Question about Western Digital External USB 2.0 80 GB Hard Drive
Hello sir, my external usb is not working model no : WD1600XMS-00, S/NO : WXE108F36568 R/N : A4B Your service centre adderss plz im in pondicherry
  • persilvertec Nov 11, 2010
    If you have not already tried this, make sure to plug in the drive directly to one of the rear ports of your desktop computer (or possibly on side of laptop). Many times, drives are not recognized if you attach them to a USB hub, or to a USB extension.
    Brigadier General:
  • 10,406 Answers
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Note that W.D. has a "Customer Loyalty" program -- you can buy a new W.D. device, through the W.D. web-site, at a significant discount.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Posted on Nov 11, 2010
  • hookman170 Nov 30, 2010
    WD passport WD1600XMS-00 mini sata to usb adapter is my problem , need to locate replacement without luck.
  • ikkenom Dec 01, 2010
    Any computer-store will sell you an "empty" enclosure, with power-supply, and a USB-to-SATA adapter. Probably $30 to $50.
    Just "transplant" your SATA drive from your W.D. into the new enclosure.
Hello sir i have nokia 1209 cotact service problem plz giv me solution
Regarding your contact service problem you should refer to the nearest mobile service centre.
Thanks for uisng FixYa All the Best!
Aug 11, 2011 | Nokia 1209 Cell Phone
When I connect my wd passport, this massage appears "usb not device recognized". although the cable is working with other devices and the wd passport is also working on other computers (not my...
there is NO problem on you external hard drive..the problem is in your own computer USB port..try to uninstall the driver of your usb port.then try it again.
Jun 15, 2011 | Western Digital My Passport Essential 160...
Unable to connect my WD pass port to any computer MDL: WD1600XMS-00 SN WXE207612581 The blue light is on and lit but dont appear on the computer together with C Drive
If the blue light is lit, then it might be the USB cord. If you have a spare USB cord, try it and see if that works.
If could also be the USB port on the external drive enclosure. In which case, you may have to open the external enclosure and get a HDD dock or another external enclosure to access your drive.
Mar 15, 2011 | Computers & Internet
Dear Sir, Have Dell laptop Inspiron 1525 with Xp loaded....but external mouse is not working with my system but the USB port are working, Sir i need your assistant how do i do with it. Pls HELP...
You will uninstall all the usb universal root hub , and to do follow all the steep.
R- click on My com>Properties>Hardware >Device manager>Scrol the mouse down for select usbhub controller . Now you will uninstall all the usb and restart the raptop again.
If your problem will same ,change the usb MOUSE .
Think it is defected.
Hope it will help you.
Dec 31, 2010 | Computers & Internet
Hi i need usb driver for western digital / WD1600xms-00 my computer can't read my external storage plz help me waiting ur answer thanx
This may help you, I know this is a different External HardDrive but sounds the same problem.
My neighbour has the Seagate FreeAgent Desk 500GB (Externel HardDrive), and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t​=84 Thread can be found in 'Technical' under 'General Technical Issues' Dont worry if your a novice like me with computers, the guide is quite easy to follow...
Aug 20, 2010 | Computers & Internet
I have a WD1600XMS 160 Go. the first week It was
Try a different USB port... I'm assuming it is an external device. Also update your USB drivers if the system is older than 2 years and it is an XP machine. Other choice is to test on another PC to see if it replicates the problem. If you are not sure and you are within the warranty period... exchange it to be safe. Most HD's fail in a 60 day period... if you get past that time frame you are normally good to go.
Dec 31, 2009 | Western Digital Computers & Internet
Some times is my display not wroking
Service Providers of Project is done to the program
Address : 68 south car street, tiruchengode, Namakkal Dt, Tamil Nadu
Service Providers of Mobile Phone Communication Services
Address : 3/176 AB B Harathiyar Street, S. Papparapatty(Po), Attayampatty, Salem, Tamil Nadu
Feb 20, 2009 | Samsung Cell Phones
Phone locked! Please Contact service center!
My phone is giving message Phone locked! Please Contact service center!)
Dec 31, 2007 | Haier D6000 Cellular Phone
Western Digital External USB 2.0 80 GB Hard Drive Logo
455 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
