Question about Garden
Hi, I have a Foton FT254 tractor (near new auction sale) After connecting a slasher I found the PTO would not disengage using the clutch. I could start it with the gear engaged and slash the grass then disengage by pulling on the PTO lever but not with the clutch. The linkage from the clutch pedal to the PTO clutch lever-arm can be removed and the lever-arm can be rotated completely around with little resistance. I don't know what should be attached to the shaft on the inside but suspect it is some type of PTO clutch lever. It looks like I could pull the top plate (with PTO clutch-lever shaft) off the gear box (six bolts) and look inside. Is there any danger of damaging or miss-aligning something if I do remove the top plate? The manual provides no data on alignment of the PTO clutch, perhaps it is too obvious.
  • 1 more comment
  • martin Dec 18, 2012
    I would like to hear the end-solution as my foton 254's PTO also do not want to disengage thus I have to disconnect the PTo shaft from the mower of baler to stop working.
  • sdeans487 Dec 19, 2012
    Mbarnard, This is the short answer. [IMGhttp://i1140.photobucket.com/albums/n567...[/IMG]
    Another photo of broken connector pin that caused enough slack in linkage to prevent operation of clutch.
  • 97 Answers
SOURCE: lawn tractor engine dies when pto unit is engaged
Check safety switches especially the seat switch.
Posted on Mar 24, 2009
  • 6 Answers
SOURCE: drive pulley won't come off engine shaft
put the nut back on were it is even with the stud and hit with a hammer while pulling on the pulley
Posted on May 27, 2009
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
  • 376 Answers
SOURCE: cable for pto is loose and when done mowing will
It's probably not the cable, but the idler arm on the deck that the pulley that tightens up the belt is not moving back and forth freely, probably from rust. Spray penatrating oil on the pivot point while working it back and forth until it frees up. If still having problems, let me know. Dwain
Posted on Jun 10, 2009
  • 130 Answers
SOURCE: PTO clutch stop needs replacing 2130 Cub
take cover off flywheel so you can hold it from turning.or use a air compressor on clutch bolt
Posted on Jul 21, 2009
Our 4710 tractor engine dies when slasher turned on.Why does this happen?
I take it to mean that when you engage the PTO drive the extra load to the idleing engine stalls
disconect the slasher and try engaging the PTO drive without load to discount an internal PTO gearbox fault if it doesn't stall check the idle speed fuel delivery system and airfilter any thing that can impact the power output of the engine
Jan 24, 2017 | Garden
Hi, I have a yanmar 236d with 2 speed pto. I am wanting to run a slasher. Can you tell me what the 2 pto speeds are please. Thanks. Ric
talk with a dealer as to the machine operations
read the user manual
I suspect that one speed will be related to vehicle movement ( as for slasher or other attachment used while travelling and the other for stationary operation - post hole digging, pump drive etc where higher rpms are required
Oct 21, 2016 | Garden
How do you disengage the clutch after being left on when turning the engine off?
You can kill the engine with the PTO clutch on and then turn the PTO off before trying to restart because the PTO will auto disengage when the engine switch is turned off. The engine should not start if the PTO switch is on.
Jul 13, 2014 | Husqvarna 22 hp 42" Yard Tractor YTH22V42
Hello, I have a Cub cadet tractor model 2164, and
BEARINGS ARE BAD IN CLUTCH REPLACE THE PTO
Oct 30, 2013 | Cub Cadet Garden
PTO will on turn while under load
most pto operations have a 2 position clutch. Full down to select gears and 1/2 down to release pto when travelling. Check that clutch pedal operation is correct It may need adjusting
Apr 03, 2013 | Ford Tractor Grill 2600 3600 4600 5600...
Pto, electric clutch
check the wires they rub on sharp edges
Mar 23, 2012 | Husqvarna Garden
Mower pto engages when initially started but after
the coil in the electric PTO shorts out when it expands by heat causing it to lose it's magnetic pull and disengages- I hate to say it,but you need a new PTO clutch.
May 07, 2009 | Garden
John deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
314 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
