Question about Acer Aspire T135 PC Desktop
A 6sec long beep with a 4sec break repeatedly when i turn my puter on ive checked all fans and compacitors there all fine please help
  • 1,179 Answers
This represents a RAM problem, you can also see my tip related to this matter, it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! this should get your PC going again. Remember to clean the RAM fingers with tissue paper and if you can test your RAM modules in other PC or if you have spare modules then try these, it all in my tip.
Thanking you
damnor01
Posted on Nov 11, 2010
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
No start up and continuous repeated long beeps?
Hello
Here are the bios beep codes:
1 long, 2 short
Video adapter error
Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Repeating (endless loop)
Memory error
Check for improperly seated or missing memory.
1long, 3short
No video card or bad video RAM
Reseat or replace the video card.
High frequency beeeps while running
Overheated CPU
Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low
CPU
Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
Check computer beeps and act according to suggestion
Hope it helps if so do rate the solution
Dec 20, 2010 | Compaq Presario Notebook
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
Should the wires coming from the run compacitor have power
The run capacitor is not a mechanical device, so the clicking that you are hearing is not actually coming from the capacitor. If you the wires going to the capacitor, (isolate the capacitor), you can check the microfarad rating of the capacitor to ensure it is still good using a multimeter. Hope this helps.
Apr 15, 2010 | Refrigerators
Ive just replaced my power supply and when i turn on the computer i get a continuous beeping sound.also my moniter wont display.ive got pwer to it but no picture and the mouse dont work.all fans ar running...
You may have to reseat the memory.
Check all motherboard connections and if that does not work for you, remove and resaet your video card and work one card at a time.
Dec 31, 2009 | Soltek SL-K8AN2E (SL-K8AN2E-GR)...
I formated my computer....a asus p4b 1.5 mhg....turn it on and off while re-installing all of my software. once done i turned the puter off to clean the cpu fan... since the puter would not turn itself...
hi hope this helps.
Beep Code: Description of Problem: No Beeps Short, No power, Bad CPU/MB, Loose Peripherals One Beep Everything is normal and Computer POSTed fine Two Beeps POST/CMOS Error One Long Beep, One Short Beep Motherboard Problem One Long Beep, Two Short Beeps Video Problem One Long Beep, Three Short Beeps Video Problem Three Long Beeps Keyboard Error Repeated Long Beeps Memory Error Continuous Hi-Lo Beeps CPU Overheating
Oct 18, 2008 | ASUS Computers & Internet
Constant beeping
I would first check that all the fans are turning when you first power it up. It may have fan speed sensors on them, and one or more fans aren't coming up to speed. I would check the CPU fan(s), as they are usually smaller, and tend to go bad before the other larger ones.
Feb 22, 2008 | Gateway 960 Series (gtwy960) Server
Acer Aspire T135 PC Desktop Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
