Question about Brother MFC-8860DN Printer
No Paper Error
I'm getting a "No Paper" error on my MFC-8860DN, there is paper in the tray, and when I turn it on or try to use it, all I hear is a clicking sound
  • 4 more comments
  • anclotefire Jul 08, 2008
    same problem as Talon52. Have to power printer off and restart it. sometimes it works, sometimes it doesn't. cheap chinese **** for $600.00. never buy another one.
  • Anonymous Aug 01, 2008
    No Paper error - paper is in tray. Have tried turning it off and on and it still doesn't work.
  • DebFP Aug 14, 2008
    Same as the others - machine will be printing fine then the No Paper message comes on. There is paper. I have no idea what is causing it. Everything looks fine and clean but it is very annoying. The printer is less than a month old - and it's only a 1 person office so it's not from overuse.
  • tedpjr Oct 18, 2008
    same problem-started after I loaded fresh paper in Tray 1 awhile back. sometimes it worked, sometimes not. after 2 weeks it quit trying.tried everything that brother suggests. prints fine from the MP tray. always defaults to "no paper" after anything is printed from MP tray.
  • dan7183 Mar 12, 2009
    MFC-8860DN "No Paper, reload paper in the MP tray" when I go to print from the computer, but if I power down and try to print a copy it works fine. So, I don't have a printer just a good copier. Any ideas?
  • Tyrchon Apr 20, 2009
    I have the same problem. The reason these solutions won't work is that the paper is lifting just fine, and feeding as well, but only when you are making copies or receiving a fax. It's only when you try and print that it suddenly tells you there's no paper. Then you have to reset the machine for anything to work at all.
  • 134 Answers
You could have two problems. One the paper sensor in the cassette could be jammed or broken, The clicking could be the sensor jammed next to the feed roller. If not it could be the fuser gear is broken.
Posted on Jun 17, 2008
A common issue i've had on the 8860DN's is the plastic shaft (axle?) that the cassette lift gear is on breaks and therefore the paper isn't lifted up to the paper sensor. As it's all part of the factory moulded fram you need to strip out the gear train, drill out the broken shaft and put a screw through to act as a stronger metal shaft. The catch is the screw can not protrude out into where the cassette slides in and the head of the screw must be very small otherwise a gear rubs on it and will give you a motor error.
I've had 3 machines do this and repaired them all in the same manner.
Posted on Mar 02, 2009
4 Suggested Answers
  • 3 Answers
SOURCE: Brother MFC 8860DN. ''No Paper'' error message and
Pull the paper tray out, look in the top middle by the roller holder, you will see a black plastic lever (edge actuator) hanging down, it should be flush with the roller, be careful when pushing back in place.
Posted on Feb 15, 2011
  • 215 Answers
SOURCE: No Paper Error
make sure you have an 1/8" gap between your paper and the rear paper stopper in cassette.
hth,
razors
Posted on Jun 04, 2009
puertobori
  • 7733 Answers
SOURCE: MFC-8860DN makes loud clicking sound
search at Brother International - Support for your Brother Product.
Posted on Oct 24, 2010
Brother mfc-8480dn no paper error I have a new brother laser printer and it is telling me there is "No Paper" but the paper tray has paper. I have tried removing the paper and reloading the tray...
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Jan 12, 2011 | Brother MFC-8860DN Printer
There is a loud clicking sound that comes from the drawer and the paper won't pull through. MFC 8860DN
You can check if the paper guides are set properly by depressing the purple lever on the right front of the tray. The leading edge of the stack of paper should rise out of the tray. If the paper cannot rise, or rises unevenly, you need to adjust the guide on the tray. There should be between 1/16 and 1/18 of play from front to back for the stack of paper in the paper tray.
The loud click sounds alarming, but is not the problem.
Sep 02, 2010 | Brother MFC-8860DN All-In-One Laser...
Brother MFC 8860DN. ''No Paper'' error message and CLICKING SOUND
Feb 01, 2010 | Brother MFC-8860DN Printer
Mfc 8660dn - how do i clear the no tray error
That error, usually means that the engine PCB is bad. If you call brother they'll tell you to check the print count, and if it's a certain number, all you can do is replace that PCB. It runs around $400.00.
Sep 24, 2009 | Brother MFC-8860DN Printer
No Paper Error
hth,
razors
May 27, 2009 | Brother MFC-8860DN Printer
MFC-8860DN
This is a common issue.
Here is the solution:
Pull out the paper tray
On the left of the feed roller there is a black piece of plastic that is a sensor. It is jammed forward. Gently bend it out to the left and push it back until it snaps back into place.
Be careful not to break it.
Oct 27, 2008 | Brother MFC-8860DN All-In-One Laser...
No Paper Light wont go out
is this still a current issue?
Jul 22, 2008 | Brother MFC-8860DN Printer
Brother MFC-8860DN Printer Logo
715 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
