Question about Bionaire BT200RCU Tower Fan
How do I open this fan, so I can take a look at what is rubbing against the plastic and making the loud screeching noise
Screeches when I cut wood
open the front and watch it when you turn on sounds like you have a piece of wood stuck somewhere
Apr 01, 2015 | Central Machinery 9" Bench Top Band Saw
Screeching noise upon start only.. Not sure what it could be
Check ur fan belts/ serpent belt .open hood you stand in front of car have someone start it and see if make noises
Jul 16, 2014 | Cars & Trucks
My dehumidifier is making a very loud noise
With the unit unplugged, open the cover and check the alignment of the fan. If the fan is stuck or rubbing against the fan cowling, adjust the fan motor's mounting hardware so that the fan turns freely.
Take care.
Aug 12, 2010 | Kenmore Dehumidifiers
I have a rooftop unit 10tons when i turn the fan on it makes a rubbing sound i remover the fan and the motor the motor make no noise I changed the berrings in the fan but it still makes the loud rubbing...
the unit may settled and it is rubbing against something it may be the cover...run the unit on low and see then to high that may lead you to the location good luck
Sep 08, 2009 | Heating & Cooling
Loud fan
The fan is rubbing against the fan shroud. it may be misaligned or, the shroud has become loose. try aligning the shroud or making sure that it is screwed on correctly. The shroud mounting screws can become loose. This will allow the fan to rub against the shroud. this will create a loud noise. If during the inspection of the shroud you find that the fan is not rubbing against the shroud, this will confirm an issue that concerns the integrity of the electric motor sator assembly. the windings are bad. have the motor replaced if this is the case.
Aug 07, 2009 | Samsung Refrigerators
NEC VT 440 Projector noise
The unit needs to be opened and have the fan checked. If it is out of warranty and you are capable you should be able to access the fan quite easily. It may be rubbing against something or it may have contaminants inside and needs to be replaced.
Jan 25, 2009 | NEC VT47 Multimedia Projector
Loud thumping noise in rear air
Hi, you should check if the blower plastic fan is rubbing against the fan housing ,they get lose with time and make those noises.good luck C1...
Nov 27, 2008 | 2003 Chevrolet TrailBlazer
Bernina deco noise
See if drive belt is not running against the plastic body on right side.!
Nov 17, 2008 | Bernina Bernette Deco 600
Bionaire BT200RCU Tower Fan Logo
50 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Steve F
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
