Question about Proform 695 LT Treadmill
Belt slips and somtimes stops on me while walking.
  • 42 Answers
Hi. if the belt slips and stops when your walking its a sign the you may need a replacement belt. and if you smell motor burning after you have been on for a while that is a sign that a/ you have no oil left and b/ your motor is slowley packing up.hope i have helped.
Posted on Nov 11, 2010
Testimonial: "Great. Thank you"
While using my Nordictrack a2550 this morning, the walking belt began to slip very badly. I checked the alignment and adjusted the tension of the belt as per the user's manual but the belt stills slip...
if it really is the walking belt that is slipping keep tightening the adjustment screws till the belt will not slip when you try to stop it ( set speed to about 3 and then with your foot try to stop belt from spinning - you should be able to make the motor and whole machine come to a stop ) make sure it is really walk belt spinning and it isnt the motor belt slipping. (if it is motor belt slipping when you try to do the stop the belt trick i just described you will see the walk belt and front roller stop but still hear the motor turning) once you get walk belt tight enough so it doesnt slip then you can worry about keeping the belt centered.
let me know if you need more help on this and let me know how the stop the belt test went
good luck!
Mar 25, 2011 | Nordic Track NordicTrack A2550 PRO...
Belt is slipping and I need to know what maintenance I should be doing on this model as I have no manual for it.
Hello, There is no maintenace required. Some people like to oil the walk belt, The manual say to do this annually. To do this you loosen the walk belt and applty some synthetic oil to the walk board under the walk belt, then tighten the belt and the belt will distribute the oil where it needs to go. As far as the walk belt, just make sure that is stays in the center of the walk board. Now your front roller and drive belt. The roller does not get serviced, it has perminently sealed bearings. The drive belt usually lasts for many years, if you remove the motor hood and see alot of black dust, it will be the belt. At that point you need to see why it is comming apart/rubbing. After you determine that, you would want to replace it.
The slipping you are describing could be the drive belt slipping on the front roller or the drive pully on the front roller. To find out you need to remove the motor hood nad get on it and look. What you will be watching is the drive belt as it goes from the drive motor to the drive pully. When you try to stop the walk belt you will either stop the drive belt or stop the walk belt. If you stop both, the drive belt is at fault, if the motor keeps turning. If you stop the motor, the motor or the controller is bad. If you stop the walkbelt and not the drivebelt you have a bad drive pully on the front roller, and need to replace the front roller. When you do this you need to remove the drive belt, this is a ggod time to replace it.
Hope this helps, rate my solution if it helped you. Thanks, Matt
Jan 09, 2011 | Proform 495pi Treadmill Frontdrive Roller...
Belt slips when walking
hi, if the belt is slipping then its too loose, if you can lift more then 2/3 inches off the base then its way too loose. at the back end of the treadmill there should be two bolts turn each one half way round and try walking if its still slipping then tighten them abit more until the belt stops slipping,
Nov 23, 2010 | Exercise & Fitness
When I step on the treadmill, the runner stops and
Unplug unit then remove motor shroud the walk on the belt normally and try to stall the belt to make it slip. Be careful during this test. If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled.
Find the set bolt(s) on the motor. This is typically run through only one side of the motor mount or may be on both sides but it does not run the full length of the mounting..
Look for a bolt that will tension the motor. If it has this bolt, it typically runs in the same direction parallel with the drive and walking belts. If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt(s) that are described in Step If your treadmill is equipped with this bolt (very few are) the repair will only require one person.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller.
If the walking belt slips when walked on. Using the allen wrench, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 27, 2010 | Proform 575 Crosstrainer Treadmill
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.
May 22, 2010 | Bowflex Treadclimber
I need to tighten the belt, it keeps slipping while walking on it
Unplug unit then remove motor shroud then do the following: If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley.
1) Adjusting the running belt if the problem: If the walking belt slips when walked on, UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
2) Adjusting Drive belt: Find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability. Some models have a single jack bolt and others have an auto tensioner. Single jack bolts are the easiest to adjust.
May 14, 2010 | Proform 860 Competitor Treadmill
Reebok 8050es treadmill walking belt has started slipping/skipping. It has been oiled and it is 2 years old.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both rear roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) above the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.If you still have slipping then the drive belt under the motor shroud can also cause this problem unplug unit remove shroud then plug unit in start it up observe the front roller to see if it stops if it does locate the tension adjusting bolt by the motor loosen motor mount and proceed adjusting until slipping has been eliminated
May 05, 2010 | Reebok 8050 ES Treadmill
Belt stops/slips
Sometimes tightening the belt is not the problem> What I would be doing is to get on the machine a determine which of the belt is actually slipping. What happens if the drive belt is glazed slippage occur no matter what you do. With the running belt you may have to it limits of adjustment and the belt can be stretched that no matter how you adjust it it will slip!!
Mar 14, 2010 | Weslo Exercise & Fitness
Belt slipping have tried to tighten, just bought used
When the belt slips, it can be 2 different places. The trick is to look at the front roller when the belt slips. If the front roller stops with the walking belt, then the drive belt (between the motor and front roller) is loose and can't be fixed by tightening the walking belt. If the drive belt is slipping, it needs to be tightened or replaced. I need the brand and model number to help you further.
Mar 06, 2010 | Exercise & Fitness
Belt stops when i walk on it
with item going 2mph, stand on foot rails, hold on handles,with one foot try stopping walking belt-look at front roller while doing this-if walking belt slips around frt roller, its the walking belt loose. at each corner there is an adjustment,with proper allen wrench, turn CLOCK WISE one turn EQAULLY on each side!! Then recheck,keep doing this untill it quits slipping-Small moves is best don't crank.
Now on other hand if walking belt Stops with frt roller, its the MTR dr. belt under the hood, to tighten,with 2 9/16th wrenchs, I loosen mtr mount bolt,with one hand apply pressure to mtr, retighten, or have wife apply this pressure with her foot,but don't over tightn-u want to turn belt 1/4-1/2 inch on side. Also check walking lube under walking belt!!
Jan 06, 2010 | Proform 760 CrossTrainer Treadmill
Proform 695 LT Treadmill Logo
484 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
