Question about Janome Memory Craft 10000
I have been trying to put designs from my computer to the machine but can,t get it to work. I am sure I am missing a step for doing this but don,t know what it is. PLEASE HELP!!!! Thank You Lucile
  • 2,071 Answers
Lucile i only get you a site where to download and upload software about janome and some reviews and testimony one who bought janome already www.epinions.com
Posted on Jun 17, 2008
    Genius:
  • 3,422 Answers
Please CLICK HERE to view the user manual.
All manuals are available in PDF Format and require Adobe Acrobat Reader. Click here to get the free Adobe Reader.
Goodluck..
    Master:
  • 555 Answers
Do you have a manual for this sewing machine?
On the last step of the design, the carriage resets and is now off by 1/8 inch. I tried resending the entire design and skipping to the end but it did the same thing. Any suggestions on how to manually...
From my experience, I just have to quit the design, close & exit from the program,switch off the machine as well as the computer.
Disconnect the embroidery unit & connect back ensure is properly
intake.Manually push the carriage to the left/right several times.Then manually push the hoop up/down the carriage, stop there, ensure USB is well connected at both end, switch back machine n computer & try work on a simple design first, if OK then redo the earlier design. If similar problem occur it is the design problem itself. Hope this can help.
Oct 10, 2013 | Singer Quantum XL-6000 Computerized Sewing...
Transferring
Jun 17, 2008 | Janome Memory Craft 10000
I want to know how do i start using this machine?
I have a Futura, different model but im sure the same instructions. You have to put the software that came with it on your computer. If you dont have it you can download it from the Singer website. Once you have the program on your computer you must have the USB cord plugged into the machine and your computer. Turn your machine on, then open the program on your computer. You must ALWAYS do it in this order. It will not allow you to open the program without being plugged into the machine. You can however plug it in, open the program and then unplug it from your computer and still work inside the program. Once you have your design ready you want to make sure you use good stabilizer specific for embroidery. Make sure to stretch your fabric tight inside the hoop and place it on the machine. Then all you have to do is tell it to transmit to the machine and press the start button! I use mine all the time and love it! Once you figure it out it is easy and so smooth that you can walk away while it is doing its thing! Good luck!!
Dec 16, 2012 | Singer CE-200 Quantum Futura Computerized...
What do I need to connect my singer quantum xl-100 to a computer so I can use other embroidery designs.
You will need a converter box that hooks up to a computer and writes to a card that fits into your sewing machine. Singer PSW 1,0 (box and card), OESD Magic Box (4 slot), and Amazing Designs Amazing box (also 4 slot) will do this. You will also have to make sure these boxes come with a blank card. Amazing Designs and OESD cards MAY be interchangeable. Not sure about the Singer card. In regards to the Singer Card--there are 2 types. Make sure the one you get is for the XL100 or XL1000. XL5000 on up is different. Singer, OESD, or Amazing Designs no longer support Singer XL100 so you will have to go to EBAY. These items are rare but they do pop up a few times a year. ALSO, the software only runs on Windows XP. Don't know if there is a patch, but there is a Yahoo group that deals with Singer XL100/1000. Good Luck
Oct 02, 2011 | Singer Quantum XL-1000 Computerized Sewing...
My machine isnt threading the bobin underneath.
Do you have the right needle in your machine? There are some Sergers that take shorter needles and I have has some customers put those short needles on thier sewing machine. If the needle is too short it cannot pick up the bottom thread.
If that isn't the problem I would also try to rethread the machine and the bobbin. It sounds very simple, but sometimes you can miss a step
If none of the above don't work, you may have a timing issue. Have you run over a pin? or had the needle come down on a presser foot? Sometimes these sudden stops can knock the machine out of time.
Apr 21, 2011 | Brother CS-100-T Computerized Sewing...
Have futura 200. Was embroidering a design and
I had the same problem, go head with machine off and embroidery unit off also turn wheel toward you. If it still won't go try winding a bobbin that is what happened with mine it seemed to undo the stiffness. You can also take the cap off the wheel and make sure there is no thread wound around it.
Good luck if this does not work there are other tips but it would take all night to email all the steps.
sewsecksy@yahoo.com
Apr 21, 2009 | Singer CE-200 Quantum Futura Computerized...
I have a futura 150 and I can't get it to change hoop settings. I will put the small hoop on it but it doesn't recognize it. What do I do to fix it. It will change it on the computer screen but doesn't on...
Do not switch on the machine with the small hoop attached. After changing the hoop reload (close and open again) the design or restart the software or select the small hoop manually from the menu.
Aug 26, 2008 | Singer CE-100 Futura Computerized Sewing...
Brother PED-Basic Driver?
Dear Kooks57, you have not deleted your designs, the program, card reader and card you purchased are for downloading designs from the internet or a computer. You will find free designs all over the internet including Brothers site. To use the reader you will download your designs from the internet or another card with designs on it and put them in a specific folder on your computer, then you can tell the Basic program to seach that folder and move the designs you want to the card in the reader. Once the designs have been moved to the card you can use it in your machine. Hope this helps if you need more help please follow the user instructions step by step and it should get you where you want to go, See page 8 in the manual.
Gale
Mar 21, 2008 | Brother SE-270D Computerized Sewing...
Designer 1 embroidery problem
If the machine is reading the file to not be found it is probably that the designs are on the floppy but the person sending did not read them to the floppy right. they should have been read thru the softwear.
Dec 28, 2007 | Husqvarna Viking 1
Help
It probably needs to update with the Singers program, it might have a deleted memory file or something so you really need to find somewhere you can possibly get online. Sorry
Aug 02, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
215 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
