Hi, I have a universal wifi range extender wn2000rpt installed and a wireless adapter installed aswell. Now reading the next set of instructions it tells me to connect to NETGEAR_EXT, open a browser and type in a http to recieve the wizard to connect the extender to the router. But i cant find this NETGEAR_EXT, Also, the Link Rate Status is not lite. How can I get my wn2000rpt to work?
  • 1,606 Answers
NETGEAR_EXT is the name or SSID of the extender. ie Netgear EXTender ;-]
What you need to do is first search for available wireless networks. It should show up there as NETGEAR_EXT if it is running and far enough away from your wifi.
Then open your web browser which should then open the connection wizard . If not you can try www.mywifiext.net. If you can't see it you may need to connect to it using a wire so you can set it up. sometimes if it is really messed up you may need to reset it to factory default.
Posted on Nov 11, 2010
Comcast changed my wireless password and now my netgear extender doe not work
You will need to reconfigure your extender, check the manual or online at the link bellow.
Since your extender is not working your range is diminished.
WiFi Range Extenders
Oct 18, 2015 | NetGear Universal WiFi Range Extender...
I ask to join and they ask for password and i typed in password and it will let me join
Try using the same security settings as your existing network by selecting the "Use the same security mode" check box when setting the your extender.
Jul 02, 2014 | NetGear Universal WiFi Range Extender...
Bauhn
You dont need a cord.IPad has a built in wireless capability.
Apr 28, 2013 | NetGear Universal WiFi Range Extender...
Wn2000rpt refurbished installation
I found this answer online - but I didn't save where - I did add to it a bit after the ** Leah DH(:
Netgear WN2000RPT Setup Instructions
Maybe since I purchased a refurbished Netgear WN2000RPT it didn't come up with setup instructions but once I emailed support they quickly responded with the info below and it worked immediately.
Do this setup and your Netgear WN2000RPT range extender will work:
1. With the help of a paper clip, press the reset button on the back of the extender for 20 seconds (please refer to the label on the bottom of the extender for reset button location). Release the reset button after 20 seconds and turn off the extender. Turn the extender on after few seconds.
2. Connect the extender to the computer with an Ethernet cable. Make sure that there is no connection between your router and the computer either wired or wireless. (I did this part by turning off the antenna to my laptop)**I went to the Network and Sharing Center and on the left click on "Change Adapter Settings" after that right click on your Wireless Network Connection and choose "Disable". Don't forget to re-enable when you're done.
3. Open a browser to start the Smart Wizard. **I had to use Internet Explorer and compatibility mode
4. Please select your Preferred Language and click on continue.
5. Let the Extender detect the list of networks available in the locality.
6. Select your network and note down the security assigned for your network and click on continue
7. Type in the security key for your network,please note that if you have WPA security assigned on your network type the network key in passphrase box and if you have WEP security setup on your network type in the network key in the Key1 box and click on continue. **I've read elsewhere NOT to use WEP security with this extender.
(Read this one carefully)
8. Assign a name for the Extender as per your choice, also make sure that option "Use the Same security and passphrase as those for the existing network" is checked and then click on continue. **Under the step #3 Configure Extender I had to right click and refresh because there was no "continue" button!
9. Let the smart wizard establish the connection. On the next screen Click on the button "I have connected to the extender network" and click on continue.
10. Now click on the finish button to close the page.
11. It should ask you to save the page as bookmark, please save the page for future use.
12. Now open a new browser and check if you are online. (turn your antenna back on)**Re-enable your Wireless Network Connection.
13. You can now unplug the Ethernet cable from the extender and scan for the SSID of the extender and connect to it using the same network key as for you existing router.
The most important part of the Netgear WN2000RPT setup is that you should NOT just plug it in and use the setup wizard. The setup does not make it clear what you should do when you get to the page with Key 1, Key 2, Key 3 & Key 4. If you follow the directions above which I got by emailing to ask about Netgear WN2000RPT setup then it will work the first time without any problem at all. Just read the Netgear WN2000RPT setup instructions above carefully first and then go through the step by step setup instructions slowly, one at a time and be sure you do exactly what it says. If you follow the directions above you will find that you can do your Netgear WN2000RPT setup without any problem at all.
Need More Help?
Need more help? Don't call me! I only know that this worked for me and it was super easy to follow the directions. I don't work for Netgear and I'm not really a techie.
I own a Florida ad agency.
Feb 11, 2012 | NetGear WN2000RPT Repeater
Lost installation disc.. need help to install
This product was never released with a installation cd as per NetGear
http://www.netgear.com/products/home/wireless-range-extenders/wireless-range-extenders/WN2000RPT.aspx
But I found this that might help
http://kb.netgear.com/app/answers/detail/a_id/14239/~/wn2000rpt-faqs
Feb 28, 2011 | NetGear WN2000RPT Repeater
How to setup Netgear wn2000rpt extender? Netgear setup wizard does not appear automatically and can't be accessed from its www site.
Try this to set up your Netgear Range Extender-
1-Plug the Extender to Power Outlet and Turn the device on.
2-Now Go to Your Computer And At The taskbar, you can see WiFi Icon Please Click On That Wireless Icon.
You may see many networks including New network by the name of Netgear.ext.
3- Now Please Click On Netgear.ext and Connect With It. Once You Connected Please Open Your Browser Like Chrome, Firefox Or Microsoft Edge
4- On The Top of your Browser Please Type Mywifiext.net And Press Enter Or Go. Now It Will Take You to Netgear Configuration Portal.
5 - Please Click On New Extender Setup And Register Your Extender With Netgear Using Your Email. Please Create the Account.
6- In The Next Portal Will Ask You To How you want to use your extender Please Select WiFi range extender
7- Now It Will Search For Network And it may give you a list of wireless networks. Please Select Your Main Router Network name And Hit Next
8- Please Input Your Existing Network Password (Main Router Wireless Password ) And Click On Next
9- Now You Can Change the network Name On Next Page As Well As Password for Netgear extender Than Click Next it
will Apply All Settings And It Will Show you all information about New Extender.
10- Once the settings Have Been Saved Please Restart All Devices And Place The Extender In The Range of the main router anywhere.
For more details visit
How to Setup Netgear Range Extender Mywifiext net
Feb 05, 2011 | NetGear WN2000RPT Repeater
Do not know where to find NETGEAR_EXT
hi, I have a universal wifi range extender wn2000rpt installed and a wireless adapter installed aswell. Now reading the next set of instructions it tells me to connect to NETGEAR_EXT, open a browser and type in a http to recieve the wizard to connect the extender to the router. But i cant find this NETGEAR_EXT the only thing i have to it is wlan_ap_EXT which i cant connect to.
Oct 29, 2010 | NetGear Computers & Internet
Computers & Internet Logo
1,420 people viewed this question
David Payne
David Payne
