Question about PNY Optima Pro 2GB Secure Digital Memory Card
My pny optima wont unlock even when not in locked position on card
4 Suggested Answers
issy2
  • 460 Answers
SOURCE: PNY Optima 2gb SD Card Write-Protection Problem
Ur right it has a physical problem. Try to format it using dos and then give it a try.
Thankyou
Posted on Jul 31, 2009
  • 10406 Answers
SOURCE: My 4GB PNY Optima sd card will not read
Try the 4GB card in some other reader, or your camera, to confirm that it does work.
It's possible that your card-reader will not support anything over 2GB.
Posted on Dec 10, 2009
SOURCE: PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Posted on Jan 07, 2010
My PNY Optima SD 2GB memory card locked itself! How do I unlock it?
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 02, 2014 | PNY Electronics - Others
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
Just bought x500 digetal camera and can't figure out why it says write protect on screen will not allow to take pictures the memory card is a PNY optima 4GB with the memory card out it allows 3...
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 13, 2011 | GE Cameras
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Even when i slide the tabb to unlock up the camera still says "Memory Card Error" "card is locked"
The tiny amount that the lock-unlock slider has to move to make it "lock" is very very small. I mean you could not tell if you were looking at it small, but if you try and slide it up you will feel it slide up a tiny tiny bit. The problem is that when you slide the card in the card reader the friction of the slide in makes the tab go down just a little bit. Then you have your lock problem again. I usually make sure the card is in the unlocked position and place a very small amount of super glue behind the tab (if you clump the glue at all it will never fit back in the card reader) and let it dry for several hours (to let the glue cure to maximum strength). Make sure that the card is not in, on or touching anything where the glue is while the glue drys or it will never come out or off of it. If that does not get it to work try to reformat the card in a PC and try it again (this will blank any data on the card be warned).
Aug 24, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
How to unlock Optima Digital Camera Memory Card?
You unlock the card by sliding the lock button, across, on the card itself.
Feb 20, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
I have a pny optima sd card for my vivitar digital camera today when i tried to take a picture it says card protected and i dont know why is happening
SD cards have a small slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 30, 2009 | PNY Technologies GeForce 6200 128MB AGP...
Write protected and locked files on PNY Optima 2 GB flashdrive
is there a little switch on the side of the usb, if so move it. test with "H2testW"
Jan 25, 2009 | PNY Optima 2GB USB 2.0 Flash Drive - Dark...
PNY Optima Pro 2GB Secure Digital Memory Card Logo
65 people viewed this question
Top PNY Electronics - Others Experts
john milligan
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
