Question about Bosch Exxcel WFO 2264 Front Load Washer
WFO 2260: drum not rotating on any wash cycle. No spin. Is there a cheaper solution than replacement of whole WM or is it not worth it? Machine is at least 15 years ols, but we've never had a problem with it. Paul H
  • Bosch Master
  • 3,463 Answers
I suspect that the brushes in the motor need replacing, remove the motor and replace brushes if less than 4 or 5 mm long.
Posted on Nov 11, 2010
I have a new machine beko wm 5120 W and tried to re-spin some items after they had been through a wash cycle...i turned the dial to spin, chose my spin speed and pressed start...the machine went through a...
No idea why but it happens to us to. You need to cancel the wash, switch off and leave a few mins then retry, not that it may work.
Now the spin cycle has stopped on ours too plus the spin is not actually working, drum is just going round and round slowly! We've had it just over a year so the guarantee has finished too :-(
Oct 31, 2010 | Washing Machines
Bosch maxx plus wfo 2260 will not spin it is working fine up until it is time for the spin cycle. Sometimes I have to stop the washer then just put it on to the spin cycle sometimes this works sometimes it...
Sounds like it is not rinsing properly.
If you have not already done so, then check the pump filter.
This is located at the bottom front right of basher behind drop down cover.
Unscrew anti-clockwise to remove and clean.
Mar 25, 2010 | Bosch Washing Machines
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
WFC 2260 - Machine Fills and empties, but drum doesn't rotate
You probably need to replace the brushes in the motor.
Remove rear panel, remove belt from drum, undo 2 screws securing motor, unplug lead to motor, lever motor back with a screw driver, keeping hold of it, and remove motor.
You will find the brushes located at the opposite end to the motor pulley.
Please leave a fixya rating for my proposed solution.
Thankyou.
Feb 03, 2009 | Bosch Axxis WFL 2060 Front Load Washer
LG 2277 Spinning intermittently "growling"
Followup: (of techwannabe)
After researching a bit further it was worth the investment to replace the sensor assembly and see if this would fix the issue. Viola! runs like a champ. The part was located locally for a mere $ 25.00 and with a few tools, strength of a gorilla to move the machine I repaired it. Yes a mother of four can complete the job! The unit works beautifully.........................
Dec 22, 2007 | LG WM-2277HW Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Front load washing machine would not spin now won't wash either.
Sounds like you have a broken belt or a bad motor. The easiest way to tell if the belt is bad is to reach inside the drum and turn it. If it turns very easily, you probably have a bad belt or something has caused the belt to jump off, such a s a loose pulley or bad bearing. If it feels like there is a good amount of resistance, or a kind of "winding up" noise, then the belt is still on and you likely have a bad motor. Also, you could just scoot the macine out, unplug it, and remove the back cover a look inside to see if the belt is still on the pulleys. Good Luck!
Oct 17, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
337 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
