Question about Samsung DualView TL205 Digital Camera
My samsung TL205 camera is in good shape, but when i press the left betton which is for flash mode change in looking at previous pictures, it does the command for the "up" or display button instead. i cannot go back to my old photos unless i go through all of my pictures. i can only go right. and i cant change the flash mode! help!
  • Fareeha Chowdhury Nov 11, 2010
    it didnt work. i think ur right, button board problems...i might still have my warranty. ill check up on it. thanks!
  • Samsung Master
  • 13,433 Answers
You should have a RESET, Factory reset, default settings, or similar option in the setup menu of the camera. which will reset the cam back to defaults, see if that solves the problem.
If that doesn't solve the problem possibly a button is broken, well - since something does happen when you press on the button the button itself might be OK, if it used to work before do you recall when this started happening and what had been done before?
it does sound like it might be a bit more complex problem than just a button, possibly theres a problem with the button board and its sending the wrong button press forward.
Posted on Nov 11, 2010
  • Ekse Nov 11, 2010
    Allright, if its in warranty, thats definitely the way to go.
My TL205 screen gets completely dark when i want to take pictures but i can see other things on it. I need help !
Reset camera Settings by the below procedure.
-Press the MENU button
-Use the left or right arrow keys to select the Settings menu (its icon looks like a wrench and hammer)
-Use the up or down arrow keys to scroll to the choice that says "Reset ALL..."
-Press the "Func./Set" button to confirm your choice.
Oct 19, 2013 | Samsung DualView TL205 Digital Camera
How do I disable the PTP mode in my Samsung ST150F smart Came
TO CHANGE THE PTP MODE OFF IN SAMSUNG ST150
1) Turn the camera off
2) Hold the zoom out (-), flash button( PHOTO TAKING) and the Menu button.
3) While holding, turn the camera on.
4) When the camera turns on, it will show a text screen
5) You can let go of the zoom out and the Menu button
6) Press the Menu button
7) Press left. This will turn PTP Mode off
8) Turn the camera off and on, and you're good to go
Aug 21, 2013 | Samsung ST150F Smart Digital Camera Red
When using flash it takes a couple of seconds to take photo hence picture is blurred
It's probably because you have enabled the slow sync flash mode.
To switch to the normal flash mode (auto flash) press your left directional key until the flash mode indicator near the top left of the screen (an icon with a "lightning" symbol) changes to an icon with a letter A next to the lightning symbol.
The slow sync flash mode is different from the normal flash mode; in this mode, the camera exposure duration can be a few seconds and the flash actuates at the beginning of the exposure. Although this is useful for certain photography techniques, you have to enable normal flash mode to take pictures in the normal way without blur.
Apr 28, 2011 | Samsung S760 Digital Camera
How do i use nite vision on the Samsung s galaxy for her AT&T which has no flash
Open the camera app.
Then on the left hand side press the "SCN" scene select button.
Look for the scene mode labeled "Night". Press that "Night" icon twice.
It will return to the taking pictures screen - now in night mode.
Mar 14, 2011 | Samsung Cell Phones
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
Actually, what I meant was, how do you get the flash to FLASH for EVERY picture? THanks. Samsung L100
Press the Flash button (left on the cursorpad, marked with a lightning bolt icon). Each press of the Flash button cycles through the various modes. You want the Fill mode, indicated by an unadorned lightning bolt.
In my copy of the manual, it's on page 30.
May 05, 2010 | Samsung L100 Digital Camera
The flash has stopped working I think the bulb is blown??
on the left,right,up and down buttons on one it looks a bit like a lightning strike go to picture mode and press it.
Apr 19, 2009 | Samsung Digimax A7 Digital Camera
The Flash on my camera won't work
When taking pictures, you must really be allowing time for the camera's flash to be charged
before you could take another picture so that camera will have enough time to rest and it
could function normally.
But if the camera was dropped, then it's really causing those kinds of issues like flash will not work properly.
You could still try these steps below:
First, do the POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Reload batteries
- Turn on camera
Second, do the MASTER RESET
- Be in AUTO mode
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see RESET
- Press the right button to pick up on YES or NO
- Press on OK/MENU button for changes to be saved
- Turn off camera for a few seconds so that settings will be refreshed
Turn it on and take a picture.
When you want to have just the AUTO FLASH.
- Rotate the mode dial to PROGRAM
- Press the LEFT/FLASH button until you've seen the
LIGHTNING icon with the Letter A on the leftmost part of the screen
- Try to take a picture by pressing and holding the shutter button
halfway first for 3-5 seconds and then press it all the way down
Dec 13, 2007 | Samsung Digimax S630 Digital Camera
Using flash freezes up camera
- Turn off camera
- Reload batteries
- Turn on camera
- Be in AUTO mode
If it still does not work, you need to contact the Manufacturer.
Dec 12, 2007 | Samsung Digimax S630 Digital Camera
Samsung DualView TL205 Digital Camera Logo
242 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
