Question about Gateway M-1625 Notebook
How do I disable the touchpad ? - Gateway M-1625 Notebook
    Brigadier General:
  • 8,909 Answers
Why would one wish to do that?
Go to Control Panel, then to Device Manager. Find pointing device and double click it. Now dissable the driver.
Re booting your Notebook will start it up again as it will look to refresh the driver.
Posted on Nov 11, 2010
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
Cursor problem
Disabling the touchpad on a Dell Inspiron can be useful when typing for long periods of time, or using an external mouse. Bumping or tapping the touchpad while typing can cause cursor jumping and unwanted results. Use the touchpad software to enable or disable touchpad controls. Download the driver for your touchpad at the Dell Support website.
Click on the "Touchpad" icon in the task bar. If the icon doesn't appear, you can download and install the driver for the touchpad from the Dell website, or choose "Start" and "Control Panel." Choose "Device Select" on the touchpad menu, or choose "Mouse" in the "Control Panel" menu and "Device Select." Click "Disable" under "Touchpad" to turn off the touchpad, or click "Disable Touchpad/Pointing Stick When a USB Mouse is Connected."
h
Feb 28, 2013 | Computers & Internet
Touchpad not active
Locate the "Fn" key in the lower right or left corner of the laptop keyboard.
The "Fn" key typically has different colored text on it or the key itself is a different color.
Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop.
The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it.
Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop.
Move your finger along the touchpad to verify that it works.
Press the combination at any time to disable the touchpad again.
hope this helps
Sep 05, 2012 | Computers & Internet
My touchpad has been disabled on my dell inspiron m5030
Hi c_louise_moo,
You can find some instructions on disabling the touchpad here:
http://www.labnol.org/software/disable-touchpad-on-laptop/14052/and this link has a piece of freeware called TouchPad Pal which allows you to disable the touchpad while you're typing (which should be the only time it gets in the way really) http://download.cnet.com/TouchpadPal/3000-2084_4-11143760.html
Hope it helps.
Thank You for using Fixya.
Sep 09, 2011 | Dell Inspiron M5030 Laptop
How to disable my touchpad on Dell Inspiron M5030 (only) when my Logitech external mouse is connected? Thanks.
You can find some instructions on disabling the touchpad herehttp://www.labnol.org/software/disable-touchpad-on-laptop/14052/
Hope this helps!
May 19, 2011 | Dell Inspiron M5030 Laptop
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Any way to turn off touchpad when typing ,etc
« Free Up Windows 7 RAM - Memory Cleaner Enable Administrator Account In Windows 7 » Auto Disable Mouse Touchpad When Typing By Nakodari on Nov 25 2009 28 Comments
It is a common annoyances with netbooks and laptops which lack the disable touchpad button. Most blogs out there are covering a single method to disable the touchpad, i.e, go to Control Panel > Mouse Properties and then disable the touchpad from there.
The above method is not suitable for those who need to disable the touchpad frequently for short periods of time. Who in his/her right mind would navigate back and forth just to enable/disable touchpad? This could be quite a hectic process.
TouchFreeze is a brilliant little app that solves this problem. It disables the touchpad temporarily the moment a keystroke is pressed. In layman's term, it disables the touchpad automatically when you are typing and enables it back when the typing is stopped.
It will sit silently in the system tray without disturbing any of your work. Just start typing and don't worry about the touchpad any more.
touchfreeze.pngI prefer using this app even though my notebook has a disable touchpad button. Please note that this app might not work with certain laptops, but should work with most netbooks and laptops that lack the disable touchpad button.
Download TouchFreeze
http://code.google.com/p/touchfreeze/
Nov 13, 2010 | EliteGroup 557 Notebook
How do I disable touchpad when mouse is used DELL 1525 vista home
Follow these steps to change the touchpad settings on your laptop:
1. From the Start menu, click Control Panel. With Control Panel in Category View, click Printers and Other Hardware.
2. In the Printers and Other Hardware window, click the Mouse icon.
3. In the Mouse Properties dialog box, click the Device Settings tab, and then click Settings.
4. There is a setting calleed "Disable Touch Pad when USB Pointing Device is present"
Jan 28, 2010 | Dell F3534 Touchpad
Touchpad not funjctioning on Toshiba Satellite L40/45 laptop
You might have inadvertedly disabled the touchpad.
1. Press Fn + F9 to enable the touchpad.
This key combination acts as a switch, enabling or disabling the touchpad: press once to enable (if it is disabled), then press again to disable.
2. If the touchpad still doesn't respond, check the settings in the mouse control utility.
Click on the touchpad icon on the right side of the task bar if you see one or click Start button/Settings/Control Panel, select the Mouse icon and Press Enter.
Change the settings if necessary.
Aug 17, 2009 | Toshiba Computers & Internet
Open Questions:
Gateway M-1625 Notebook Logo
78 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
