrade file. You could also try calling them at: 1-866-726-3475 but an email should be sufficient because, from what I remember, it is just a link to file that you need to download. I hope that helps...
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
Database???
Hi, I had the same problem and fixed it by initialising the disk of the walkman (under Settings - Initiaize disk) in combination with the installation of the newest Sonic stage software (that takes a lot of time!). This will remove all songs on the walkman, but the problem was fixed.
Jan 02, 2007 | Sony Network Walkman NW-A1200 MP3 Player
Sony Network Walkman NW-E105 Logo
371 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
