My pc turns on but will not boot up. It glitches on the emachines symbol. F11 will not work and neither will pressing F8 repeatedly. It was working fine for about 2 or 3 days and then did a crash dump. Now it won't even boot or let me enter safe mode. Pleae help.
  • 1,179 Answers
I suggest taking a look at my tip regarding this matter it is entitled My Computer is not turning on!!! Is it dead!!! No POST!!! this should get it going again.
thanks
damnor01
Posted on Nov 11, 2010
Emachine fans
upon turning on keep hitting f8 repeatedly to get to the bios menu and check your boot sequence
Sep 14, 2013 | eMachines ET1161-03 PC Desktop
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Can't install windows
If there is a boot menu you may have to load the CD drive from there and the restore disk will load. Check the boot screen when the PC is first turned on and look for restore option and which key to press. It is usually F10 or F11. If all else fails press F8 on start before the first boot screen vanishes and select the prompt option. then load the CD from there after you ID the drive letter.
Sep 16, 2012 | E-Machines eMachines Desktop PC
I tried to do a system recovery by restarting the computer and holding the f11 key but it wont go in to the restore screen mode
You have to keep pressing it during the boot sequence. Can you get F8 to work? You can try having windows restore your last known good configuration.
Apr 15, 2011 | eMachines W3611 PC Desktop
When i turn on my computer it glitches and restarts repeatedly. need to do a system restore, but nothing seems to work. it is an emachines EL1200
Micahs
What triggered the problem? do you know? did you recently change anything? install any new programs? etc.
Do you get any error messages? Do you see the windows loading screen and then it just reboots again?
Try this first: HIt F8 when it is trying to boot, and if you get to select boot using Last Known Good settings. See if that helps. If not we can try something more advanced.
Jan 18, 2011 | eMachines EL1200 PC Desktop
When I boot I get as far as a screen that
Have you tried pressing F8 at boot time and booting in "safe mode". Then you can think of a solution.
Jul 27, 2009 | E-Machines eMachines Desktop PC
My laptop wont turn on fully
you could have a boot virus. to restore, switch on laptop and repeatedly press F8 key until you get a boot option screen. you can select the bottom option, to go back to the last settings that worked. if this doesn't fix the problem, then you can restore your laptop using either the F10 or F11 key when you switch on your laptop. one of these keys takes you into system restore. you may have to press the Alt key + F10 or F11.
Jul 17, 2009 | Acer Computers & Internet
Machine won't boot to win xp
You have two choices:
1) Insert your e-machine system disk and boot from it. It should ask you if you want to install Windows or repair it. Choose R for repair. Then when you get the black screen with white writing, choose your windows installation (usually #1) and then press enter when prompted for a password. When you get the c: prompt, type chkdsk /r
This might fix it.
If not, then try the process again and don't choose "r" but continue through the screen when it asks you to accept the Microsoft agreement by pressing F8. Then on the next screen choose to repair the existing version of Windows. It will reinstall the system files and may actually fix your problem.
Feb 19, 2009 | eMachines T3406 PC Desktop
Emachine T5224
Repeteadly Press F1 during boot. Then at the menu press F8 to go to advanced options. Then select System Recovery, and you can get into the recovery manager to restore the original factory system.
Jul 07, 2008 | E-Machines T2742 PC Desktop
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
