Question about Vacuums
Hello, My baby lock intrigue sewing machine threader is broken. It does not pull thread down. Thank you, Deborah
3 Suggested Answers
micromatikal
  • 2777 Answers
SOURCE: instruction manual for a baby
Unfortunately this manual can't be found for free anywhere online, I have looked extensively for you. It can be purchased though, for $7.99 from the link I will give you at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www.sewingpartsdirect.com/babylock-model-bl4-728d-instruction-manual.aspx
Posted on Oct 14, 2010
Tally Girl
  • 1129 Answers
SOURCE: Just inherited a kenmore ultra
You can buy this part here
http://www.sewingpartsonline.com/tension-kenmore-mo-2052.aspx so I'd say it is certainly repairable.
However, installing it may be something you get a serviceperson to tackle, just depends on how easy it is to access the machine. etc. Another Fixya expert may have done this type of repair before but I haven't.
The other option is to take the machine to a local sewing machine repair person and get a quote to replace the tension dial and give the machine a service at the same time; this will mean you'll know the machine is working correctly, has been cleaned and lubricated and you'll be able to start fresh with it.
Posted on Sep 06, 2011
My Futura 900 machine is locked up tighter than a drum. How can I fix it?
this should be in sewing not vacuums. Did you find the bit of needle that broke off? It might still be in causing problems. turn machine upside down to free any bits that might be hanging about.
Jul 03, 2014 | SewShop.com Singer Model 900 Futura...
I got this for my daughter in law. The machine bunches thread up underneath material. I have tried moving the upper tension, rethreaded (with pressor foot up) the needle & bobbin. I have changed...
the tension at bobbin seems to be the problem, make sure bobbin thread is in placed in bobbin CORRECTLY...then it should not be loose but loose enough to pull out with the slightest pull, top tension should be set on around 4,,,,,
Feb 28, 2014 | Singer 4411 Heavy Duty Sewing Machine
Feed dogs don't work!
Many of the older machines had a long geared belt that operated the feed dogs. Turn the machine upside down, take the bottom off and check. If there's a belt there, check it for tautness and for useability. If there is a belt, take it off and try the sewing machine repair shops in Kazoo on S. Westnedge for a replacement.
Oct 23, 2013 | Singer CG590 RBFree$30CarVac*18Stitch...
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
Hi, I have a silly question. How on earth do I thread my Brother Xr-65 sewing machine?!! I have misplaced the users manual during my recent move. It seems to take thread a little differently than my...
The XR-65 and the XR-65T are the same except that the T indicates the sewing machine was sold with the Quilting Table and some accessories for quilting.
To thread the sewing machine, first lift the presser foot and use the handwheel to raise the needle to its highest position. The thread take up lever should be at its highest point. Place the spool of thread on the horizontal pin secured with the appropriate cap. Make sure that the thread comes off the spool from the bottom front, (Also check that the catch (for holding the thread when not in use) on the spool is at the back of the pin.) Then bring the thread to the thread guide at the back of the machine then down past the reverse lever and back up the the thread take up lever. Wrap the thread around the take up lever so that it slides into the slot and then goes through the hole in the take up lever from right to left. Bring the thread down again and place it behind the guide above the needle. Then thread the needle from front to back.
Brother has the manual available for download: http://welcome.solutions.brother.com/BSC/public/files/dlf/doch000061/xr52c65txl64526562ug01enesfr.pdf . See page 31 (43 of the PDF) for the pictures of the upper thread path.
I hope this helps.
Jul 29, 2011 | Vacuums
Just purchased a used Babylock Companion 200 sewing machine; looking for a user's manual.
I just purchased one from from shop in McDonough, GA called Scarlet Thread. The are Baby Lock dealers and were able to get one for me. It took about 3 weeks but was only $6.99.
By the way, you bought an excellent machine that's super durable!
May 07, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
Sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Jan 05, 2009 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
