Question about Daewoo DTQ-19V1FC 19" TV
Daewoo DTZ29G2 has an oval rainbow on screen
My 60" 3D LG Plasma Model 60PZ950 is displaying an oval of rainbow colors, which seem to switch to different parts of the screen, i.e. top/bottom/corners etc. What causes this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 08, 2015 | LG Televison & Video
Lcd screen rainbow
try on external screen, if works, try changing LCD, if on external screen is rainbow, videocard problem.need 2 replace videocard, or repair..
Dec 28, 2013 | Acer Aspire Computers & Internet
Rainbow e2 system. Will not power up
the water basin has a safety on it so the unit cannot run without it. if you look on the bottom of the rainbow you can see a small oval shaped space that you can depress just to test and see if it still runs it will only run with this depressed.
Oct 11, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
Im seeing triples on my screen when i use the menu and when i play a dvd theres like a black oval line on the bottom with a rainbow effect..
Need to replace the convergence amps, possibly some of the yoke return resistors and pico fuses in the convergence circuit,
Bill
Oct 30, 2008 | Toshiba 42H81 42" Rear Projection...
Rainbow on the screen
Do you have any larger speakers close to you tv. Or any magnets been neer it. If you unplug it for a while the tv should have remove the rainbow
Aug 28, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Daewoo Plasma DT-4280NH
Hello nkoomy,
This is a sign of a bad scan driver board
Jul 28, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Rainbow
Rainbow effect has more to do with color wheel style and speed.
Jan 31, 2008 | LG RU-44SZ51D 44" Rear Projection...
Samsung HDTV Oval rainbow of colors covering entire screen
I HAVE PANASONIC MODEL TH50PE700U WATCHING IT AND THE COLOR WENT YO B/W
Oct 04, 2007 | ViewSonic N2750w 27 in. HD-Ready LCD...
Rainbow colours appear on the screen after it fell over
Hey there well what i think happend is that the convergance has been modified and some parts has moved inside the TV. There's lots of posts in this website about this problem so just search for convergance. also check this link it will exlain you exactly how to deal with it http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-i.html Let me know if you need more help :) Tom
Jun 26, 2007 | Daewoo DTQ-27S2FC 27" TV
Daewoo DTQ-19V1FC 19" TV Logo
102 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
