Question about ADVANTAGE Waterway Spa Pump 3/4 HP 115v
When pushing start button on spa pump does not kick in at all, tested power point and working ok ..What could be the problem and solution. Brian C
  • 310 Answers
If you know that power is getting to the computer board then it is either a bad top-side control panel, or a bad relay on the computer board. If this is an older model, replacing the relay may be possibly. If this is a newer board, they build them right into board so a new board is neccessary.
Note: Make sure to check all fuses on the main board before coming to the above conclusion. If you know how to do a continuity test with a multimeter, do this will ALL fuses before replacing anything.
Iyou are not proficient with a multimeter, visually inspect the fuses for breaks in the filiment (if the is a high voltage slow blow fuse that is solid white, start by replacing this fuse. It should be available at any decent hardware store.)
Posted on Nov 11, 2010
Hi on my uncles spa pump the blower works but every time we push the button to get the jets it makes a clicking noise in the control board but the motor won't kick in and pump the water jets?
I will make an educated guess and say that clicking noise is either the relay for the pump would indicate a dead pump or it could be from a rectification capacitor. Beyond that though we kind of need a more detailed electrical diagnostic for your exact circumstance
Feb 04, 2015 | Pool & Spa
Locate reset button jacuzzi
on the gfi box ther eis a red button and a black one..push the red one first then the black one.. it should start up..if it keeps kicking off look for a reason(leaks wet parts etc)
Oct 23, 2013 | Jacuzzi Pool & Spa
Lanark spa bath
Not really sure but it sounds like there is a sensor that may not be reading properly preventing the pump to turn on.
Rod @ US Parts Center
May 12, 2013 | Pool & Spa
Spa kicks off in a cycle. needs to be reset
Dean,
Thank you for asking me to help you with your problem. However, this is either not within my level of expertise or the question is unclear or there is not enough information and I cannot help you at ths time.
Nov 25, 2011 | Jacuzzi Pool & Spa
Pump won't start anymore. Pool guy says a part (acts like a solonoid) is bad. Is there a reset button? Can I buy the part myself?
NO RESET BUTTON, THERE IS A START OR A RUN CAPACITOR. ON YOUR MOTOR. MAY HAVE BOTH. WARNING THESE CAN HOLD VOLTAGE ! WHERE SAFETY GLASSES AND SHORT THEM OUT WITH A SCREWDRIVER . YOU CAN BUY NEW ONES OR YOU CAN SEARCH YOUR AREA FOR THE LOCAL POOL PUMP REPAIR GUY.. THEY WILL HAVE THE (TESTER) SHOULD BE A FREE TEST...#2 THERE MIGHT BE A START SWITCH ON YOUR MOTOR AND THE POINTS MIGHT BE DIRTY, USE THE STRIKER OFF A BOOK OF MATCHES TO CLEAN THE POINTS, DO NOT BEND THE POINTS ! ..HERE IS A LINK ON HOW TO REMOVE YOUR POOL PUMP AND ID IT. GOOD LUCK AND PRIME THAT PUMP AFTER A REPAIR !.., KICK ME SOME FEEDBACK IF'N I WAS OF HELP...Jay
Jan 30, 2011 | Sta Rite 1 HP StaRite Pump 15" inout...
Hot tub tries to start up and kicks off
Thank you for posting your question here on Fixya.com.
With your meter check to see if the motor is still getting voltage when it kicks off. If it is the motor needs servicing. If not, look for which component (such as the relay) is dropping line voltage and replace it.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Apr 24, 2010 | NRS Digital Spa / Hot Tub Controls
Push on button and it motor just clicks.
impeller stuck or seized-- motor needs to be oiled--or relay bad --check power to motor if power relay ok --need to service or repair impeller or motor
Feb 16, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Will not stay running.No power to the fuel system,tank pumps dead,booster pump dead and can't switch tanks.Fuse ok in dash,both relays are working...(help) I hade to hard wire my booster pump just to make...
Take the drivers side kick panel off there is a fuel safty cut off it is a gray box with a button on top push the button in see if it starts if not check the plug in the box to see if it is burnt my ford f 150 is a 87 and thats what happened to it hope this helps
Mar 10, 2009 | 1987 Ford F 150
ADVANTAGE Waterway Spa Pump 3/4 HP 115v Logo
99 people viewed this question
Top ADVANTAGE Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you an ADVANTAGE Pool and Spa Expert? Answer questions, earn points and help others
