Question about Toshiba TDP-S20U Multimedia Projector
I have a toshiba projector TDP S 20 it starts & automatically Light goes off in Couple of minute \r\ni don't understand what is the problem \r\nlooking for help
  • adam hill May 18, 2012
    hey mike. thereis no glass in there no bulbs havebeen smashed in it, gaz what do you mean i need a sub d connection between pc. im using the vga. also it doesnt have a usb port on it and whats a pj lol. thanks guys
Hey mike. thereis no glass in there no bulbs havebeen smashed in it, gaz what do you mean i need a sub d connection between pc. im using the vga. also it doesnt have a usb port on it and whats a pj lol. thanks guys
Posted on May 18, 2012
SOURCE: Toshiba TDP S8 projector shuts down suddenly
most probably the lamp is dead already.
jimag2008
Posted on Jan 24, 2008
  • 27 Answers
SOURCE: toshiba tdp-mt100 projector
dont use the usb connection
you need a sub d connection between pc and pj when using
pc with a pj
Posted on Feb 26, 2008
  • 4 Answers
SOURCE: The color went out on my Toshiba TDP-T45
Color wheel failed. Clean the glass pieces out loose in the unit and replace the color wheel assy with Toshiba part no: 23125963. No soldering is required, just a no. 2 phillips screwdriver and and a set of jeweler's phillips screwdrivers like Radio Shack has.
Posted on Jun 24, 2009
  • 23 Answers
SOURCE: Replaced bulb in projector and it still doesn't
Smetimes the other fan comes on when set to full bright. As your lamp is not lighting up, the other fan will not come on. If yo have replaced the lamp and it is still not working, then 9 times out of 10 it is will be the ballast.
Posted on Jan 21, 2010
SOURCE: toshiba tdp-t90 projector. I rplaced the lamp on
set the beamer off, unplug the power line, press -on-/input/menue at the same time and plug the beamer to the power line again thereafter you can remove your fingers from the below mentioned buttons. now the lamp counter should be reseted to 0 hope this helps it works on a TDP-T100
Posted on Jul 22, 2010
My TDP-P75 toshiba projector keeps cutting out for no reason - any advice anyone?
Hi, Cutting out after 5 minutes sounds like an overheat fault. On every projector will be a filter that is user serviceable - it will most likely be blocked up with lint. To Clean - locate the filter & remove carefully. gently brush the lint & dust off the surface of itusing a soft brush or vacuum cleaner on its lowest seting. Try not to puncture the filter element. reinstall.
Dec 08, 2012 | Toshiba TDP-S8 Multimedia Projector
JUST PUT NEW BULB IN A TOSHIBA TDP-S20 ON 2/18/11 . BOUGHT PROJECTOR IN 2004 USED UNTIL THE BULB HRS RAN OUT . BULB NEVER BROKE / BURST. ON START UP WITH THE NEW BULB IN MACHINE BOTH FAN AND LAMP LIGHTS...
Your new bulb is not lighting.
Check the connections are correct.
Have you also tried putting back old bulb to see if it works.
Please dont forget to vote this answer was helpful
Many thanks
Feb 18, 2011 | Toshiba TDP-S20U Multimedia Projector
Projector will only stay on for a couple of minutes then shuts off automatically. the LED turns from green to red
Make sure the venting for the cooling fan is clear and that it is activating. The only time I have seen this in a projector is when it overheats. If it reaches a certain temperature and doesn't sense the cooling fan being on it shuts down to protect the bulb and protect against fire hazard.
Oct 28, 2010 | Toshiba TDP-T90 Multimedia Projector
HOW TO RESET TOSHIBA TDP-S8 LAMP
after installing the new lamp, hold the volume top & bottom key simulteniously, when green light indicate at panel start the projector & go to service there you may found reset lamp ? press yes the lamp will reset.
Feb 01, 2009 | Toshiba TDP-S8 Multimedia Projector
Standby light for toshiba
probably power supply or ballast (starts the lamp)
either would be $600.00 or so to repair, probably costs more than the projector is worth.
Jul 15, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba tdp-t9u projector
It is likely your bulb is going out, or your fan is broken & it is oveheating.
Jun 23, 2008 | Toshiba TDP-T9U Multimedia Projector
Toshiba projector tdp-s8
please start your computer first and then the projector- use function key with f4 or f6 or f7 or f5-and select computer from input of the projector.
Dec 29, 2007 | Toshiba TDP-S8U Multimedia Projector
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Dec 09, 2007 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-P5 projector
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Oct 03, 2007 | Toshiba TDP P5 Multimedia Projector
Toshiba TDP-S20U Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
