Question about Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit
My DW928 Dewalt drill is making sparks and smelling in the area of the brushes. I replaced the brushes and it is still doing it.
rowdy45176
  • 2176 Answers
SOURCE: Unable to get to brushes on DeWalt DW959 drill type 1.
the brushes are made to slide into the side of the motor. gently pull up on them. Also I would recommend that you go to Dewaltservicenet.com and type in your model number for a parts explosion and part number for replacement brushes. Let me know
Posted on Jan 11, 2009
  • 103 Answers
SOURCE: Ryobi cordless drill burning smell
your over using the drill on havy jobs
Posted on Apr 12, 2009
  • 25 Answers
SOURCE: 14.4v dewalt xr2 drill
Some cordless Dewalt drills do not have open motors allowing access to the brushes. However there are a few styles that do.
If you want to check, open your drill. Remove the screws from the housing. Then remove half of the housing. You can see the motor at the back of the tool. If there are vents at the back of the motor you may be able to see the brushes the removable type are connected to a gray or tan piece of plastic mounted at the back of the motor.
If the brushes are from a removable style you can purchase a brush set. If they are hidden in the motor. You will have to change the whole motor.
You can check the Dewalt Service Net web site to find out.
Posted on Apr 23, 2009
  • 12 Answers
SOURCE: Dewalt Drill DC728. Chuck came out of drill body
If you find that the end of the screw inside the chuck is actually broke then you have a gear problem inside your drill. This is actually a very common problem. Sometimes people push too hard on their drills and the gears inside wear out and break. This prevent the motor from wearing out, but, the gears have to be replaced.
If it is the gears and not the chuck. you broke the minimium of the front gear or gears inside your drill. YOU CANNNOT repair gears. they need to be replaced. you may be able to find some off brand gears to work but, you run the risk that they are not as strong as your original ones, or may not be exactly grooved correctly.
so, if replacing your chuck does not work. find replacement gears. IF you cannot find the gears from the manufacturer see about replacing your drill.
If the chuck is still good, keep it. If you buy the same model, keep your old drill for replacement parts, ie, switch, armature, cord, etc.
hope this helps somewhat.
Posted on Jun 11, 2009
brewerstool
  • 141 Answers
SOURCE: how to change the bushes on a Dewalt DW928 14.4V
You will need to get part # 389025-00 which is the brush pair kit. Remove the 8 torx screws from the right side handle half. Make sure you have the drill on its side and pry the handle half off carefully. Make sure not to disturb the insides too much. You could possibly mess up the transmission setup if care is not taken. After removing the handle half you want to take out the motor, switch and transmission all together. Remove the motor from the transmission taking care not to let all the insides of the transmission fall out. You will not like having to figure out how all those gears go back into the transmission. If you have a piece of duct tape handy, I suggest putting it over the transmission so you don't hit it accidentally and send small gears flying. ( I have done this on numerous occasions) Once your transmission is safely away from the motor you can pry out the whole brush block with a flathead screwdriver. The brush block just slides out. I suggest you do one side at a time and replace both the brush box and wire. Make sure you use the correct color wire and replace it exactly as saw the original. DC switches and motors can be damaged if you wire it incorrectly. All it takes is one squeeze of the trigger to ruin either when wired wrong. After replacing the brush blocks you can reassemble the drill. Take note that there are tabs on the transmission that have to line up properly with the handle half in order to seat properly. Any questions please post and I will answer.
Posted on Oct 25, 2009
Dewalt dw983
It could be due to bad brushes or commutator. You would see lots of sparks coming from it.
Apr 26, 2013 | Dewalt DW983K-2 Battery 1500mAh, 14.4V,...
Dewalt 18v xrp clutch slipping and electrical smoke smell in rear
Yes you can. Depending on the model of the tool it may not be the clutch causing your problem though. On some models the transmission is more likely the problem. Brushes create an ozone smell when the motor runs so that could be the smell. Does it run slow or get hot?
Jan 01, 2012 | Dewalt 18 Volt Compact Drill Kit
Hi i have a dewalt DC 988 combi drill, 4 years old. its starting to have a burning smell when used what are possible problems and solutions?
It all depends on what is burning I'm afraid. When in use, run your hand around the back of the machine and handle area to see if anywhere in particular is getting hot. On the older versions of these (DW988) the leads leading from the switch to the brush holders would overheat and burn, also causing damage to the brush holders themselves. Is there any smoke coming from the rear vents, if so you wil probably find it is a motor problem and the smell would be the insulation burning off the armature. The only other thing to check would be to make sure the battery isn't shorting and getting hot, as this could also cause damage to the switch and vice versa.
Feb 10, 2010 | Dewalt DC988ka 18 - volt XRP 1/2''...
Hi, I have a dewalt dc925 drill. When running the
They all do that a bit. The sparks when starting up and stopping are normal. If it has been used alot brushes may be a good idea but before they need to be changed it will spark quite a bit.
It will not hurt to inspect the amount of brush material remaining.
Jan 04, 2010 | Dewalt DC925 Cordless Drill
18v dewalt battery gives off burning smell
18v is one of the newer models, correct? And the drill is new? If so there will be some smell as the motor breaks in. The srmsture is varnished as well as the windind for the commutator. The first few times it get s warm/warm from a heavy load, You will smell it. I would say there is nothing wrong at this point.Do not overload the motor and avoid drilling at low speeds. Use the variable trigger at low speed only for starting a hole. If you are driving screws start the screw,then full trigger driving it in. Good Luck, Ned
Nov 06, 2009 | Drills
How to change the bushes on a Dewalt DW928 14.4V
Oct 24, 2009 | Dewalt 18 Volt Compact Drill Kit
Makita cordless drill 6011D
Here is the schematic for you: http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/makita/6011D
If it is running just fine and meets your needs I would just keep on using it.
May 16, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Dewalt DC727KA 3/8" 12v Cordless Drill/Driver Kit Logo
795 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
