Question about Cell Phones
Hi, my name's Dan Sabadas and I bought recently an tv lcd sharp aquos LC32DH77E,and I to know how to access the service menu,in order to find how many hours did lcd worked. Thanks.
How to make picture on full screen
You have to go the menu of the tv and have to change aspect ration setting to 16:9. Here i have added the link the the manual of the tv which will help you to know how you access the settings.
www.electro-medical.blogspot.com
Sharp Aquos LC 32D44U Operation Manual
Sep 11, 2015 | Sharp AQUOS LC-32D44U 32 in. LCD TV
SHARP LC 46XD1E LCD TV
the service menu can only be accessed with a "service remote" only available to certified Sharp service techs... special training and $350 required to become one... contact sharp for more info or find a repair man locally if you dont want to become one yourself... the training is a lecture
Jul 04, 2012 | Sharp Aquos LC46XD1E 46 in. HD-Ready LCD...
How to reset sharp aquos lc-32l400m?thanx before
Sharp Aquos LC-32L450M - i have recently baught this LCD, but I think the 'mpx' ie the multiplex sound is not working. there is this 'mpx' button on the remote, but wen i press it nothing really happens. in the manual its only written in one line "mpx- multiplex sound" . please any one can help me ..I m really not happy wit the sound right now. paid so much & no good sound its bit irritating please any one help.. wats the problem
Jan 06, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I bought a Sharp 52" LCD stuck in demo mode
Hi jmartinezua,
Here is how you fix this:
Go to menu--> setup --> reset
This will reset your TV to factory settings. The Demo Mode will cease.
JJ
Feb 23, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp AQUOS 65" LCD, No Picture Menu Access
change picture mode from (STANDARD)or other modes and put tv in CUSTOM then you will be able to change the contrast
make sure all cables are in
Dec 15, 2009 | Sharp Aquos LC65E77UM 65 in. LCD HDTV
Sharp Aquos 37" Audio Static Issue when watching DVDs
i have had to replace the hdmi input board on these units to fix them.
Jan 08, 2009 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos lines threw the picture
I've seen this problem before and if caught early (usually only a few pixels), its fixable. But if it has already started forming a "line" it might be too late and you might have a defective LCD panel. Most of the time, doing the factory initialization helps with this problem.
(WARNING: THIS GIVES YOU ACCESS TO THE SERVICE MENU. DO NOT ADJUST ANYTHING IN THE SERVICE MENU OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS. IF YOU DECIDED TO ADJUST ANYTHING OTHER THAN WHAT I PROVIDE YOU IN THESE INSTRUCTIONS, I WILL NOT BE RESPONSIBLE IF ANYTHING WRONG HAPPENS TO YOUR TV.)
  1. unplug tv
  2. press and hold at the same time “Vol –“ and “input” button on the TV set.
  3. while holding those buttons, plug the tv back in
  4. the tv should turn on by itself, keep holding the buttons until the letter “K” appears. Then let go
  5. then at the same time press “Vol –“ and “Ch. Down”, you should see the service menu appear (if it does not appear, try pressing the two buttons again, it needs to be exactly at the same time)
  6. Then use the “Ch. Down” button to navigate down the service menu until you see “Industry Init” (NOT Industry Init +cause)
  7. Then press “Vol +” to toggle it to “ON”
  8. Then “/////////////////” should appear.
  9. when the screen turns GREEN, unplug the TV. Wait about 30 seconds, then plug the TV back in.
  10. Then continue on with the initial setup again.
Mar 27, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
My Sharp Aquos 46" LCD
Digital inputs on Aquos TV's are "always on," usually the HDMI inputs and DVI inputs. As opposed to analog inputs 1, 2, or 3, are only activated once something is plugged in.
Try plugging in another HDMI sources into input4 or 5, if its still not working, the TV needs a new Main Board. Try calling Sharp 1-800-237-4277 and locating a local service center in your area.
Mar 14, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Cell Phones Logo
32 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
