Question about LG WM2487H Front Load Washer
LG FRONT LOAD WASHER WONT TURN ON
It started filling with water then just clicked off, no juice.
  • mgb061 Apr 14, 2009
    My power went off during the spin cycle. The washer powered back on fine and I finsihed the spin cycle and the next time my wife went to turn on the machine, it did nothing. No power. I ran the extention cord from a known good outlet as it was faster than digging out my meter. Still dead. LG tech can and said it has a blown board and it is scheduled to be replaced in 2 days. I plan on being there for the repair and will possibly put a surge protector on the unit.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
Hard call, double check the outlet to make sure it is good, take off the top lid. 2 screws at the back then push it back.
Check to see if you have voltage once the line has gone through the noise filter. If no power there, you have a bad filter. If you have filter, see if you can see a red led light on the main board. no then it is a bad board. If there is a light then then check to make sure it is not a loose connection.. Make sure all your connections are good to the front display.
After all that, if it still isn't working then it goes back to the main board.
tricky one there.
Sgt 48
Posted on Jun 18, 2008
LG WN1832CW does not fill with water
The fill valve may be defective or there may be a controller malfunction that prevents the fill valve from operating.
Nov 22, 2013 | LG WM-1832C Front Load Washer
Our LG Klasse front load washer won't turn on
check from power supply to the unit. If the controller is leeting the water inlet open and filling then the program must advance. If not the controller orr the valve can be faulty.
If the water fills and there is no response then check voltage to motor, check water level controller. If water inlet valve cuts off then the prrogram is advancing , check motor voltage, if absent check controller unit.
Sep 12, 2010 | LG WM-2277HW Front Load Washer
WATER IN WONT DRAIN OUT
The water inlet Solenoid is open. Check the Solenoid. Give gentle tap it may re seat again. Finally replace if it is not settling!
Apr 05, 2010 | LG WM-1832C Front Load Washer
How do you get rid of the moldy smell in my front load LG WASHER?
There are some products out there that you can purchase from any Walmart or Grocery chain but what works real well is a mixture of concentrated lemon juice and water. You can make a permanent solution for this use by taking a spray bottle and filling wih 2/3 water and the rest lemon juice, (concentrated), and praying this around the boot and then wiping dry.
Jan 31, 2010 | LG WM-2277HW Front Load Washer
Why wont the hot water shut off to the machine when i turn the tap on. It is like the hot water is filling in the washer?
The water inlet valve where the water supply connects to the washer is stuck open because of sediment or wear. Replace it or clean it out.
Jan 26, 2010 | LG WM2688H Front Load Washer
Indesit wd125 drum wont turn
check your pump it may not be working
Dec 18, 2008 | Indesit W 123 Front Load Washer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WM2487H Front Load Washer Logo
303 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
