Samsung S3650 Corby / S3650 Genio Touch Cell Phone Logo
Posted on Nov 11, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to update this phone - Samsung S3650 Corby / S3650 Genio Touch Cell Phone
Anonymous
Level 2:
  • Expert 337 Answers
  • Posted on Nov 11, 2010
Anonymous
Expert
Level 2:
Answers
337
Questions
0
Helped
116353
Points
685
You may contact the service provider.........
My Nokia 928 worked great for a year, now all of a sudden, it's over heats extremely and it will not charge at all. I am using the charger that came with the phone when it was purchased. Anyth
  • Is it overheating only when charging? Use the Nokia battery charger that was included with your phone. Older chargers may not fully charge the battery.
  • Reset your phone. Press and hold the Power and Volume down keys simultaneously until you feel the phone vibrate. After this operation, you may need to set the date and time on the phone. Note that this does not remove any settings or your personal content. You might try this too! Make sure you have the latest software update; of course you have to have enough battery power to do this:
  • updating your phone software, and you can get fresh new features and improved performance too. Your phone supports wireless Over the Air (OTA) updates and there is no need for cables or computer, just download and install the update using your phone. Also, your settings, apps, photos, and text messages remain safe and sound.
  • Your phone notifies you when an update is available for you. You can also check for updates, just tap Settings > Phone Update.o view and to install the updates, tap the notification message, and follow the instructions shown on your phone. You can install the update immediately, or postpone the update to a more convenient time.The update should take around 15-30 minutes, but a major update could take up to 2 hours to complete depending on your phone model. You are not able to use your phone during the update installation. Follow all the update prompts, and do not worry if your phone restarts several times during the process, that is completely normal.
  • Otherwise contact Microssoft.com
N70 SOFTWARE HOW TO UPDATE
1) Update using your phone's Software Update application
We recommend you use a WiFi connection if possible. For most phones:
  • Select Menu > Applications > (Tools >) SW Update
or
  • Select Menu > Settings > Phone > Phone updates
    Choose the updates you want to install and follow the on-screen instructions.
How to update n73
Hi there,Well as consider that you need to update the firmware of your phone. There are 2 ways to do that -
1. You may update using your pc. Follow the link below -http://europe.nokia.com/support/product-support/device-software-update
Type your phone model number (N73), and follow all the steps provided on the link.
2. You may also update your phone using phone just go to application, SW Update. You may see a lots of program update here, just select programs or firmware or both (which you want to update) than go to options and select start update.
Post comments for more information or help.
Good Luck!!
1helpful
How do i renewer my Nokia software
You can update your phone's software or reinstall it by following the steps below.
1.Download Nokia Software Updater from the following link.( http://europe.nokia.com/support/product-support/device-software-update/update-with-pc ).
2.Install it on your computer along with the PC Suite provided with your phone.
3.Connect your phone via USB Cable to the computer in the PC Suite mode.
4.Backup your personal data to the Memory Card or your PC using Nokia PC Suite.
4.Double click and open the Nokia Software Updater (Make sure that the broadband connection is active on your PC)
5.Your phone will be automatically identified by the Nokia Software Updater and will find the available software updates.If there are no new updates available for your phone you can reinstall the software.
6.Click on the start button to proceed.Please don't try to use or disconnect the phone until update is complete and phone is restarted.
7.Disconnect the USB Cable when the update is completed and phone is restarted.You can use the phone as usual.
Jun 21, 2011 • Cell Phones
1helpful
How to change the os of my nokia 5310 ?
phone_new.gifUpdate using your phone You can download most software updates straight to your phone, with no need for a PC.
These free software updates from Nokia keep your phone working at its best, with improvements to battery life and performance as well as new features.
  1. Select Menu > Settings > Phone > Phone Updates.
  2. Select any available updates you want to install.
  3. To download, follow the on-screen instructions.
If the software update doesn't appear, learn how to update your phone's software by consulting your user guide
containerbtm1.png pc.gifUpdate using your PC If you use a PC, Nokia Ovi Suite can check your phone's current software version and download new versions when they become available, using your PC's internet connection.
Nokia Ovi Suite also helps you to back up your contacts and photos, synchronise your calendar and update other applications such as Maps.
To update your phone's software using Nokia Ovi Suite on your PC:
  1. On your PC, open Nokia Ovi Suite and connect your phone
  2. In Nokia Ovi Suite, select Tools > Software updates.
  3. From the list of available updates, choose what you'd like to install.
It's free to download and use Nokia Ovi Suite. It runs on Windows 7, Windows Vista and Windows XP.
Note: If you're a Mac user, you need to update your software from your device as Nokia Ovi Suite is not available for Mac OS.
4helpful
Hwo iam update my nokia n73 phone.
You can update your phone by Nokia pc suite and nokia updater. Firstly connect your phone with your pc via multimedia cable. Then start nokia updater. You need internet connection to your pc to update your phone.
3helpful
I want to update my w350i
Hello ,
Using 'Update Service' you can update your W350i for latest enhancements.
* Before updating the phone software you should backup your contacts, media files, notes , bookmarks etc.
1) Download the 'Update Service' software using this link :
Click Here
2) Simply run Update Service and connect your phone to the application with a USB cable.
This procedure only takes a couple of minutes. Software updates are released at different times depending on your phone model and operator. How long a software update takes is very much dependent on the speed of your Internet connection and which phone model you are updating.
It may take about 10 to 40 minutes to update your phone.
The phone battery needs to be fully charged to ensure that the phone will not power down during update. Also ensure that you've got a stable Internet connection.
3) If you have found any update then *go ahead with updating.
3helpful
2answers
How i can update my 5130xm software
Note: Before updating, you might like to backup your phone's contents using Nokia PC Suite. These can be restored once the update is complete.
update_with_pc_1.jpg 1) Download and install Nokia Software Updater (this need only be done once). update_with_pc_2.jpg 2) Connect your phone to your PC with a suitable USB cable and open Nokia Software Updater. update_with_pc_3.jpg 3) Follow the on-screen prompts until your update is complete!
How to check updates for mobile and how flash it
To keep your phone performing at its best, it's a good idea to perform a software update regularly. You might not always notice what an update has done, but it can prevent future problems.
To update the software download the nokia updater from below website
http://europe.nokia.com/support/product-support/services
Select the phone model and it will show the updater.Exe software setup. Download and install it.
Open the installed software and click on start.Connect the mobile phone through USB cable.It will start checking the updates of the mobile and will start updating in your phone.
I recommend to update or reinstall the software please go to nearest NOKIA CARE and they will update or reinstall the software as required.They are more expirenced to do this process.If something wrong happens when you do updating it may make your mobile useless.So better to take to NOKIA CARE.
Note: Reinstalling the software will delete all the content in your phone like contacts, calendar entry etc.
You can also Update software by below steps
As of now no flashing methos is found for nokis 6300.Please go to nearest NOKIA CARE they will fash the mobile for you.
Thank You
17helpful
2answers
I want to latest update for my nokia 7610 phone software
Dear u can find the latest firmware update available for ur phone at the nokia.com/softwareupdate.You can update if any update is available via NOKIA SOFTWARE UPDATER.
Dec 07, 2009 • Nokia 7610
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
