Question about Akai LCT3285TA 32 in. LCD Television
My akai lct3285ta only gives me the akai welcome screen then goes dark- any thoughts
    President:
  • Akai Master
  • 1,779 Answers
Sounds like a bad Inverter board, or just the capacitors on it.
Posted on Nov 11, 2010
How do I adjust to full screen on my Akai-LCT3285TA without the remote?
If it has a format feature it will usually only be on the original remote--if using a box of some type look for the feature to also be there.
May 06, 2012 | Akai LCT3285TA 32 in. LCD Television
My akai lcd 32.5" tv will not stay on and all it does is flash the blue screen with akai then turns right back off and i was thinking power suply might be bad. what could it be?
You could be right it sound like the power suply, has it got a AC adaptor power suply,bit like a laptop charger? goes from mains to a black box then from box to the TV?
does it stay on at all?
Oct 01, 2010 | Akai LCT3285TA 32 in. LCD Television
IS THE AKAI LCT3285TA A COMPUTER MONITOR TOO
check on the back side if they got the vga connector to the cpu
May 07, 2010 | Akai LCT3285TA 32 in. LCD Television
Im having trouble hooking up my desktop computer up to my Akai LCT3285TA tv? what am i doing wrong? I have both VGA hookups connected and screen says not supported?
The screen indicates 'not support' because the resolution you are try to feed the TV exceed the maximum it can display, you need to set your computer video out put resolution the TV native resolution, which you need to find out by download the user manual here: http://www.retrevo.com/support/Akai-LCT3285TA-TVs-manual/id/741bh147/t/2/
Dec 15, 2009 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA Television won't turn on
the problem is in the power supply(they know about it good luck fighting them)but there is good news.you can remove the power supply and replace electrolytic caps,EC18,EC19,EC20 all of them are 1000mf at16 volt use 1000mf at25 volt.you can also go to shopjimmy.com enter model number you will see power supply part number MLT169B
it will be cheaper for you to replace the caps,the board cost about $80.00 from them
Sep 24, 2009 | Akai LCT3285TA 32 in. LCD Television
Power supply board needed from a Akai LCT3285TA 32" LCD TV
Go to partsstore.com this is where I found the power supply board for this TV.
Jun 30, 2009 | Akai LCT3285TA 32 in. LCD Television
Damage lamps interior around the screen AKAI LCT3285TA LCD 32"
You can purchase parts for your television at:
circuitcity.partsearch.com/Model/Akai/Akai/LCT3285TA.aspx
or
www.looking4parts.com/search/?custid=4582&PIndex=47
or
tigerdirect.partsearch.com/Search/Model/Akai/Akai.aspx
or
www.shopjimmy.com/searchparts.cfm?make=Akai
or
www.partstore.com/
or
www.akai.com/
Jan 17, 2009 | Akai LCT3285TA 32 in. LCD Television
AKAI LCT3285TA static noise
Which input connections are you using?
Jun 07, 2008 | Akai LCT3285TA 32 in. LCD Television
Volumne on Akai LCT3285TA
Often a signal might experience a super-quick "drop" in signal strength, and the display is automatically adjusting the now weaker audio signal to "mono" (temporary, as for best quality). But the dropout is usually so brief you will then see the "stronger" signal restored [full strength], and now the audio is "stereo".
It's like a "bump" or "disturbance" that occasionally affects the cable/satellite/OTA (antennae) signal being fed into the TV, and your display's attempts to compensate for the weaker signal [going to mono, then back to stereo once back to full strength].
Connecting it to your cable directly (bypassing the box) or an antenna would give you a true over-the-air signal, which would be proper MTS and would not give you any more pop ups.
Jan 05, 2008 | Akai LCT3285TA 32 in. LCD Television
Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Oct 30, 2007 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3285TA 32 in. LCD Television Logo
62 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
