Question about Canon PowerShot G10 Digital Camera
Lensa error - Canon PowerShot G10 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 11, 2010
Error lensa when turn on the camera
You mean "lens error" this will need to be fixed by camera tech, this is not a user fix and there is no magic button to cure the problem.
Jan 26, 2013 | Nikon COOLPIX S8 Digital Camera
Lense obstracted
yaa. lensa saya tidak bisa menutup kembali, ketika di sambungkan ke pc terdapat tulisan lens obstracted. bagaimana cara mengatasinya?
Dec 20, 2011 | Kodak M522 Digital Camera
Lensa error !
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Oct 14, 2011 | Nikon Coolpix S210 Digital Camera
Power on lensa tidak mau keluar.muncul tulisan turn the power off and on again
Error: TURN THE POWER OFF AND ON AGAIN ditampilkan pada layar LCD saat Mekanisme Lensa macet atau ketika terpengaruh oleh kerusakan apapun. Jika memutar power on dan off lagi tidak menyelesaikan pesan kesalahan, coba lakukan reset kekuasaan dan Inisialisasi pilihan.
Melakukan reset tenaga manual
Matikan kamera.
Keluarkan baterai.
Tekan terus tombol daya selama 30 detik.
Biarkan kamera untuk tetap tanpa listrik selama 60 detik.
Masukkan kembali baterai.
Hidupkan kamera.
Untuk mengatur ulang Kamera kembali ke default pabrik, pilih Opsi Initialize dari Menu Utama Pengaturan 1 dari Kamera ke OK.This akan mengatur pengguna menentukan pengaturan kembali ke default pabrik. Gambar-gambar dan video tidak akan bisa dihapus.
Jika masalah berlanjut, mungkin diperlukan layanan.
Terima kasih telah menghubungi FixYa.
Feb 23, 2011 | Sony Cyber-shot DSC-W90 Digital Camera
E210
untuk mngatasi error 210 ini biasanya gir lensa patah,solusi terbaik yaiitu ganti lngsung gir yg patah dengan yang baru. PERHATIAN ; dlam memasang gir lensa harus bener2 presisi atau pas dalam artian tidak ada yg longgar. setelah gir terpasang dngn benar lngsng nyalakan mesin dan lakukan error kode *4*error*...jika masih error 210 brarti ada kelainan di mtor lensa tersebut. thanks ARIF FAJARRIANTO_PANGKALAN BUN.
Nov 05, 2010 | Canon NP 6050 Copier
Saya punya kamera digital kodakc142, tapi setelah di play hasil rekamanya g ada suaranya, tolong dong, gimana cara nya biar bisa punya suara
2 minggu yang lalu saya beli kamera digital kodak c142, tapi saat mau dipakai tidak bisa konek(terbuka)/digunakan, lensa sudah keluar tapi dimatikanpun tidak bisa, akhirnya saya lepas baterainya (lensa tetap tidak mau masuk). mohon solusi ya.
Oct 07, 2010 | Kodak EasyShare C142 Digital Camera
Porblem E210
check motor lensa (gear is crack),check sensor
Feb 18, 2009 | Canon NP 6050 Copier
Please help
What is the error code that is being the displayed on the control pannel???? It will help to solve your problem.
May 05, 2008 | Minolta EP1083 CS/PRO Copier
Canon PowerShot G10 Digital Camera Logo
87 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
