Question about NComputing L230 Network Terminal
I have config the ncomputing dell powerdege T110 systems. i have in installation and configuration win2003server sp2 when i configuration on dell T110 systems server my ncomputeing dives not connecting to NCS SOFWARE . THE ERROR IS (TS ERROR - STATIONS LIMIT EXCEEDED) how to resolve this problem. pl. help me
Hi Jerod - we'd like to get some more info from you on your specific configuration to narrow this down. But, it's likely an issue specific to the T110 (quick way to isolate is to run 2003 Server in a VM on the same machine to see if you still have the issue). Please contact us at http://www.ncomputing.com/techsupport (online or phone support) and we can help you with this.
NComputing Tech Support
Posted on Nov 11, 2010
Luz naranja parpadeante?
That depends on what is flashing orange. Please be more specific, and please post in English. In general, flashing orange lights on Dell servers mean something is wrong. Installing and running Dell OpenManage System Manager will usually tell you exactly what is wrong.
Jul 28, 2014 | Dell PowerEdge T110 II
Wifi won't connect
install windows xp 2006 2nd edition sp2
and then upgrade drivers
Dec 18, 2013 | Dell Inspiron Computers & Internet
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
I installed and used the NComputing x300 on windows XP-SP2 on Dell Optiplex GX-280. At first it was working. Latter I get a Virus attack in my computer and formatted the Computer with the same OS. Then I...
You need to re-register the software and the devices. Reboot after registration all should work fine. BTW - I'd recommend installing SP3 (will minimize virus attacks due to increase security patches) and contact NC TS for updated X300 software, it's free so they won't charge you for it and your system will be more current.
Jul 15, 2011 | NComputing X300 3 User Expansion Kit...
Dell poweredge t110 Raid 5 setup on PERC 100 raid config in bios stating Virtual drive degraded and drive 2 is in ready state...how do we remove from drive array and install a new on without data loss
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
May 02, 2011 | Dell PowerEdge T110 Server (GB/2GB)...
First l230 connect to vspace ok,then i installed safe360 , then l230 report "terminal server - yet not ready. please, retry ..."
What is Safe360, an AntiVirus or Firewall software? If so, the program may have inadvertently blocked port access to the kernel which vSpace needs access to for user sessions. Below are the port exceptions for firewall configurations and file exceptions for Antivirus configurations. Current as of this post.
  • Port Exceptions
    • For L-series device connection
      • TCP: 27605, 27615, 3581, 3597, 3645, 3646
      • UDP: 1027, 1283, 3581
    • For vSpace registration
      • TCP Port 3630
      • Point to:
        • register.ncomputing.com
        • or 85.214.107.229
    • For vSpace Update
      • TCP Ports 20 & 21
      • Point to:
        • 70.182.176.102
        • or 81.169.173.128
        • or 81.169.173.128
  • File Access Exceptions
    • For vSpace functionality
      • C:\Windows\system32\KMServc.exe
      • C:\Program Files\Common Files\NComputer\Bootsrv.exe
    • For vSpace tray icon
      • C:\Program Files\NComputing vSpace\KmMsg.exe
    • For vSpace Registration
      • C:\Program Files\NComputing vSpace\KmRegWiz.exe
    • For vSpace Update
      • C:\Program Files\NComputing vSpace\KmUpdate.exe
May 01, 2011 | NComputing L230 Network Terminal
Hi, when i try to connect thin client(L130/L230) , i get following error "ts error stations limit exceeded " , configuration is Dell power edge T110 , OS is Windows server 2003 , i have tried...
I need more details to help
How many TS licenses do you have?, are they PER SEAT or PER USER?
I suspect that you'r TS licensses are PER SEAT
seeya!
Dec 18, 2010 | NComputing L230 Network Terminal
Problems when installing sp2 on my dell 4400
Reboot and keep tapping on F8 into Safe Mode. You can select "Last known good configuration" or continue In safe mode and do a system restore to the day before you installed the SP3. To do a system restore, go to Start, Programs, Accessories, System Tools, System restore. Windows XP SP3 has some issues with certain programs giving the blue screen of death.
Jan 04, 2009 | Dell Dimension 4400 PC Desktop
Ncomputing l230
at present Ncomputing supports only 32 bit version softwares.
Jul 14, 2008 | NComputing L230 Network Terminal
NComputing L230 Network Terminal Logo
930 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Alun Cox
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
