Question about HP Digital Sender 9250c scanner Printer
When attempting to send a document, the device keeps asking for a file name. We have another one of these devices setup, and on that device, there is no field for file name. Even after entering a file name, it will still tell me a file name is required. I have upgraded to the newest firmware, reset to factory default, compared the setting from our working unit to this unit...nothing seems to work. Any ideas? Thanks for any assistance. John
  • 2072 Answers
SOURCE: HP C6280 All-In-One: Problem with "Set As New Defaults" feature
What is happening, is the memory battery has failed.
When you remove the power, the settigs are stored in memory, and that memory is maintained by a lithium battery, either in the memory chip itself or mounted to the board.
If the battery is not good, the machine will reset back to the original factory settings.
Posted on Apr 03, 2008
  • 35 Answers
SOURCE: Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
hi..!
- pls click this link below it might help you to troubleshoot the problem
- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01391654&cc=us&lc=en&dlc=en&product=1153494 - for VISTA OS
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01388134&cc=us&lc=en&dlc=en&product=1153494 - for XP OS
Posted on Jul 30, 2008
  • 111 Answers
SOURCE: Wireless router FIOS upgrade - now printer won't work
If the computers connect but the printer doesn't, then it probably means the wireless router is working ok. Not sure what you mean when you say you turned off the firewalls, but I'll have to assume you mean any built-in firewall on the router and hopefully the firewalls on your Windows computers (still not sure what you mean by "security things").
You mention that you entered the SSID and WEP settings manually. I'd start there in trying to fix the problem. On the wireless router, turn off WEP. Remove any WEP setting information on the printer. Don't worry, you can turn WEP on later after you've established a connection between the printer and the router. Often with wireless devices, you first have to establish a connection with all of your security turned off, then one by one, turn your security measures back on, testing the wireless connection each time.
You've probably already done this, but make sure you've entered the SSID correctly. Sometimes it's that simple a problem.
If these measures don't work, then it could be quite a variety of different issues. Wireless networks are impacted by a large number of factors and it's difficult to diagnose all of the possible problems with just the small amount of information you've been able to provide.
HP.com does have a web page for your product that gives you a set of troubleshooting steps:
Troubleshoot Wireless Network Connection Problems
Read through all of the suggestions on that page and see if one of them will help you. Sorry I can't offer more, but as I said, there are so many things that can interfere with wireless communication.
The only other suggestions (assuming all else fails) I can make would be to completely turn off your printer then turn it on. If that doesn't work, assuming you installed the printer software and drivers when you first got the printer, uninstall and reinstall the printer, just as you did originally. Sometimes that fixes problems that can't otherwise be detected. It's a last ditch effort, but if you have exhausted all other attempts to fix the network issues, that one might work.
Good luck.
Posted on Oct 13, 2008
sfks
  • 14 Answers
SOURCE: HP Officejet 5610 All-In-One... Problem
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
349
Posted on Mar 19, 2009
SOURCE: HP Officejet 5610 All-in-One scanner will not work
Windows Vista causes an error with the scan feature of the HP officejet 5610. To work around it use the paint program:
1. open paint program
2. click file
3. click "from scanner or camera..."
4. scan menu opens
from there simly select the type of scan you would like to do and click the scan button
Posted on Jul 07, 2009
I cant open my samsung galaxy s2 due to too many pattern attempts my daughter try to open more times thats why it unlock and try to open it by putting - I wanted to ask you what im goiing to do if my...
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the phone is using or the original password used.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
We Are Here To Help !!!
Donald Deane MCSE,ASE,CPO
Aug 11, 2017 | Cell Phones
I need to know how to fax a doc
Open the document.
Click File
Click Printer Setup
Select the 'fax' device, instead of your "default" printer.
Click File
Click Print
A windows will open, asking you for the FAX-number of the destination FAX-machine.
Enter the telephone-number.
Click OK, to send the FAX.
Jul 19, 2011 | Canon Office Equipment & Supplies
I m not able to send data by bluetooth from my xperia 8 can u help me out from this problem
Usually the procedure to be followed is to select the file and from its options choose to send or transfer ..and select more options and the way to be transferred..In some devices this options is not called transfer or send ..but its called copy ..to ..or by ..After all these..you will be guided to the find device options and the device you want to copy to must be bluetooth activated and you will be able to select it from the list of devices found....by its name ...In this point you will be asked for the security code...wich is usually 0000 or 1234 if never been changed..and the transfer will begin after you confirm the transfer from the second device (the one receiving )
Another way is to activate the bluetooth in both devices...and in the one you want to send the file to ...activate it for to be found..(it has this option in the bluetooth feature..) after hat when the devices are paired..just select the file and send it by ..choose bluetooth and from the list choose the device by its name ..and click send ..after which you will have to confirm the transfer from the device you'll send to ..
Jul 11, 2011 | Sony Ericsson XPERIA X8 Cell Phone
How do I receive music via blue tooth from other phones
turn on bluetooth on both the devices and then in the sending phone go to that music file and go to option and then send option and then select via bluetooth the sending phone searches for other devices and list the phones that are available now select the name to which u should send the file and if you select send the other device will prompt you telling that you have a file and will ask whether to accept or reject once u select accept you will start receiving the file
Mar 10, 2011 | HTC Tattoo Cell Phone
How can i transfer pictures and videos from htc hero to computor
You'll learn how to transfer file (music, photos, videos, ring tones, documents, etc between your computer and your mobile phone.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • A bluetooth enabled cell phone.
  • A computer with either a built in bluetooth module or an external bluetooth dongle.
  1. jQuery(document).ready(function(){ jQuery('#jsArticleStep1 span.image a:first').attr('href','http://i.ehow.com/images/a02/4f/q0/phone-computer-using-blue-tooth-1.1-800X800.jpg'); }); Bluetooth Dongle
    Ifyour computer does not come equipped with a built in bluetooth module,you'll need to purchase a bluetooth dongle. These can be picked uponline or in a retail store and average between $10 and $30.
  2. Plugthe bluetooth dongle into your computer or if your computer is equippedwith an internal module, activate it (this is sometimes accomplished bya switch on the side of your notebook computer).
    Some bluetoothdongles will be automatically recognized and windows will automaticallyinstall the drivers for you; however some devices may require thedrivers be installed manually.
    Now you'll need to activatebluetooth discovery on your computer. This step may be differentdepending on the drivers used but should be similar to the following.
    * Look for the bluetooth icon in the windows system tray.
    * Right-click this icon and select open bluetooth settings.
    * Click on the Options tab and select "Turn discovery on".
  3. Activateand configure bluetooth on your cell phone. Setup will be differentdepending upon the brand of your phone. You will need to refer to theowners manual of your particular phone for specifics but I will covergeneral guidelines.
    * Locate the bluetooth settings menu in your phone.
    * Turn bluetooth ON.
    *Give your phone a name (you can use anything you like, but keep in mindthat other bluetooth users can see this name) this is the name thatwill identify your phone when you or others are searching for nearbybluetooth devices.
    * Set your bluetooth visibility. This shouldbe set to "shown to all" or "visible". You may wish to turn thisfeature off when you are not utilizing bluetooth.
  4. Now you'll need to pair your phone and your PC. This can be done from either the phone or the PC.
    From the PC (Windows XP):
    * Right click on the bluetooth icon in the system tray and select open bluetooth settings.
    * At the bottom of the devices tab, select "Add"
    * The Add Bluetooth Device Wizard appears, select "My device is setup and ready to be found" and click the Next button.
    * The wizard should find your device, if it doesn't, refer back to step three.
    * Select your device and click Next.
    *When prompted about a passkey, choose "Let me choose my own passkey",enter a passkey of your choosing (I like to use 0000 for ease butwindows recommends an 8-16 digit passkey). Click Next.
    * At thispoint the computer will attempt to connect to the phone via bluetoothand if successful your phone will prompt you for a passkey. Enter thesame passkey you entered into the computer and press OK.
    * If you are prompted to accept a connection request from your computer, select Yes.
  5. Nowthat your phone is paired with your computer, you are now ready tobegin transferring files. We will use a picture for this example.
    *Right click on the bluetooth icon in the Windows system tray and selectreceive a file. This lets your computer know to expect a file transferfrom a bluetooth device.
    * Again all phone models are different so this next step will vary.
    Locate an image file on your cell phone and select send - via bluetooth.
    * The phone will then search for bluetooth devices in range and display them along with already paired devices.
    * Select your computer from the list of devices.
    *The data file will transfer over to the computer and windows willprompt you to enter a file name and choose a location to save the fileto.
    * Thats it!!!
Tips & Warnings
  • Allmobile phones are different and some bluetooth drivers are different.Refer to your phone's owners manual for specific phone settings.
  • It is sometimes a good idea to turn off bluetooth on your phone when in crowded areas for security reasons
Jan 09, 2011 | Cell Phones
When I turn it on it says "Can t Unlock Maps? What does this mean?
The "Can't Unlock Maps" message appears because the unlock code is missing from your satnav. To solve this problem follow the instructions below:
Remove any microSD / SD cards in the device
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click "Register your garmin device". Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select Manage Maps
  3. Select Details
  4. The unlock code is located under the Installed Maps.
Creating an unlock code file for PC:
  1. Plug your Garmin device into the USB port
  2. Double-Click on My Computer or Computer located on the desktop
  3. Right-Click on the Garmin or nuvi drive
  4. Click Explore
  5. Double-Click on the Garmin folder
  6. Right-Click in a blank space in this window
  7. Move your mouse over the word New
  8. Select Text Document
  9. Press Enter / Return on your keyboard
  10. Double-Click on the New Text Document. This will open the New Text Document in a window called Notepad
  11. Type the unlock code that is listed in the Manage Maps section of your myGarmin account in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  14. Change the Save As Type to All Files
  15. Type gmapprom.unl in all lower-case letters for the File name
  16. Select Save
  17. Close the Notepad window
  18. Delete the New Text Document file
  19. Disconnect the GPS device from your computer
Creating an unlock code file for Mac:
  1. Open the TextEdit application located in the Applications folder on the Mac HD
  2. Click Format
  3. Select Make Plain Text
  4. Type in the unlock code that you retrieved from your mygarmin account. The unlock code should be in all capital letters and with no dashes.
  5. Click Save As and name the file as gmapprom.unl (Note: Be sure to uncheck the box If no extension is provided, use .txt)
  6. Copy the gmapprom.unl file to the GARMIN folder on your device. (Note: Save the file directly to the Garmin mass-storage device if connected)
If you have a second maps you may also need to unlock it e.g. if the first map is USA and second is EUROPE this may also need to be unlocked
  4. Click Explore
  11. Type the European unlock code that is listed in the Manage Maps section of your myGarmin account. This will need to be typed in all upper-case letters with no spaces
  12. Select File
  13. Select Save As
  15. Type gmapprom1.unl in all lower-case letters for the File name
  16. Select Save
After unlocking the maps they may need to be enabled as described below.
Enabling maps on the GPS device:
  1. Touch the wrench icon on the Where to/View map screen
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
  5. Select the checkbox next to the maps to be enabled on the device
Sep 17, 2010 | Garmin GPS
Unlock the maps? I updated with 2009 Garmin CD. It says cant' unlock maps
To retrieve unlock codes you need to have your satnav registered with garmin. If you haven't already registered it connect the satnav to your computer and go to https://my.garmin.com/mygarmin/customers/myGarminHome.faces and click Register your garmin device. Follow the prompts. You'll be asked to create a username and password. Write them down and keep them safe. You'll need them anytime you need to update your maps or solve problems in the future.
  3. Select Details
  4. Click Explore
  12. Select File
  13. Select Save As
  16. Select Save
  2. Click Format
  2. Touch Settings
  3. Touch Map
  4. Touch Map Info
Sep 04, 2010 | Garmin nuvi 200W GPS Receiver
Change language ,send pictures via bluetooth on touch diamond 2
In order to send pictures from your phone to other devices via Bluetooth, the following steps should be taken:
• Access your phones picture library
• View the picture you want to send
• Hit the menu button
• Select “Copy” from the menu list
• Chose “Bluetooth”
• Hit “Yes” when it asks you if you want to temporarily turn on Bluetooth
• Select “Look For Devices”
• Once your phone finds the device and lists its name, you select that device name
• The receiving device is then prompted to accept/reject my file
• Once accepted, the picture is sent (takes about two seconds)
Jun 21, 2009 | HTC Touch Diamond Smartphone
Can i save files sent through bluetooth strait to my memory card on the lg ks360
o send a file via Bluetooth:From the Start-up screen select the Main Menu icon
Go to Multi-media (Figure 1)
Select My Stuff (Figure 2)
Go the images/sounds/videos/documents and select the file you wish to send
Select the Menu icon at the bottom left of the screen
Select Send Via (Figure 3)
Then choose Bluetooth (Figure 4)
You will then be presented with a list of devices in your area. (Figure 5)
If you do not see the device you wish to send your file to ensure it’s has Bluetooth switched on and select New
Your handset with then search for all Bluetooth devices in your area (Figure 6)
Select your device and your handset will send the file (Figure 7)
The Bluetooth device you are sending your file to must accept the file (Figure 8)
To receive files via Bluetooth ensure you have Bluetooth switched on – only accept files from devices you recognise.
You will receive a message stating the file name with the option to accept or reject the file
To receive select Accept (Figure 9)
The file will then be transferred to your handset (Figure 10)
It will then be saved in your images folder
Oct 18, 2008 | LG Cell Phones
"Pocket PC 2002 Update 2.0"
Microsoft Pocket PC 2002 Update 2 official statement This document provides useful information for end users and IT professionals to successfully update Windows® Powered Pocket PC 2002 with the latest improvements to the Microsoft® Pocket PC 2002 software included in the update. EUU2 Improvements This update provides improvements to the following problems. Calling IpReleaseAddress() causes a multi-homed Pocket PC 2002 device to stop responding. Server Sync cannot synchronize if a specific meeting is in Inbox or Calendar. ”Trouble Connecting” error appears even when a user wants to end a connection FTP User/Password authentication default overrides user “anon.” Pocket Internet Explorer sometimes does not send Submit button Name/value information. Pocket Internet Explorer is slow to load a pages with JScript®. IMAP4 service stops responding when attempting to download e-mail with certain attachments. Media Player Full Screen playback breaks on second played clip. Advanced VPN Settings will not save in Pocket PC 2002. System .WAV sound files have extra noise at the end. Setup and Installation The PPCEUU2_.CAB file includes the EUU2 improvements described above as well as all previous updates. Once installed, the device will permanently store the changes in flashable ROM, saving the device RAM for applications and program memory. Be sure to back up all of the data on the Pocket PC 2002 before beginning the installation process. Ensure that the device has a minimum of 9 MB of free system RAM*. (Refer to your owner’s manual on how to free up additional memory.) The required memory is used only for the installation and will be available again once the setup has completed. Be sure to keep the device connected to your power adapter during the updating process. * System RAM is RAM available to the device apart from additional RAM storage cards. -------------------------------------------------------------------------------- Two methods of updating your PocketPC e310: Method 1. Updating your Pocket PC while connected to the Internet or intranet Ensure that the device is connected to the Internet or intranet through either a modem or LAN card. On the device, open Microsoft® Pocket Internet Explorer and enter the URL to the Update page. (Consult your system administrator if you are not sure of the URL.) Navigate to the appropriate page to locate the PPCEUU2_.CAB file. Download the file. Answer “Yes” in the dialog box when you are prompted. The .cab file will open and install automatically. Answer questions when you are prompted during setup. WARNING Do not attempt to turn off or restart the device while the update is in progress. After applying a ROM update, do not attempt to restore a backup that was made before the ROM update was installed. Method 2. Updating your Pocket PC while connected to a desktop computer Ensure that the device is docked and connected to
Sep 07, 2005 | Toshiba e310 Pocket PC
HP Digital Sender 9250c scanner Printer Logo
275 people viewed this question
Seeker5211
Seeker5211
