Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
I have a GE Adora Problem with the GE DSS25KSTB Side by Side Refrigerator I have a GE Adora refrigerator side by side for over 4 year now and since more than a year I have this problem.It all start by once in a month to at least every other day my refrigerator stop working for no reason.I can hear it running but the temperature goes down until the ice in my bin melted and make a big mess in the freezer and freeze the whole thing back in a block of ice.I stop using my ice maker since a while now because of that.This morning my temperature was 10 degre in the freezer and 55 degre in the refrigerator and came back to normal at noon to 0 degre and 37.So far I change the termostat and the control panel and still the same.Please help
2 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I have a GE Adora
From your description we understand that the problem with your refrigerator is during the defrost. The defrosting is control from a defrost thermostat that does not leave the temperature during defrost not to go very high like in your case. So in your case this thermostat is bad and during the defrost the temperature go higher than 10 as you describe.
In this case you need to replace the Defrost thermostat that is located on the evaporator in Freezer department.
However the defrost time period is control by a so called defrost timer and this should control the period of defrost that should be about 30 to 60 minutes according to the amount of ice on evaporator and is in conjunction with the above mention defrost thermostat. However if this timer is malefaction and leave the period of defrost more that 60 minutes then you have the same results the temperatures will rise more than 10 degrees. So you can fist identify the time period of the defrost in order to identify the part which is malefaction.
Sometimes both of the above parts are becoming bad and we have a very tricky situation and many engineers in order to combine the visit they replace both Defrost thermostat and defrost timer so they are in the safe side and avoiding the possibility of another vast.
You can let us have your model and brand so we can give you some more information of the parts you might need.
Posted on Nov 11, 2010
I have a GE Adora M# DSF25KGTABG. Set temps on the freezer door to 0 and 37. runs great for a few days then drops down to -9. I have replaced all thermistors and the mother board. What would be the next...
I have the GE Adora DSS25KSTB ss and the temps will not hold to cool temp.
We set it at 0-25 and the refg to 35 and sometimes it will cool to that temp and then sometimes it is a lot warmer.
Dec 29, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
I have adora side by side refrigerator. Both door handles are loose
check along the handles for little hole that may have set screws in them and tighten them. may need an Allen wrench set to do this.
Dec 17, 2010 | GE Adora (DSF25KGTBG) Side by Side...
GE side by side ADORA, refer and freezer or not cold, cleaned and unplugged to maybe reset. Unit is 4 years old.
return air ducts from the freezer may be iced up, unplug unit and use a hair dryer to defrost. The ducts will be behind the rear panel, but just let the hot air circulate for a couple of hours to really defrost it
good luck
Nov 26, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (Side x DSide) Adora: closing fridge door causes the freezer door to open
That will happen if you close the door too quickly or make sure the freezer door gasket is sealing properly.
Nov 20, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
My G.E Adora refrigerator freezer is not cold enough. Ice cream is melting and refrigerator is at too cold and is freezing food, It is only 5 years old. It is a side by side. Help!
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 18, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Where are the coils on the GE Adora side by side?
Most coils on modern refrigerators are underneath.
In past years, some refrigerators had coils on the rear.
Oct 10, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ge adora top half not cold on both sides
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 06, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Door panel doesnt work
Check circuit fuse,electrical connections,check your door circuit & buttons.
Feb 21, 2009 | GE Adora (DSF25KGTBG) Side by Side...
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
175 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
