Question about Car Audio & Video
I have a 2003 mustang gt convertable and changing out the head unit with a Sony 540 Xploid unit. I have the metra 70-5519 harness. on the back of the head unit it has an out put for the rear subs and a out put for the front with the RCA's hook up. Do I need to have both plug in so I get all the speakers to work. Since the harness only has one set of RCA's on it. Do I need to get a Y set of RCA's to plug into all ports.
  • 23 Answers
You shouldn't have to buy y connectors. The sub output on the back of the sony head unit is for bass output that goes to an amplifier & then to a sub. The RCA's on the harness will be just for Stereo sound ( left & right ).
Posted on Nov 11, 2010
  • Michael
    Michael Nov 11, 2010
    Sorry i should have clarified a bit better, it was a bit hard to understand your question ,If the sony head unit has multiple sets of stereo RCA outputs you only need to plug in the two RCA's on the harness into two of them, one left and one right to get sound to all your speakers.
    They should be plugged into the plugs labelled as Front if you have a choice.
    If you are running a sub
4.6 Engine valve train in 2008 Ford Mustang Gt
    mages for 4.6 Engine valve train in 2008 Ford Mustang Gt
    More images for 4.6 Engine valve train in 2008 Ford Mustang Gt
    2005-2009 Mustang Cylinder Heads & Valvetrain ...
    www.americanmuscle.com/mustang-valvetrain-0508.html
    They help your motor breathe better and also make sure your Mustang gives top-notch throttle response. ... 2005, 2006, 2007, 2008, 2009 Mustangs; V6, GT, Bullitt, Shelby GT500, ... 2005-2009 Mustang GT Cylinder Heads & Valvetrain Components ... (6).Ford Racing SOHC 3V 4.6L Head Changing Kit (05-10 GT) $76.00.
    Mustang Camshaft Facts & Technical Information ...
    www.americanmuscle.com/camshaft-tech-guide.html
Feb 08, 2016 | Ford Cars & Trucks
Installation
Crutchfield has a good selection of wiring harnesses complete with kits and instructions. Crutchfield.com
Dec 31, 2013 | Pyle PLTS78DUB Car Video Player
How to change taillight on 2007 ford mustang gt convertible
Open trunk, pull back any trim & if you don't see
the lamp socket, you will see nuts to remove the
tail light housing from the body
Jul 08, 2012 | 2007 Ford Mustang GT California Special...
I installed a aftermarket head unit in my 2002 Malibu; right now I did the fuse tap thing that came with the metra 70 - 2003 wiring harness but the head unit doesn't cut off when the car is off. Then I...
The radio accessory wire is brown at the ignition switch. If the ignition switch is to the left of the stereo, remove the stereo to access the ignition wires.
Apr 04, 2011 | Car Audio & Video
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
Got a 2003 GT convertible, intermittent wipers
The turn signal switch and wiper switch are one unit called a Combo switch. The good news is it is easily changed. After opening the column covers it is held to the side of the column with two torque head screws. You don't have to remove the steering wheel.
Oct 24, 2009 | 2002 Ford Mustang
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
2000 mustang convertable amp problems
Are you sure the amplifiers are trashed? Have you checked the fuses? A reputable car audio shop could help for a fee of course, but it may be worth the price. It's odd that (all) the amps would malfuntion simultaniously unless someone unqualified messed with the wiring or the radio has a defective trigger wire (turns the amps on). You'll be sadly disapointed with any new radio without the factory amps, especially with the convertable ... I strongly suggest getting the amps (the factory system) working again.
Apr 17, 2009 | Metra Turbowire 70-5605
Replace grill on 07 mustang
Follow this link to get instructions. I did and it worked for me. I also includes pictures of the process.
http://www.mustangmonthly.com/howto/mump_0710_center_grille_foglight_install/index.html
Jun 30, 2008 | 2007 Ford Mustang GT California Special...
Car Audio & Video Logo
63 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
