Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
My compresor do not stop when reach the max presure i want to think becaus it is not automatic stop
  • 134 Answers
It should have automatic stop they all do for safety reasons.
Posted on Nov 11, 2010
The presure washer head will not turn or will stop turner when engaged
The head probably needs some cleaning. I use a spray bottle of general cleaner. Then I'll shoot some wd40 in the head.
Jun 09, 2014 | Homelite Pressure Washer. 2600 psi 2.3 GPM...
A/c compresor not engaging
Yes, freon must be present in the system in order to circulate the oil that lubricates your compressor. A low pressure switch is used to stop the compressor from running if the freon level/pressure is low. This is to keep your compressor from destroying itself due to lack of lubrication.
There are also several other reasons that an A/C compressor will not engage. Proper diagnosis is required.
May 19, 2012 | 1995 Buick Skylark
The a/c has a restriction & will not allow the Refrigerant to charge up. Can you tell me if this sounds like a metering device problem, or a drier blockage, or both?
this sound from expansion valve , befor refrigarator . this valve for balance presure between high/low presure lines . the drier should replace (more laod to compresor ) leve the vehicle for 20min and check persure high/ low mustnot big difrent
Jul 06, 2011 | 2000 Volkswagen Beetle
Duo therm air conditioner that the compressor will not start
Hello,The freezestat should be closed.Try jumping that out .
Apr 18, 2010 | Dometic Rooftop RV Air Conditioner
BEVERAGE COLLER IS KEEPING THING COLD BUT NEVER SHUT OFF
Most of this coolers the fans inside runs all the time ,the compresor is the one that stops when it reaches the temperature you've set, but if the compresor never shuts off and it colds ok ,either the cold control is set too low ,its sensor is loose or it doesn't work properly and needs to be replace.
Apr 22, 2009 | KitchenAid Refrigerators
AC compressor not engaging
Hi, you should never bypass the compresor because it may cause damage to the sistem including the compresor,even if the sistem is charged if it gets a little low it may prevent the cluth to engage to prevent damage ,be sure that you have the proper freon presure.also check the ac relay and the fuse.....good luck
Jul 21, 2008 | 2000 Ford Mustang
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
50 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
