Question about Toshiba Computers & Internet
Have a toshiba laptop tuan on work for about 10 minutes and power shuts off what good be the problem
  • Toshiba Master
  • 32,281 Answers
The Toshiba could be overheating and then shuts down. It won't boot up again until it has cooled down.
If this problem is not fixed the the CPU will eventually fail. For details to fix this problem, please click on this link and follow my instructions :-
http://www.fixya.com/support/r5959377-overheating_computer
Posted on Nov 11, 2010
Toshiba excite 10.1 wifi not working
Try shutting down your router, leave it off for 10 minutes then switch it on again. I had that problem with my laptop and it sorted it, no guarantee though. good luck
Apr 03, 2013 | Toshiba Excite 10.1 Tablet 16GB Wi-Fi - -
Hi I have a Toshiba laptop model no.psl2xu-ookoof and it doesn't charge anymore so what do I do
If the laptop works only off the Power Cord and the battery is not charging, then the battery is dead.
To check to make sure the Power Cord is working remove the battery and let the latop run for 10 minutes or so.
To check to see if the battery has any charge left in it put the battery in and remove the power cord. If it won't boot or shuts down then the battery is dead and needs to be replaced if the power cord is ok.
Mar 26, 2012 | Toshiba Computers & Internet
Somehow, my three-year-old must have locked the keys on our Toshiba Satellite L505D laptop. How do I unlock them? We have a wireless mouse for it, which I can still use.
Don't blame your daughter ;) some Toshiba laptops have this keyboard problem. seems the easiest remedy is;
  • Shut down.
  • Remove the battery and the AC power.
  • Wait for 5 - 10 minutes or hold the power button depressed for about ten seconds.
  • Put the battery and power back.
  • Turn on the computer.
I believe there is an updated driver for the keyboard you can download from the Toshiba support website that may may prevent this from recurring.
Hope this helps ;)
Feb 01, 2011 | Computers & Internet
My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.And from yestarday it is shetting down after 30seconds after...
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It's nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
I decided to use a shop vac to suck the dust out and it worked. I tested it by letting the machine run all night and it worked. It's been a couple of weeks now and I'm glad I did it. I was ready to take the machine apart, now I'm glad I didn't. I'd suggest you use a heavy duty shop vac to clean out the fan and heat sinks first.I agree. Try to fix the problem without taking the laptop apart first but I would recommend using a powerful air compressor instead of a vacuum cleaner.
If your laptop is still under warranty, you can take it to any Toshiba Authorize Service Provider and fix the problem at no charge to you.
Toshiba Satellite A15 Clogged Heatsink
Toshiba Satellite A35 Clogged Heatsink
Toshiba Satellite P15 Clogged Heatsink.
Aug 25, 2017 | Toshiba Satellite A205-S5855 Notebook
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
May 04, 2010 | Toshiba Computers & Internet
Toshiba Satellit M35X-S114 locked keyboard
Hi there. This is not forced to work but you can give it a try. Perform a forced shutdown on the laptop by holding down the on/off button until it shuts down, then take the battery out and the AC power for 10 minutes, put it all back together and try again. Please let me know how you get on. Good luck
Jun 04, 2009 | Toshiba Satellite A105 Notebook
Dvd player shuts off during movie
Look at the power supply capacitors to see id any have a bulged top. Those need to be replaced.
Sep 03, 2017 | Toshiba SD-2705 Multi-disc DVD Player
SL300-129 Toshiba
Remove the battery from the laptop. Wait a minute then reinstall. It should reset, if not then hold down the start button for 10 seconds and it should reboot, if it reboots sooner remove your finger from the botton. That is the quick fix to a simple problem, hopefully it will work for you otherwise it will require moe work, good luck, Gym
Dec 26, 2008 | Toshiba Satellite A135-S2276 Notebook
Shuts down
thank you for your response....I'm using Vista and the power seems to be on but the screen is down. I have to hold the power button down for 10 seconds to shut down then turn it back on to restore the computer. It is a Toshiba A215-S5818
Jun 18, 2008 | Toshiba Satellite A215-S5822 Laptop
Troubleshooting with Toshiba Satellite A75-S211 Notebook
try more chargers, if posible one made for u;re model , so that u;ll know if the charger is the problem !
i susspect that not the charger gives u hard times but the computers power managment hardware/software .... U can try to open the computer, and look for burned, blackened, smoked, components (capacitors usualy), and if so change them (if possible)
Feb 20, 2008 | Toshiba Satellite A75-S211 Notebook
Computers & Internet Logo
62 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
