Question about Siemens Washing Machines
Siemens washing machine WM14S392GB is giving me this error : F61 and F34. What does it mean
5 Suggested Answers
SOURCE: Hoover Vision 1600 AAA Washing Machine error code 5
High summerzaman,
the error mean an problem by the temperatur sensor of the water. It is possible an defect of the sensor or cable between the sensor and the microcontroller or the controller self.
with regard Andreas
Posted on May 07, 2008
SOURCE: siemens s14.149 washing machine error
Mine was the front door catch!
Posted on Sep 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: Cabrio WTW6600SBT Top Load Washer: my washing machine is giving e an f1 error what do...
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 20, 2010
  • 1417 Answers
SOURCE: Bosch washing machine error code
An F61 error code on your Frigidaire washer indicates a failure of the drain pump relay. Depending upon the model, your washer may be under warranty for up to 6-15 years above , so check your warranty's status before attempting any repairs yourself.
To solve the error code problem apply the below step one after the othe
  • A power outage can cause error codes to display on the screen, even if there's no problem. Hold down the "Cancel" button for three seconds, or unplug the machine briefly to see if the code goes away. If it returns, the problem is real.
  • The pump can also be the problem
  • Unplug the machine and remove the service panel. Locate the pump on the floor of the machine, to the left of the tub, towards the front. Inspect the wiring for burns, breaks or loose connections, and replace as necessary. Use only appliance-grade wire.
  • TO REPLACE THE CONTROL PANEL.
  • If the wiring is fine, the problem is a severed relay on the control panel. Unfortunately, this cannot be repaired and must be replaced. Remove the control panel from the upper portion of the back of the machine, and replace with an identical part from Frigidaire. Generic parts can cause additional damage
  • Hope this help?
    Thanks.
    Posted on Nov 19, 2010
    I want to know how can i cleare the erro f21 about siemens washing mechine.
    Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
    Jan 14, 2017 | Siemens Washing Machines
    F34 nad f36 error bosch washing machine
    Check/ clean filter bottom R/H side could be dirty. Sometimes can be hard to remove to clean take it easy with it it can be quite Brittle plastic
    Feb 02, 2015 | Bosch Washing Machines
    What does erroe code f34
    F34 is a motor error
    and can mean many things from a blasted contact not so good
    or brushes or a bad motor detect on the pump
    Aug 05, 2014 | Siemens Washing Machines
    Washing machine Siemens iq300 has error CL in display (status) & can't be used
    This means that the door is not being closed. It might be a bad door switch.
    Mar 27, 2013 | Washing Machines
    Siemens washing machine error code e61
    Some brands where technical information is not always available or hard to obtain are Bosch,Siemens,Indesit,Hotpoint,LG,Samsung..
    Here you can Download Instruction manual For your washing Machine (Enter you Product code to Download Example: WXS1040/05 )
    https://portal.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
    Hope This help you out.
    Sep 29, 2012 | Siemens Washing Machines
    Siemens WM14S392GB - error F61. Help to fix please.
    Error E61 means that the door is locked but the sensor is showing as still open.
    You may have a faulty door sensor.
    May 07, 2012 | Washing Machines
    What does error code f67 on a siemens wash machine mean?
    I have a Siemens WM16S772DN washing machine and encountered the error code "F:67" followed by repeated beeps. (Note: Siemens and Bosch are related companies). I called Siemens and they said the code means "Fatal error" or program error. The service technician was called, and he replaced the electronic board and reprogrammed it.
    Apr 18, 2011 | Bosch Washing Machines
    Error code F-35 is showing on my whirlpoot steam duet stackable front load washer, what does that mean? It won't run through any cycles.
    it is an analog pressure sensor failure theres a malfunction with the steamer component detected by the steamer electronic board
    check if pressure hose is fixed correctly
    check if the airtrap is not blocked
    check if the hose is not blocked
    hope this helps if this doesnt work write me back
    Jul 21, 2010 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
    Washing Machines Logo
    108 people viewed this question
    Top Siemens Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    shaun taylor
    Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
