Question about Sharp EL-1192BL Calculator
STORE TAX RATE
I can't figure out how to store the tax rate. I have tried the "STR" button, I must not be doing it correctly.
Thanks for your help.
  • tafilandro Oct 02, 2008
    Please help with setting the tax rate.
SOURCE: How do you set a tax rate?!?!?
Casio Calc SL-210TE
How to Set Exchange & Tax Rates
Select EX mode
Press AC
Press and Hold for 5 Sec %(Set) key
Press C1 or C2 or C3 or TAX+
Enter New Rate
Press %(Set) Key
New Rate is now Saved
Hope this Helps ..Mike
Posted on Oct 31, 2007
SOURCE: Resetting sales tax rate on Casio HR8TE calculator?
Thanks very much it was very helpfull.
NC- Sri Lanka..
Posted on Jul 22, 2008
SOURCE: how to set the tax rate
Its easy just type in the tax rate that you want, then hit the rate button. Afterwards leave tax+ pressed and you should see the tax % sign appear above the number you punched in, and THATS IT!!! Easy!!!
Posted on Jul 23, 2008
  • 21 Answers
SOURCE: casio MS-120TE tax rate
Look for "RATE SET" it is usually located on the % button. Press and hold the button and when the display comes up just the press the desired rate then press "RATE SET" again then clear
Posted on Sep 20, 2008
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
How change percentage (tax) rate on Casio-1100TV?
FINALLY figured out how to change the tax rate! Press AC. Press and hold the Rate Set (%) button UNTIL THE CURRENT TAX RATE IS DISPLAYED. Enter the new rate you want (such as 7.5). Press the Rate Set (%) button again.
Mar 05, 2010 | Casio Office Equipment & Supplies
Manual for Casio MS-120TE Calculator or how to program exchange rates
press AC
press RATE SET, hold for approx5 secs till you see "tax" "%" displayed
type in new rate (say 20)
press RATE SET (to confirm 20% as new tax rate)
Done
Oct 19, 2009 | Casio Office Equipment & Supplies
Change tax rate for canon ls-100ts
To store Tax rate
Enter Tax Rate Figure eg : 10
Press 'Rate' button, then 'Tax+' button
This would set a tax rate of 10%
Jul 30, 2009 | Canon LS-100TS Calculator
Change the tax rate on calculator on MS-8TV
SETTING YOUR TAX RATE
you hold your set % button down for three seconds until set shows again, then hit tax rate button it shows your tax rate, change your tax rate then hit set your tax rate should be set.
cliff notes:
hold set% button
hit tax+ button
change the desired %
hit set done
Do rate the solution.
Mar 23, 2009 | Casio Office Equipment & Supplies
Tax button
under the GT button at the top, switch that button to the "Rate"..enter whatever % tax rate you want. Then move button back to off setting.
enter your number and hit the plus sign, then the tax+ button or the tax- button. it will automatically figure the tax for you. You may have to play with it a bit..I got the pdf version from the canon tech geeks, and the directions leave lots to be desired. Good Luck!
Oct 31, 2008 | Canon MP-25DV Calculator
Tax rate
press button CA then TAX+ and enter tax rate figure, then press TAX+ again to store.
Jun 15, 2008 | Canon TX-220TS Scientific Calculator
NEED TO SET TAX RATE
Solution #1 has it backward..
(tax rate), STR, TAX+ (or TAX-)
Example- San Francisco sales tax = 9.5% you enter 9.5, STR, TAX+.
now it functions as (amount entered) plus tax. Example- find the total with tax for a purchase of $14.99 14.99, TAX+ Calculator will show 16.41
Jun 05, 2008 | Sharp EL-2192Rll Calculator
RE: CASIO CALCULATOR MS-80TV
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
Oct 16, 2007 | Casio MS-80TV Scientific Calculator
Setting tax
try switching the top button next to GT to rate,then enter your tax rate then % (8.25%) then switch the top button back to on (or whereever you had it set to) and hit the tax+ button. That worked for me. GO TEXAS!!!
Sep 29, 2007 | Sharp EL-2630P Calculator
Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
Mar 13, 2007 | Casio MS-80TV Scientific Calculator
Sharp EL-1192BL Calculator Logo
51 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
